Swave e ensotech esc
Old 12-01-2018, 02:57 AM
Default Swave e ensotech esc
I have a swave e combo with 5300kv motor
Could anyone give swave configuration tips?
I have never had a sensored esc and I do not know how to configure it.
Can I put a GL 3500 sensored motor?
gcmauricio is offline
Old 12-01-2018, 09:43 AM
EMU
EMU's Avatar
I have an swave e2 with a gl 3500 sensored motor. It explicitly states not to use a 15mm motor or a motor that is not on their list, but it works. I only ran 2 packs on the car before busting the servo.
for some reason I can't hook the esc up to my phone to adjust settings, so can't be of much help there. I plug it in as the instructions state, but it doesn't fully connect.
EMU is offline
Old 12-02-2018, 12:19 PM
there are many parameters of n% and it is not clear n% in relation to what?
Old 07-16-2019, 04:48 PM
Is it because esc?
did the problem has been resolved?
please give your opinion about this esc. I have already ordered some swave w.
TIA
b.wihardja is offline
Old 07-16-2019, 09:50 PM
EMU
EMU's Avatar
Originally Posted by b.wihardja View Post
Is it because esc?
TIA
cable was not working. I have bluetooth and used a different USB cable to my phone that worked...
the ESC works well, but if you don't have an android interface to connect to it, you cannot adjust it. With the bluetooth you can adjust the settings on the fly which is handy. Because I have the esc on completely different platforms, I can't really do a head to head comparison as the AWD platform that ot is on is less efficient than the 2wd with motor power. I may swap out one of my HW ESCs to test if I find time.
EMU is offline
Old 07-17-2019, 12:44 AM
Glad to hear that now it can work. Does the boost and turbo settings have a lot of influence?
