GL Racing GLF F1 Chassis >
Like Tree285Likes
Old 11-25-2019, 07:19 AM
  #271
Originally Posted by art4242
The wing worked well on the large club track, rear end felt more planted and stable at high speeds. Also tried out the 21 deg GL fronts, which are better balance on my track. Finally feel like it's getting close to dialed in on the larger club track. All of us are running the above wing in the race below. For comparison, lap times were only about 0.2-0.3 sec slower than my GT car with the same power train (3500kv lithium).
https://youtu.be/XWN8trMyAzo
Great video, thanks for sharing. Check your inbox here I sent you a message.
rystang is offline
Old 11-25-2019, 01:15 PM
  #272
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Kevinrcstuff
Hi John,
Iíve got two bodies, one trimed and this one, both have the same problem
Can you take a video with the body off? If the pod is snapping over on the links, you may need to adjust the shims on the pivot ball. If it's only body rub, it would be nice to see how you have it packaged under the body.
liljohn1064 is offline
Old 11-26-2019, 05:18 AM
  #273
Billy Kelly's Avatar
Last couple times on basement track, the F1 didn’t sound or feel right. Found pieces stuck in pinion. None of the other were having this. Figured out this morning that it’s tiny pieces of the tire. You can see the tire in second picture. Trimmed the loose pieces. See how it is tonight
Billy Kelly is offline
Old 11-26-2019, 05:38 AM
  #274
Here’s the cause. Can see the teeth marks matching
Old 11-26-2019, 10:31 AM
  #275
Originally Posted by Billy Kelly
Hereís the cause. Can see the teeth marks matching
I wonder if the tire is sliding toward the gear when you turn left at speed. Might have to retape or glue tire to the wheel. I checked mine and it is fine. I cut some of the edge/flashing off the tires when I first assembled my kit.
rystang is offline
Old 11-26-2019, 10:45 AM
  #276
I trimmed the loose edges thus morning. Most of my basement track are right turns.
Old 11-26-2019, 12:28 PM
  #277
EMU
EMU's Avatar
Is the pinion fully pressed onto the motor shaft? Which motor is that, DXR? If you can slide the pinion further on the shaft, and flip the spur gear, it should give better clearance to the wheel. Another option would be to shim the diff axle .3mm on each side of the mount to move the spur and wheel further away from the center.
EMU is offline
Old 11-28-2019, 02:16 AM
  #278
Kevinrcstuff's Avatar
Do you glue them or just tape in?
Kevinrcstuff is offline
Old 11-28-2019, 03:15 AM
  #279
Tires are taped. I do see now how itís likely the pinion that making contact. I may end up gluing. But last run went good.
Old 11-29-2019, 08:28 AM
  #280
Should have expected this body. It would eliminate the wheel to wheel contact concern I’ve been hearing about.
Old 11-29-2019, 08:42 AM
  #281
LJH
Should have expected this body. It would eliminate the wheel to wheel contact concern Iíve been hearing about.
I am a bit of a sucker for scale looks and the GLF F1 body looked quite cartoonish to me but the LMP body is looking pretty darn good. Now if they did a 919 or R18 that might be enough to sway me.
cheers,
Jim
EMU likes this.
LJH is offline
Old 11-29-2019, 08:53 AM
  #282
cheers,
Jim
F1 body looked fine to me. Iíd been fine with this. For most part, all the LMP style bodies look the same.
Old 11-29-2019, 03:49 PM
  #283
EMU
EMU's Avatar
I felt that they did a good job on the scale appearance of the GLF1. Its not as scale as the way that the Kyosho cars were done, but it has a good representation of the current style, while being fairly generic.
I do like the LMP body style though. The first thing that I did when I first heard about the GLF wheelbase, was search for LMP body options in the same wheelbase that could fit and be raceworthy....
EMU is offline
Old 11-30-2019, 12:52 AM
  #284
I seriously need something to protect the front spoilers and wheels... any help guys ?
Old 12-01-2019, 10:10 PM
  #285
lore's Avatar
I flipped all my spur in opposite direction... i always thought is a better fit
lore is offline
