GL Racing GLF F1 Chassis >
Like Tree285Likes
Old 12-01-2019, 10:14 PM
  #286
lore's Avatar
Originally Posted by Kevinrcstuff
I seriously need something to protect the front spoilers and wheels... any help guys ?
I use the original plastic front body post and the 3D wing print with Tamiya wheel from one of the guy here and since them i did not broke one, either my son or my daughter, and trust me they crash....
Works really great.
lore is offline
Old 12-01-2019, 11:45 PM
  #287
Kevinrcstuff's Avatar
Works really great.
Thanks, I'll give a try!
Kevinrcstuff is offline
Old 12-01-2019, 11:48 PM
  #288
Sounds interesting.
liljohn1064 likes this.
Old 12-03-2019, 12:41 PM
  #289
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Originally Posted by EMU
the wing replaces the entire front wing assembly, mounting to the chassis directly. I felt that this would provide the strongest platform.
did you ever print one?
liljohn1064 is offline
Old 12-03-2019, 05:06 PM
  #290
EMU
EMU's Avatar
I printed a couple for the race in Detroit. I ended up breaking one in half hitting a dead car on the straight which I didn't see in time. Huge hit. Broke my link and saver in that hit. I replaced the wing, but got caught under the rails a bunch of times (rails weren't fully secured at that time). Overall, it did a decent job at reducing rail grab and protected the front end a bit... but, each time it drove under a rail, I broke a link and quickly ran out. I also bent my diff shaft. After spending a lot more time in the pits making repairs, I decided to focus on my other 3 cars and not run F1 despite that being the class that I was looking forward to running most.
the wing dimensions and clearance were designed with the thought of using kyosho dimension wheels and tires. I need to make some revisions to increase durability, and reduce the wing driving under the rails, I just haven't had the time.
liljohn1064 and Kevinrcstuff like this.
EMU is offline
Old 12-13-2019, 06:40 AM
  #291
Originally Posted by art4242
Also posted this on FB, first prototype of 3D printed front wing using Tamiya mini 4WD rollers to keep from digging into or sticking on the rails. Drop in replacement.
This one's still modeled a little roughly but works well when I tested over the weekend. STL file is attached, exported units are in inches if they come out too small. I printed in PLA material on my home printer and have not had any break after multiple crashes. You do have to be careful to not over tighten the self-tapping screws compared to the molded plastic wing.
I used the smaller rollers from this Tamiya package:
https://www.amainhobbies.com/tamiya-...m15381/p734686
Hi mate, just print a few of your wings are they look really nice! But the carbon fiber part that you have to insert inside it, doesn't fit. Do you have the same problem when you print it for the first time?
Thank you!!!
Old 12-13-2019, 07:28 AM
  #292
After purchasing a GLA and really liking the fit and feel I was looking at the GLF as an option but concerned about durability given is also class myself as an average racer.
The Le Mans body teaser pic GL released had me interested but then part of me thinks of I was to go that route I might as well get the GLR
Do you see these F1ís becoming a solid class or a but of a niche one?
EvilR2.0 is offline
Old 12-13-2019, 07:45 AM
  #293
Billy Kelly's Avatar
I was hoping our class would have been going by now. Find out this weekend. I do have feeling that most will end up with the prototype body instead. Takes the risk of wheel to wheel contact out, mostly.
Billy Kelly is offline
Old 12-13-2019, 07:46 AM
  #294
gottapro's Avatar
I think EMU says it all in his post #290. Consider that EMU is an accomplished mini car racer... If he struggles with durability average racers, myself included, will become frustrated two-fold! I am not motivated to repair so much when I have a GLA and GLR that are an absolute pleasure to drive. That said... I still have another GLF-1 kit new in the box. For $240 I will include a set of tires and ship for free anywhere in the USA if interested?
Regards,
[email protected]
gottapro is offline
Old 12-13-2019, 11:02 AM
  #295
Had another thought about it. I believe it will stay most local thing. I donít see PN adding it to there event. I really canít see Kyosho having it at their. Which, unless, GL starts hosting their own races. Kinda leaves it on its own.
Old 12-13-2019, 12:43 PM
  #296
Thank you!!!
Sorry to hear that. I think that the fit of the carbon into the wing depends a lot on the particular printer, material, and print settings you are using.
The exact outline of the first few layers of the material can be variable due to squishing on the build plate and if there's glue stick/tape/etc. on the build plate.
I designed them so they fit well when printed on my printer using PLA, even then I occasionally need to clean up the edges that fit near the carbon with a knife for a good fit.
art4242 is offline
Old 12-13-2019, 01:41 PM
  #297
The exact outline of the first few layers of the material can be variable due to squishing on the build plate and if there glue stick/tape/etc. on the build plate.
I designed them so they fit well when printed on my printer using PLA, even then I occasionally need to clean up the edges that fit near the carbon with knife for a good fit.
thanks my friend, Iíll try to print in on PLA then.
Best regards
Old 12-13-2019, 01:45 PM
  #298
EMU
EMU's Avatar
Originally Posted by gottapro
I think EMU says it all in his post #290. Consider that EMU is an accomplished mini car racer. If he struggles with durability... average racers, myself included, will become frustrated two-fold! The level of commitment required was more than I could handle because I have a GLA and GLR that are an absolute pleasure to drive when set up correctly. That said... I still have a GLF-1 kit new in the box. For $240 I will include a set of tires and ship for free anywhere in the USA if interested?
Regards,
[email protected]
I think the car has real potential, but I just didn't have any luck with it when i was on the track in Detroit. New steering llinks are available, which should help most of the issues that I was having. My car was handling pretty good in practice, but just when I started to try to tighten the line or push the car a little is when I would bang and break.
I think if my front wing design were better, or the link held up, I would have had a different tone. Hopefully I can get more track time soon with it to work out some of the setup...
EMU is offline
Old 12-13-2019, 02:08 PM
  #299
Even using the roller wings our group has had a few broken parts. I've broken the carbon wing once, another racer broke two carbons (in back to back races!), and another broke the plastic front wing mount. I think if you hit a corner just right the rollers don't roll and the wing takes the entire perpendicular load and the weakest point breaks. Not quite sure how to address this, I think the best bet would be a larger carbon piece with more material around the screw holes, in conjunction with the alu or brass wing mount. In the meantime I've stocked up on spare carbons.
We have not broken any servo links yet though.
art4242 is offline
Old 12-13-2019, 05:03 PM
  #300
lore's Avatar
Thank you!!!
Hi, you must shave a bit the boarder of the wing a bit with a file, and it will fit.
Also the hose for the screw, i suggest to screw once first, unscrew and then install.
Follow this steps and you are good to go.
lore is offline
