GLR 1/27 Scale RWD Pan Chassis
#661
Some things you can do to center everything is center the servo and steering linkage mechanically as close to straight and equal as possible. Then you can trim the radio center and end points to acheive straight steering and equal turn radius. Make sure to set all trims to center and 100%. If you have to move them excessively to center the car or acheive equal turning radius that means the mechanical stuff is off. Servo's are never perfect center, at least none that ive owned. You want the left and right steering links to be equal in length, so make sure they are the same. You can lengthen or shorten the servo link to acheive a mechanical center, or as close as possible. Most racers skip all the mechanical stuff and adjust the centers with the radio trims. Thats better than nothing, but to have it mechanically centered first makes the radio settings less severe and works much better IMO.
Oh and if the car is pulling one way or the other under accelleration you can usually compensate with the side spring pre-load.
#662
GL-Racing announced a new car: de GL-GTR. Looks like its, roughly speaking, a GT-like front with a GL-like back. It will be available in February
https://www.facebook.com/GLRCRACING/...12564928771024
#663
Come race your GL Racing cars in SLC!!
Rules, Schedule and Registration info here -----> 1/28th scale RC Car Racing | West Valley City, UT - Official Site (wvc-ut.gov)
#664
Hats off to GL, this car marks a big leap forward in general for the scale by intoducing arm ball joints & double bell crank to the front . much lower CG in the back with lowered & conventional top shock location and mid chassis side to side brace all also better on paper....lowered top shock should allow lowest avaiable height pan car body instalation ... in the current market with already many good choices this model checks a lot of desired new to this scale boxes. 28th scale 2WD being unique in on-road RC world with pan rear / TC front suspension combo and this car pushes that idea farthest its gone so far... I run a different brand and will be sticking with that but curious to see how this car will do.
That's probably the most interesting thing I found out. Despite what a lot of people have told me, The GLR, is just simply amazing on asphalt. Coming from the larger classes, I'm shocked. Seriously. Get it off the RCP! Go outside, jack it up to max ride height and see if you don't have an absolute blast. Just SWEEP THE LOT FIRST!!! A pebble at full throttle and it will pull a 90 degree turn, into the curb. Also, get the front bumper, trust me.
At this time I think big track mini-z racing if persued woiuld be counter productive to expansion of the class by confusing and diluting the existing momentum that has picked up nicely but it should be something for big race event organizers and clubs or tracks to think about in the backgrounds as a possible variety option at some point in the future.
