Losi mini B 1/16th 2wd buggy >
Like Tree115Likes
Old 01-17-2023, 10:34 PM
  #391
Do we have a running list of batteries that fit the mini b?
sliding_on13 is offline
Old 01-20-2023, 05:39 PM
  #392
I just have the smaller ones made by Losi/Horizon for the Mini-B.
alternatepoc is offline
Old 01-23-2023, 07:07 AM
  #393
Scrad's Avatar
Trader Rating: 16 (100%+)
Anyone know of a place to find a weight kit in stock for the mini B?
Scrad is offline
Old 01-26-2023, 02:31 PM
  #394
Trader Rating: 81 (100%+)
I ordered this one and really like it. Even when it shows out of stock they make them quick and get them out. https://sth.ecwid.com/Losi-Mini-B-We...Set-p272182004
tom73 is offline
Old 02-16-2023, 05:33 PM
  #395
This one is mine I've been working on..
its running a castle 8200kv on 3s.. My best is 74mph.. I've got a few things done like a Hackfab wheelie bar. 48p gears..
(edit- didn't realize I couldn't share pics yet)
BustedAw11 is offline
Old 03-07-2023, 06:24 AM
  #396
just some info on aluminum parts. This diff case is garbage. Even if its barely screwed together you get binding. Tried everything, absolutely useless...... Only wanted an aluminum diff case because the ball stud mount looks like a very weak point on the plastic case.
https://www.amazon.ca/gp/product/B09...?ie=UTF8&psc=1
I didnt install the aluminum arms, but the tolerances for the steering components and the bell crank was excellent. even came with bearings. It is comparable to the aluminum losi one. I have the pro version....I did use a 0.5 shim for the rear hubs. in regards to the bellcrank ..... I can't f'ing believe losi didnt include bearings with their aluminum ones. This was a a good purchase in my eyes.
banx is offline
Old 03-16-2023, 01:45 PM
  #397
slcf1's Avatar
re: Boki racing.. Like those guys.. fast response.. product is solid. Beats shipping from UK or Canada
slcf1 is offline
Old 03-16-2023, 02:49 PM
  #398
I've shimmed mine up to the point there is almost no play, yet spins freely and turns freely. A couple .1 and .2 shims can be tucked between the steering spindles and arms. A note with the rear transmission case, I only broke mine after I put a washer to raise the ball height. Not sure if it was a weak point after a bunch of crashes but seemed to break a couple crashes in after the putting them on there. What was weird is the replacement trans case now has this area reinforced and wider, like its now meant for a small washer. I wish I could post photos or links :/
staiguy is offline
