Go Back   R/C Tech Forums > Company/Manufacturer Forums > MaxAmps Support Forum
Old 04-16-2010, 12:25 AM   #1
Default how long can a 2s2p 3100 handle 100 amps?
i have a 2s2p 3100 from you, maxamps,. the battery is about 1.8 years old and i dont think i used it during that period. this month i did a few gentle cycles on it with my duratrax ice (.5-1C charges and 1-2C discharges) to see what the pack was like and it was about 2900mah with avg 7.4v i think. after that i put it in my 1/12 with a 2.5 turn tekin rspro system and an eagle tree. the average current over about a 5 min run was 15 amps but there were several (about thirty) 60-90 amp spikes that lasted less than 1 second. there were about 5 times where voltage dropped below 6volts (5.88minimum). i just finished doing another gentle 1c charge 2c discharge cycle on it and it seems the pack only hold 2500mah now.
am i pushing the pack too hard or is it more easily damaged since it is older? will the current limiting feature on an RSpro be enough to protect the battery? any general thoughts and advice would be appreciated.
i can post my eagletree datalog file if you have the software to read it.
benben10 is offline
Old 04-22-2010, 04:16 PM   #2
JAM MaxAmps's Avatar
Generally if a pack has sat that long it's pretty much shot. Packs need to be stored at 60% of their rated capacity and cycled once every 30 days to stay fresh.
Jason
Jason
CMO
[email protected]
www.NitroKillers.com www.MaxAmps.com Caster Driver
JAM MaxAmps is offline
Old 04-29-2010, 12:10 AM   #3
Neu_Racer's Avatar
Trader Rating: 211 (100%+)
Just wanted to chime in that this is not the case for every manufacturer as I've left "other" brands sitting for more than 6 months at a time fully charged and they lost less than .1 volts while providing excellent power still. Good to know for this brand though in case I come across one in the future.
Neu_Racer is offline
Old 04-29-2010, 07:57 AM   #4
Just as a note it won't happen all the time smart guy. The storage at 60% is a suggestion from both us, Hyperion and some other companies to prevent packs from going bad. Preventive maintenance is always best.
Jason
Jason
CMO
[email protected]
Old 07-11-2010, 06:39 AM   #5
Gen
Gen's Avatar
Default cycleing
so whats best for lipo storage ,recharge and discharge 60 % once a month ??
Kyosho MP9 tki3
Kyosho Strr Evo
Os engines
Vp race fuel
Futaba 4pks
Gen is offline
Old 07-12-2010, 06:57 AM   #6
We recommend storing at 60% of the packs rated capacity (Which is what the "Store Mode" is set to charge to in the Hyperion chargers) and this should be done if the packs are going to sit for a week or more. Then if in the "Store" state cycle the packs once every 3 weeks. Charge full, discharge to the Cut off point then charge back to 60%.
Jason
Jason
CMO
[email protected]
Old 12-21-2010, 08:07 AM   #7
Default storing
Good advice !! Just a question though, i have a new race edition 6500 2s 7.4v from you guys ... i only go out about 1x or 2x/month...should i still do this ?
Or should I charge it at storage rates, then charge it up full just b4 use, then put it back onto storage charge until next use ?
Does it need to be fully discharged after storage then fully recharged ?
Awesome pack by the way !! Totally worth the $ and MaxAmps cust service is the best by far !!
dmakrc is offline
Old 12-21-2010, 09:30 PM   #8
" Or should I charge it at storage rates, then charge it up full just b4 use, then put it back onto storage charge until next use ?"
That's the best thing to do in your case. No need to discharge Li-Po's at that point just charge and go.
Jason
Jason
CMO
[email protected]
