balancing question...
Old 12-10-2008, 03:03 AM
bad_b4's Avatar
Trader Rating: 43 (98%+)
Default balancing question...
i have heard(but never had the balls to try it...) that on 2 cell packs,when balancing,you can actually double the amperage output because with the balancer it is like charging 2 seperate batteries?
EXAMPLE: charging a 4000 2 cell through the balancer at 8 amps..will each cell get 4 amps?
bad_b4 is offline
Old 12-10-2008, 10:15 AM
JAM MaxAmps's Avatar
It's called a 2C charge rate. You have to check with manufacturers but with our Li-Po's you can charge at 2C if you balance charge.
Jason
JAM MaxAmps is offline
