PN racing tire compounds?
Probably get a quicker response in the MiniZ thread
Kyosho Mini-Z Series
Most that start trying to run floors find that dust becomes an issue. I know track can be more of investment then might be ready for. A number in the Facebook groups have found that anti fatigue mats work. It’s not the same as the actual track. But an acceptable alternative for many
If you have the space and budget I highly suggest you get a RCP track, it makes these cars so much more fun.
Cheers,
Jim
Absolutely, one thing about RCP track is the Smoothness over the joint. I tried different tiles from hardware stores but none of them is as flat as rcp tiles.
I ran on hardwood for a few months and what I learned is that it can not be clean enough. I would need to swiffer the floor every single time I ran and would need to clean (just plain water on a paper towel) the tires multiple times during a session. I tried a bunch of different Kyosho and PN tires and learned that going softer did not help and if anything softer tires just got dirtier faster. I ended up thinking PN Med Fronts and PN Soft Rears were the way to go.
Cheers,
Jim
Cheers,
Jim
I would also add that RCP allows you to set up the same track layout as someone else, so you can participate in things like HFAY and the Mini 96 Challenge, or even just fast laps on a given layout.
