Go Back  R/C Tech Forums > International Forums > Manila Racers
The Big Locked Thread >
View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
Like Tree1Likes
Old 07-26-2013, 03:16 AM
  #86431
bryanito1919's Avatar
FOR SALE / SWAP SH .28 ENGINE WITH PULL STARTER
CLUTCH ASSY AND TUNE PIPE NOT INCLUDED
RFS: CHANGE TO BIG ENGINE
0939 399 0981
[IMG][/IMG]
bryanito1919 is offline
Old 07-26-2013, 05:04 AM
  #86432
Leo V.'s Avatar
Lusot sa ilalim ng mesa ang kulelat
Leo V. is offline
Old 07-26-2013, 05:15 AM
  #86433
geromeling's Avatar
@axo: battle color (neon green) mo ang gagamitin ko bukas para malito ka. wahaha!
geromeling is offline
Old 07-26-2013, 05:33 AM
  #86434
A X O's Avatar
Trader Rating: 51 (100%+)
Ooops. Linawin nyo mabuti. 1st finals ba Ang RC bukas?
Lilipat ba tayo Ng venue sa 2nd at final heat?
Makapag ready na nga rin Ng BOLA at PATPAT para sigurado
A X O is offline
Old 07-26-2013, 06:12 AM
  #86435
Originally Posted by futlus
7000 , 5000 , 3000 sir values ng lapot yan ,sa associated na brand diif oil , onroad diff oils ang pagkakaalam ko mataas , sa offroad basic ata yung 7,5,3
combo , dipende sa driving style mo at tracks , 5000 yung gitna standard , harapan para sa kurabada hahatakin nya yung likod , magaan yung sa likod para iwas spin out sa tracks , nabasa ko lang , tinuro din sakin , yung gitna iwas bigay ng biglaan torque na itransfer sa diff shafts papunta diff papunta dogbone papunta gulong , sa experience namin , pag grasa gamit mo sa tracks ng offroad spinout kalaban mo kahit ganu kakapit gulong mo , yung transfer ng power malakas , trigger control at handling , matrabaho , pagka race mo naka set up ng tama , kahit anung piga nya wala spinout. durog na planetary gear ng diff at putol na dogbone mga nangyayari pag grasa gamit mo
btw wag mo lilinisan yung oring ng kerosene/wd40 baka lumobo or masira sayang naman , soap and water will do
hmm nagka-idea ako sir sa configuration ng diff gear oils...wala kasing LHS dito sa province namin so sa tingin ko we need to experiment oild use in automotive...ano kaya sir ang kasing lapot ng 5000 7000 3000 sa mga oils use in automotive? engine oil,atf oil or even singer oil pwede po ba? i think engine oil will do sa differentials wat ya think sir?
wakanga is offline
Old 07-26-2013, 06:17 AM
  #86436
skuter-race-ta's Avatar
Trader Rating: 34 (100%+)
Originally Posted by japong
Hi po,
I am looking for Airtronics/Sanwa M11 plastic battery case. Yung lalagyan po ng 8xAA battery. Baka may naitago o hindi kayo nagagamit. Bilin ko na lang mga sir.
Also looking for a compatible 3S Lipo Battery for Airtronics/Sanwa M11 as another option. Baka may alam kayo mga sir. salamat..
meron ako sir txt me valenzuela area ako...pang m11 talaga naiwan eto sa m11 ko dati bnew sya kaso natambak na lang pick up nyo na lang dito sa lugar ko po
skuter-race-ta is offline
Old 07-26-2013, 08:24 AM
  #86437
futlus's Avatar
sir mahirap mag timpla pag di mo kabisado yung lapot ng actual na ginagamit , silicon oil ginagamit para di mamaga orings , nasasayo yun kung gusto mo experiment ng mga engine oil , me nabibili clutch fan oil , pure sillicon yun sa automotive supply , 60-150 pesos depende sa brand, yung iba me nakasalulat 10000 yung lapot , yung iba wala naman , yung iba tireblack na maganda , pero if you want it to be accurate , order ka na lang sa mga local shop dito sa manila , pede naman padala nila thru shipping at your expense.
bago ka sumubok ng hindi silicon , try mo muna magbabad ng oring na di naman kelangan , overnyt mo babad , dapat me kapares para makumpara mo yung mamaga or masira oring.
google ka lang baka me mga tips na iba pa oil gamit.
i suggest clutch fan oil at tireblack mix mo na lang para bumaba lapot.
futlus is offline
Old 07-26-2013, 09:16 AM
  #86438
jhay32's Avatar
FOR SALE : Hot Bodies D8
Still Fresh
Engine : Werks B7 pro Sirio Evo 4 crank Case Still intact
Pipe and Manifold : Polish Jammin JP4
8 Wheels & tires
No Electronics
And some extra parts
8K Firm
just pm me and leave ur number
jhay32 is offline
Old 07-26-2013, 09:22 AM
  #86439
Default starter box
Im looking for a starter box...baka mayron kau jan na di na ginagamit kahit used na basta pde pa..Thank you..
09202964241
tnx RC Tech
cicero36 is offline
Old 07-26-2013, 09:14 PM
  #86440
ayun clutch fan oil will try siya, so far wala na akong masyadong spinout inayos ko yung wheel alignment ko medyo toe-in ginawa ko sa rear para kapag umarangkada hindi masyado iikot, and problema ko naman sa kanya ngayon ang hirap kunin ang tamang tune niya, hindi naman loose mga needles at nilagyan ko na ng rubber seals pero kapag nag-straight full throttle ako namamatay siya...siguro mga 20 seconds or more na full throttle tapos biglang mag-stall, hindi naman siya lean kasi yun yung dating settings ko...or medyo barumbado lang kasi ako sa driving ko? dahil ang style of driving ko steady full trot on straight then sudden brake on corner combined with steering turn then sudden full trot na naman? masama ba ang sobrang babad sa full trot?thanks
wakanga is offline
Old 07-27-2013, 12:32 AM
  #86441
binzki's Avatar
Trader Rating: 15 (100%+)
binzki is offline
Old 07-27-2013, 04:03 AM
  #86442
Talking DF 03ra ARTF
DF 03ra ..............12k negotiable.......
-df 03 graphite chassis
-front steering block
-front aluminum c hub
-rear suspension brace
-DF-03 Front One-Way Set............needs new front one way gear
- Tamiya Assembly Universal Shaft
-Himoto brushless motor 9.5T (sensored)
txt me if intrested globe: 09278355631
smart:09185916593
OR JUST PM me
Attached Thumbnails The Big Locked Thread-img_20130727_182647.jpg   The Big Locked Thread-img_20130727_182701.jpg   The Big Locked Thread-img_20130727_182724.jpg   The Big Locked Thread-img_20130727_182758.jpg   The Big Locked Thread-img_20130727_182808.jpg
Tim-t is offline
Old 07-27-2013, 07:34 AM
  #86443
marc's Avatar
lf honda hatchback shell
09194283428
marc is offline
Old 07-27-2013, 07:47 AM
  #86444
xxxlosi's Avatar
Trader Rating: 20 (100%+)
Stealth: i use to watch those guys like the father robert mamonlok and doc eusebio who is the coolest guy in rc always joking and just having. Just like manuel "maning" sy who always use my l300 van driving to light house during night race at violago just have girl inside doing something and the rest is censored . Also didn't forget bobby farinas and ricky kagiat who always teach me technics. The 80's is the most happiest rc races of all .
xxxlosi is offline
Old 07-27-2013, 08:30 PM
  #86445
devilsome's Avatar
LF: Tamiya Blitzer Beetle wheel set.
brand new or used. PM me. thanks!
Attached Thumbnails The Big Locked Thread-%24-kgrhqiokjge4gdhbeztboutbdf2jq%7E%7E48_35.jpg
devilsome is offline
