Losi Mini 8 db bell crank replace >
Old 06-12-2019, 10:42 AM
Default Losi Mini 8 db bell crank replace
Hello everyone.
Inwas wondering if someone could offer some help. I have a Losi Mini 8 DB and Iím trying to replace the stock bell crank. However I am having some troubles with it. I purchased the Chinese GPM one off of EBay and I have the HR one. It appears that there are no springs with either and the bell cranks donít fit on the stock posts.
Online it says that the HR one is made as a direct replacement for stock parts but Iím not having any success.
Losiboi0928 is offline
Old 06-13-2019, 08:03 PM
racknpinion's Avatar
Afaik, and from what I recall when I owned my DB, it uses a completely different bell crank/servo saver setup from the truggy or the buggy. You may be out of luck unfortunately. You could always try to find some different posts and use a servo mounted servo saver, but whether it's worth it, I couldn't tell you.
racknpinion is offline
