Losi mini B 1/16th 2wd buggy >
Like Tree113Likes
Old 05-27-2022, 07:05 PM
  #331
Is there any other battery recommendations for the b pro other than the 2 dynamites that seem out of stock everywhere? I tried a 2000mah for a t from ebay and its not even close to fitting the battery box. I'd have to take out the waterfall to use it. Thx.
Btw i have the hobbywing 5200kv brushless combo.
dswear22 is offline
Old 05-27-2022, 10:50 PM
  #332
I started running microquad packs in mine - CNHL 2s 850's. Ridiculously cheap. Get four or five and you'll run all day.
Sabin is offline
Old 05-28-2022, 11:35 PM
  #333
Running the same battery, really happy with it.
Timw is offline
Old 05-29-2022, 11:32 PM
  #334
Do any of the aftermarket bodies have more room for electronics? I'm looking for a body that's a little bit taller to fit my random batteries and full sized receiver.
Razor_Racer is offline
Old 06-11-2022, 02:17 PM
  #335
I just bought a 12 scale datsun 240z body that has all the room you can imagine, but it's probably not what you are looking for. My mini 8ight buggy body might be a good fit, I'll try that tonight and see if that's an option for you.
YourConfused is offline
Old 06-11-2022, 04:07 PM
  #336
Here ya go, mini 8 buggy body on mini b.
Old 06-11-2022, 04:08 PM
  #337
looks like a pretty good fit actually
Old 06-13-2022, 01:16 AM
  #338
Really itching to pick one of these up. Really enjoyed my mini-t that I had like 15 years ago lol
Pocket_Fred is offline
Old 06-13-2022, 08:37 AM
  #339
savage24x's Avatar
Trader Rating: 17 (100%+)
What brushless motor Kv ratings have you guys been using for your tracks? Very small, mini-z type track converted to carpet for the summer. I was looking at the castle 5300.
EDIT: going with the 4100. Also ordered the Hot Racing shocks for the bleeder screw.
savage24x is offline
Old 06-19-2022, 09:46 PM
  #340
Does anyone know if there's a go-to tire and wheel package for loose dirt? Seems everyone's running on carpet, clay or cement. Thinking maybe ribbed front and spiked pins (if that's the correct description) in the rear
Milkdudd is offline
Old 06-20-2022, 09:35 AM
  #341
Looking for some wisdom from Mini-B owners. I have a brand new Mini-B, all stock brushed electronics. First 2 packs were great, buggy ran perfect. On the 3rd pack, I started experiencing "run aways". It would quit responding to transmitter commands and drive off erratically for a few seconds before coming to a stop. Only way to regain signal was to quickly turn the transmitter off and back on. The blue power indicator light is steady blue all the time, so I don't think it's an intermittent radio power problem. Didn't matter if I was 3 ft away or 200 ft away. Transmitter batteries are good. Range is good. Freshly charged lipo. Literally nothing is different from the first 2 packs through it. Same exact location, so it's not interference either. I've gone through the binding process 4 times, reset my trims and dual rates. All connections are good with the on/off switch, battery and esc plugs, antenna wire isn't loose and in perfect shape, servo securely plugged in. I topped off the lipo and ran it 2 more times with the same problem. I got nuthin' left to check lol. Anybody had this happen? If so, what's the solution?
Thumper01 is offline
Old 06-20-2022, 03:38 PM
  #342
Sounds like the ESC has gone a bit naff (had an electronic malfunction). Pull it, replace with a different ESC.
IIRC, It's a 2-in-1 esc so try binding with a different, known good radio. If it fails on the bench, create a support ticket.
Thumper01 likes this.
Sabin is offline
Old 06-20-2022, 08:26 PM
  #343
At this point, I believe a call to Horizon for a replacement is probably the only option. Are these 2-in-1 receiver/esc units known for having a lot of problems?
Old 06-21-2022, 06:20 PM
  #344
No idea. I pulled all the stock electronics out as soon as I bought the kit.
Sabin is offline
Old 06-21-2022, 06:25 PM
  #345
I bought the Pro Roller version, but after my experiences with the stock controllers on other LOSI sh!t driving my cars full blast strait into concrete or rocks, I wouldn't even dare to run anything on them, ever! I don't know why they sell things with such garbage, as it does nothing for the brand at all. My experiences are both before and after Horizon bought them out, so take that for what it's worth. My Flysky GT3C for $39 was the best first upgrade I made over my old ass Sanwa stuff.
