Associated Reflex 14B/14T >
Like Tree58Likes
Old 05-23-2019, 05:26 PM
  #271
https://scontent-lga3-1.xx.fbcdn.net/v/t1.0-9/61276734_10158083395963357_4979110016649789440_o.j pg?_nc_cat=106&_nc_ht=scontent-lga3-1.xx&oh=a456775fae82ec678bc88a32cbf70b0f&oe=5D9C29 44
LC racing MT tire give it tons of traction.
Josh Matta is offline
Old 05-26-2019, 06:03 PM
  #272
slick2500's Avatar
Linky no worky.
slick2500 is offline
Old 05-27-2019, 06:29 PM
  #273
anyones rear cover come off their motor? I seem to spend more time working on the car than running it,
bastian63 is offline
Old 05-28-2019, 05:34 AM
  #274
Billy Kelly's Avatar
No problems at all so far. Bought some spare parts since pavement is usually hard on buggy’s.
Billy Kelly is offline
Old 06-05-2019, 12:44 AM
  #275
Has anyone tried gluing the bearing on the center diff? Or another fix for the bearing and spur gear failure issue?
Full send rc is offline
Old 06-09-2019, 08:52 AM
  #276
To answer any questions about the "biggest" motor that will fit... It looks like it was designed for up to a 2838 but this 2845 will not. I notched the ESC plate to make the 2838 easier to fit without removing it. I have interference in several areas with this 2845 including the chassis mount for the ESC where it hits the screw mount, the ESC plate (though likely okay if the ESC mount was shaved), and the wires are a TIGHT fit. You could probably mount the motor with the wires 180 deg from the visible position but then they would need a 180 deg bend out of the motor....
I have a 2838 4500 kv ebay motor that runs pretty well and cool with a 17t pinion. The x1401 2938 Tenshock motors appear to be a popular option with the LC racing crowd but I would be surprised if they fit ours. For those that have not investigated, there is a small plate to be removed around the center dog bone to allow the bigger motors to fit. It works great with the motor mentioned but is VERY close when gear mesh is set. I would imagine that it would not mesh correctly with even the 1mm larger motor unless you started grinding or used a bigger pinion.
msmy300z is offline
Old 06-14-2019, 05:25 AM
  #277
#5. Jump practice. I’m trying smaller jumps. Looking for a height that could work if we get some interest in running these at the hobby store. We’ve had a for fun 1:18 racing group for 5-6 years. Figured this might be another to add.
Old 06-19-2019, 05:30 AM
  #278
pastimesteve likes this.
Old 06-21-2019, 11:17 PM
  #279
slick2500's Avatar
Nice to know I'm not the only crazy person who covers the bearings on the back side of the motor with tape.
Old 07-03-2019, 07:34 PM
  #280
Old 07-08-2019, 05:34 AM
  #281
Old 08-01-2019, 05:50 AM
  #282
Well I found that the skatepark did not damage the first thought. The rear motor cover had come off. Installed I new motor this morning. But it’s not working. Motor spins free, but under power it seems boundup. Motor gets hot instantly. Even with motor out of vehicle it does this. It’s not drivetrain binding.
Old 08-02-2019, 04:05 PM
  #283
slick2500's Avatar
Well I found that the skatepark did not damage the first thought. The rear motor cover had come off. Installed I new motor this morning. But itís not working. Motor spins free, but under power it seems boundup. Motor gets hot instantly. Even with motor out of vehicle it does this. Itís not drivetrain binding.
Sounds like a bad motor.
Old 08-02-2019, 04:48 PM
  #284
Really hope not with the brand new one. I was able to pop the rear cover back on the original. But that motor feels messed up just turning by hand.
I know defect happen. So itís possible new one is bad. Been more then few years since had a motor go bad. And never on any Iíve bought.
