Losi mini B 1/16th 2wd buggy
#316
I finally got to test out my mini-B at the track last Sunday. Small, technical, carpet track. Built for 1/10th scale with some long jumps. It was a challenge with the mini-B (compared to my 1/10th TLR 22 3.0), but it could handle it. I was using the mini pin rears and wedge fronts. I did once have the servo sort of freeze up after a crash, but a little tap and it cleared whatever jammed it. I didn't do any tuning with springs and oil yet. I think that would help with jumping and making it easier to steer through tight switchbacks.
#317
I have never ran on low pile carpet or astroturf. I was going to setup either of those on a outdoor section of my yard that I use as my “track”. Is the mini b to small for the low pile type astroturf?
#320
Anyone running one of the hobbywing 18 or 12T motors. I bought a 12T combo and soldered/installed everything then noticed the motor shaft is round and has no ground flat spot for the pinion set screw.
Can grind one myself but find it unusual to have to do it.
Figured I would ask before reaching out to hobbywing. I’ll pm someone I know running one but figured this might help someone else picking electronics.
#321
#323
Thanks - yeah so far runs fine and no slipping....just not what I am used to for cars. 12T is pretty darn quick with no boost.....next stop is the track!
#325
Hey guys just got my kids into the mini b and we have 6 cars but only 3 remotes wasn’t sure if anyone had any stock set ups (remote esc motor) they would be willing to part with. They don’t need any brushless stuff just trying to get them running so they can run them around the back yard and practice. I appreciate any help we can get thanks guys.
#326
#327
#328
#329
