I need help with my wltoy a959b >
Old 06-22-2019, 04:23 PM
Default I need help with my wltoy a959b
My wltoys a959b won’t move all I hear is the motor spinning also when I spin one wheel The one next to it goes in the other direction. By it won’t even move when I hold it up in the air how to fix plz
QuakersYT is offline
Old 06-22-2019, 05:42 PM
My guess would be your pinion is no longer meshing with your spur gear (or your pinion is loose).
Tonkatrucker is offline
Old 06-24-2019, 11:05 AM
slick2500's Avatar
This^
That is how a differential works, jack up your real car so the drive wheels are off the ground, put the transmission in neutral and turn one of the wheels, the wheel on the other side will spin in the opposite direction.
slick2500 is offline
