GLR 1/27 Scale RWD Pan Chassis >
Like Tree275Likes
Old 01-25-2021, 01:08 PM
  #526
EMU
EMU's Avatar
Originally Posted by b.wihardja
Hello all
What setup has the most effect on the GLR other than the tire choice? maybe tire gluing/tape?
Do you run diff with slip or full lock?
Because I am very new to this car, what is the effect of the changes to the center shock, side spring, front spring, front and rear droop including the grease?
Since the first time I had glr, yesterday my glr can be controlled after changing the receiver. apparently there was a problem with the receiver.
TIA
diff tension I always start with the loosest setting which doesn't slip under full acceleration.
I only run with brass chassis. front springs I use blue edith lexan body and purple with hard bodies. Side spring I mostly use yellow side springs. This has the body roll which I like to have on the car.
the center shock is where I do most of the tuning for the circuit. Spring rate I change to the traction level of the circuit along with body choice to control overall steering feel from mid corner to exit. As spring rate is changed, preload is adjusted to maintain ride height.
Droop is where I control the corner entry to mid corner along with drag brake.
there is a lot you can do with just the center shock.
b.wihardja and NutDriver like this.
EMU is offline
Old 01-25-2021, 04:28 PM
  #527
How about the gease is it play significant role on the setup? I have tamiya soft, med and hard. Mine is vibrating during a corner and sliding uncontrolable during hard braking. Also tend to slide to the left on hard acceleration
b.wihardja is offline
Old 01-25-2021, 08:57 PM
  #528
I
With the GLR, to track prep, brass chassis, 1.5d knuckle, spring sets, and the side pistons are all of the essential parts needed outside of motor and receiver. (car in video was equipped exactly this way)
i don't see any 1.5d knuckle on gl website, there is only 1, 2.5 and 3.
kit standar is 0 degree right?
Edited: our LHS have 1, 2 & 3. What do you prefer 1 or 2?
Old 01-26-2021, 01:08 PM
  #529
EMU
EMU's Avatar
I would choose 1d if 1.5 isn't available. GLR-004-1.5 is part number for the 1.5. Must be out of stock.
Kit is 0d
b.wihardja likes this.
EMU is offline
Old 01-26-2021, 01:22 PM
  #530
EMU
EMU's Avatar
I use Kyosho 30k grease in center shock, and 15k on side and front.
I preload right shock about 1-1.5 turn more than left to balance the load on the rear axle. Depending on side spring used, it may be different. Since the differential being offset produces an imbalance in the pod, this is one way to produce consistent drive off the corner and under braking.
I lift the rear of the car and want both wheels to lift at the same time. The other method would be to balance the rear pod by adding mass.
EMU is offline
Old 03-28-2021, 09:34 PM
  #531
ae4ever's Avatar
With the release of the GLR-GT is the GLR discontinued? I prefer the fixed lower arm suspension but I'm worried about replacement part availability.
ae4ever is offline
Old 03-28-2021, 10:38 PM
  #532
Kremzeek's Avatar
At one point, I think they said that the GLR-GT was not really a replacement for the GLR and they'd continue to sell both. As someone who owns both, I can say that they're very different in the way they handle.
Kremzeek is offline
Old 03-29-2021, 11:31 AM
  #533
ae4ever's Avatar
Can you expand on the handling characteristics of both cars? I feel that I would be more comfortable with the standard 1/12 scale suspension on the GLR.
ae4ever is offline
Old 03-29-2021, 07:14 PM
  #534
Kremzeek's Avatar
Biggest difference is the double-wishbone suspension on the GT. Its supposed to handle bumpier tracks better and not traction roll as much. It also has a lot more grip so you have tons of steering. I added the optional sway bar to tone it down a bit. Downside is that with the shocks and what not, its a little harder to tune than the front of the GLR.
ae4ever likes this.
Kremzeek is offline
Old 03-29-2021, 10:56 PM
  #535
The old GLR already has a lot of steering... I do hope the new version can be run on rcp96 without the need of brass lower deck.
I may have to pick one up soon, GLR GT seems to be the only chassis outside kyosho to support 90/94mm narrow body.
zxcvb1t is offline
Old 04-05-2021, 07:12 AM
  #536
ae4ever's Avatar
Default Front pivot balls binding
Ok, I'm mid build on my GLR a found the front upper and lower pivot balls have a slight bind, what's the easiest method of freeing them up?
ae4ever is offline
Old 04-05-2021, 09:24 AM
  #537
EMU
EMU's Avatar
a little dab of polish, and work it in by hand... then clean the polish off.
ae4ever likes this.
EMU is offline
Old 04-07-2021, 03:49 PM
  #538
ae4ever's Avatar
Default Hard body
Finished with the GLR build and I should have ditched the 03 months ago. Now I'm looking for a hard body to top it with. I ran a auto scale 12c w/ lexan window on my 03 and don't have anything bad to say about it but most of the guys at the track run the jomurema GT01 body w/ lexan roof. What's the gotta have hard body now days?
Thanks,
ae4ever is offline
Old 04-07-2021, 04:18 PM
  #539
EMU
EMU's Avatar
Thanks,
There are a lot of variables, amount of power, traction and driving style definitely come into play with body choice. I personally like the way the 12C handles on the GLR. The jomurema is a good body, with a large setup window. It is pretty neutral with good balance, and shortish overhangs. It seems to do a lot well, but for me, I kind of prefer 12C for low to medium power with medium to high traction.
Here are a few bodies that I was testing with my last real test session... the surface was relatively low traction, so I did like the big McClaren because it tends to slow down reaction somewhat due to the overhangs.
The old R8 is also pretty good, somewhat similar in feel to the jomurema, but doesn't make as much traction.
I tend to prefer cab forward bodies, as I feel that they enhance the strengths of the GLR. I prefer to drive it on the front more than the rear, and the steering feel of the chassis I feel goes well with cab forward designs, or neutral cab.
ae4ever likes this.
EMU is offline
Old 04-07-2021, 07:15 PM
  #540
ae4ever's Avatar
Thanks again EMU, I think I'll stick with the 12c. Are you attending the PNNAC this year? It's at my home track so you'll be able to see all your information put to use, not necessarily good use.... Also why are you still running a sensor less ESC? I just picked up the new PN sensored system now that it's legal.
ae4ever is offline
