hyperion duo
hyperion duo
Hey guys I have a duo. The first one. And I have a few questions. I want to know why it takes me sometimes over 90 mins to charge batteries. 3800-4800 mah Also I had a 3cell 1500mah batt charge for 99mins Is this normal?? Or is something wrong???
Also Can I update this? or do I need to update it?
I use a 13.8v 12.5amp PSU
Also I have a basically new smc battery I run it, then let sit for 5 mins. then go to charge and the charger is telln me the battery is done chargeing. can you tell me why it does that?
Thank you much appreciated. Love this Charger.
here a quick question for you just curious what chemestry of batteries are you charging LiPo, Nimh, nicd??? also what amps are you charging at.
if you your charging lipo the with the cell balancer it does take time to get the last 500 mh in the pack as it useally goes down to around half the amp then further down. till down. I know it take my single cell around 35 minute to fully charge up to 4900.
I hope this helps
I hope this helps
Try watching your charge rate while charging. If your never seeing the true rate you set the charger at you need a bigger Power supply. The DUO needs at least a 30 amp 360 watt power supply to operate correctly.
Jason
I know what I am talking about also the battery doesnt charge for more than 5 seconds. So I cant see shit. The battery is Brand new. Never had a issue. and It even charges on my turnigy 6. So ........
Sumtimes it takes over 2hrs to do 1 battery can you explain that???
I am only running lipos from 3400-5200 mah 25-35c
Well sir due to your attitude and language and seeing that this is an older no longer warrantied charger we will just end this thread here. Good luck and best regards
Jason
Jason
but I could Use help on the charger and could like to know why and how. Thank you
Thank you for the apology, if you have never updated the charger I would start there. Another thing to watch is the balancer while your charging. Your packs may not be balancing out as fast as they used to. The Hyperion's balancer is very sensitive and the extra time may be spent trying to balance out the packs. Check those two things and go from there.
Jason
Jason
Jason
Jason
Lets start over......
I run my SMC 5200mah 25c battery for 12 mins. I go to charge it and it tells me the battery is done. I put the SAME battery to my other charger, it works fine.
Now also this charger is taking longer than my turnigy 6 to charge the same battery. Now why is that???
I never updated it and dont know how really. But I think this charger is dead, and is not working properly. I see it is discontinued but Im sure that you can help me out and fix this isssue.
Thank you and have a good day
Hey I'm trying to help here plain and simple.
What is the DUO's screen reading when it claims your pack is fully charged? What's it showing for numbers. With out that info I can't say whether the charger is bad or not.
Jason
Jason
But I mean with what I am saying what does it sound like to you? I know you guys dont repair chargers, You just replace. I dont know where any of my paperwork is on this item. I was told these DO NOT Break. And are Flawless. That is why I bought this charger.
How is the eos1201?? is that any good compared to this??
Ok let s keep on track with out making rude comments to those trying to help you. If you simply insist on being rude we can simply end this here and now.
Now as for the charger another thing you can try doing is cleaning all the electrical contacts. Charge leads, balance plugs the works. As for the durability of the hyperion chargers I still to this day use an original DUO with out any issues. They have a great track record.
-J
-J
charge peak
Is there anyway to get the peak to go higher than 8.38-8.39?
8.44 is max that is legal, so I would like to get this charger to at least go to that voltage.
