Mini-z MR03 won't pair
Old 04-27-2019, 02:29 PM
Default Mini-z MR03 won't pair
I purchased a MR-03 Sauber in Feb. Ive probably run it less than 10 times. The last couple times i brought it to the track, it would turn on but not be paired, and I would have to pair it. Now, it wont pair at all. Someone told me that perhaps i need to replace the board. Is there anything I should do testing wise before replacing the board? Any other tricks to get it to pair? This is the item: 32327S-B MINI-Z RWD Sauber-Mercedes C9 No. 63 LM 1989 MR-03 Readyset
acidreign is offline
Old 04-27-2019, 03:29 PM
EMU
EMU's Avatar
Are the batteries in the transmitter fully charged? What cells are you using in the transmitter? Does the light on the transmitter come on and stay on?
I would try a radio reset, then pair again.
How can I reset the Syncro KT-531P transmitter? ? MINI-Z Info
Do you have a friend with a transmitter that you can try binding to your car and see if it holds the bind. This would give an idea of the electronics in the car or transmitter are at fault.
If the issue persists, contact Kyosho America for warranty support.
EMU is online now
Old 04-27-2019, 08:02 PM
Thanks I will try that!!!
