one cell bad???
one cell bad???
my max amps saddle pack had 1 cell go bad last weekend
is there any way i can just replace the one cell
Jason
As I mentioned in the PM's there is nothing that can be done. For starters it's a used pack. The other main factor is you cannot run old cells with new. The discharge rates from new to old cells will be to different causing severe imbalance issues in the pack. Discharge what you have to less than a volt and toss it in the trash and buy a new pack.
Jason
Jason
i just decided to pull the soft case off and some of the negative metal prongs from the cells waere off
