Go Back  R/C Tech Forums > International Forums > Manila Racers
The Big Locked Thread >
View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
Like Tree1Likes
Old 05-12-2013, 09:23 AM
  #85096
rundown's Avatar
Trader Rating: 18 (100%+)
Default Almost Ready To Run TL01 shortened
http://www.rctech.net/forum/11974414-post920.html
Thank you RCTECH..
rundown is offline
Old 05-12-2013, 09:34 AM
  #85097
sylver3rd's Avatar
Trader Rating: 29 (100%+)
Default .....Sale or Swap
http://www.sulit.com.ph/index.php/vi...Position,1-2,2
Addl info..
Naka front one way, cf upper deck, front cvd, all joint cup upgraded to aluminum, front and rear tamiya sway bar
Swap to BL Combo 8-9t 60amp.. Lipo 2s 4000mah up. ( must be in good condition ) Servo. used is ok.. ad cash if necessary depends on the value..
09173988660
sylver3rd is offline
Old 05-12-2013, 04:11 PM
  #85098
Dongskie's Avatar
Trader Rating: 44 (100%+)
For Sale: Traxxas Slash Wheels&Tires Set P1k only Meet-up Mandaluyong Area / Buyer shoulders shipping cost. FIRST COME FIRST SERVE BASIS / NO RESERVATION
Attached Thumbnails The Big Locked Thread-375098_603391446352149_2098738242_n.jpg   The Big Locked Thread-941844_600420439982583_143149938_n.jpg
Dongskie is offline
Old 05-12-2013, 05:46 PM
  #85099
r_escuy's Avatar
Default for sale
FOR SALE
1/8 SCALE BUGGY KYOSHO NEO
ALMOST READY TO RUN
PULLSTART NEO ENGINE .21
NO RADIO AND IGNITER
PRICE : sold sold sold
r_escuy is offline
Old 05-12-2013, 06:42 PM
  #85100
shock@yahoo.com's Avatar
Trader Rating: 7 (82%+)
Default for sale
SAVAGE XL HPI PHP 12K
FX ENGINE TAMIYA BROKEN HEAT SINK, AND BAKPLATE ROTO
WITH ROTO STARTER
WITH FM REMOTE
SHELL
NEW TIRES
VERY GOOD UNDER CHASSIS
PHP 12K
AIR BOAT
AQUACRAFT
NITRO
WITH STARTER
SERVO
PHP 8K
NANDA NRB3
SERVO
RTR
BAGO PA TO
PHP 8K
KESTREL 500 HELI
PHP 2K
WITH BOX
KYOSHO V1 RR
RB ENGINE AND RB PIPE
VERY GOOD CONDITION
PHP 12K
09273868095
5692703
Attached Thumbnails The Big Locked Thread-dsc09921.jpg   The Big Locked Thread-dsc08122.jpg   The Big Locked Thread-dsc09516.jpg   The Big Locked Thread-dsc09449.jpg   The Big Locked Thread-dsc09862.jpg
shock@yahoo.com is offline
Old 05-12-2013, 07:07 PM
  #85101
miles514's Avatar
knightwalker - sir pakiusap lang, every pics uploaded pls press enter para pababa yung pics mo, hindi pahalang...
miles514 is offline
Old 05-12-2013, 08:16 PM
  #85102
LGWGM's Avatar
Originally Posted by LGWGM
Used LRP Nitro Engine ZR.30 X Competition (spin start abled) <1 3/4 gallon though it including break in> P10K now!
Cubic capacity ...... .30 (4.92ccm)
Power .....................4.21HP
Max. RPM................38.300
RFS: Could hardly find a bashing spot for nitro so I'm done with nitro.
Used Losi LST XXL rx 1100 mAh rx batt pack P600
Used Tenergy 6v 3300 mAh batt pack P900
Used Dynamite 086 pipe P1.5k
Used Glow plug igniter (w/ batt meter) + charger + rechargeable battery P900
Used Futaba S9450 digital servo P3,500
Used Losi F/R servo P400
--- Losi Cluth shoes (mounted but not ran - shows some scratch marks due to install/uninstall) P1,000
New Losi LST XXL Exhaust Header P1,175
New Losi TiNi Diff ring/pinion P1,850 (2 sets available)
New Losi F/R Diff Bevel Gear set P695 (2 sets available)
New Losi Pull/Spin start One-Way Bearing P875
New Losi Front/Rear Bevel Gear Set (28/17) P660
New Losi Cluth Nut & hardware P525
New Dubro Silicone Fuel Tubing, 2', Medium P390
New Losi Exhaust spring P250
New Losi Clutch & Nut Hardware P500
New
Losi Combo Pull/Spin Start Assembly P1,100
New
Losi Aluminum Diff Case, Blue:LST/2,AFT
P990 (2 sets available)
New MG996R servo SOLD
More parts HERE
Ask any question you have (private message/sms)
Will add more items as I find them. Thanks for looking
Contact number +639266838717
Pics
LGWGM is offline
Old 05-13-2013, 12:19 AM
  #85103
binzki's Avatar
Trader Rating: 15 (100%+)
binzki is offline
Old 05-13-2013, 02:38 AM
  #85104
TOJ
TOJ's Avatar
Default for sale
16>18 Volts 4 Amps Regulated Power Supply
Good for Nitro Engine Starter Box
35% higher voltage for more cranking power.
600.
Short Tuning Springs by 3Racing in metallic colors
set of 4 pairs
Hard (silver),Medium Hard (blue),Medium Soft (gold),Soft (pink)
Brand New 400. for all 4 pairs (never used, mounted only)
Pinon Gears 200. each
48P 18t yokomo (unused)
48P 23t associated (used)
64P 24t xenon (brand new)
Spur Gears 64P 250. each
104t Xenon (used once)
128t Losi (brand new in Pack)
Team Associated TC4 Front & Rear Option Suspension Mount Set
(Rear Toe-In 3 degrees)
Brand New in Part Tree 350.
call or txt 0922-8583385
meet up QC area
Attached Thumbnails The Big Locked Thread-4-amps.jpg   The Big Locked Thread-tuning-springs.jpg   The Big Locked Thread-18t-23t-48p.jpg   The Big Locked Thread-24t-64p.jpg   The Big Locked Thread-104t-128t.jpg
TOJ is offline
Old 05-13-2013, 02:54 AM
  #85105
Originally Posted by wntdcarbon
For sale TEH R31 / Toolbox
TEH-R31 Eagle Racing CF convertion - 5000php
TOOLBOX -1000php
TEH R31 w/ Hop Ups
NOTE : Kit Only No Electronics Included
MORE PIC. of TEH R31 without Electronics
http://i1002.photobucket.com/albums/...ps627075a6.jpg
http://i1002.photobucket.com/albums/...ps3dc39d79.jpg
http://i1002.photobucket.com/albums/...ps0068c127.jpg
http://i1002.photobucket.com/albums/...ps0bbee964.jpg
http://s1002.beta.photobucket.com/user/carb0n/library/
Kit:
R31 Eagle Racing CF Convertion
R31 Eagle Racing Front One Way
R31 Eagle Racing Multi Diff Solid Spool axle
R31 Eagle Racing Aluminum Steering
R31 Eagle Racing Wide Angle Unis. F/R
R31 Eagle Racing Aluminum 10deg. C-hub
R31 Eagle Racing Aluminum Motor mount (Gold)
R31 Eagle Racing Aluminum Spur Gear Holder
Aluminum Dampers (not sure Eagle Racing)
R31 Eagle Racing Aluminum Servo Post
55% CS/Overdrive
F- 40 / 14 (Aluminum)
C- 18 / 18 both Aluminum Pulleys
R- 21 (Aluminum) / 36
Spring
F= Tamiya RED shoft Spring (but binalatan ko na dahil nababakbak para mas malinis tignan)
R= Super SOFT (from inertia)
FREEBIES for KIT
-almost B.new Tamiya 112T Spur
-Eagle Racing Front One Way tube for TA05 w/ 39T Pulley
-Eagle Racing 21T Front Center Aluminum Pulley
-TEH-R31 TUB CHASSIS
-TEH-R31 Front and Rear Shock Tower
-TAMIYA Adjustable offset rims with USED Threaded Tire (70%)
-BASHING SHELL YOKOMO S14 w/ Light Buckets ang Wing
-USED Painted Yokomo Rims (OFFSET maybe 6 or 7mm)
-1set China Rims and Stretch Tire 80%
NOTE : body post cut (advice to replace for other type or brand of shell)
Shock Piston need to replace for better performance but still in good working condition (may 2 piston modified 4 holes)
No Rear Diffuser
TOOLBOX -1000php
almost b.new bought last Dec. 2012 may price tag pa
(yung part na Orange is made of metal kasya ang kit w/ shell and some spare parts)
http://i1002.photobucket.com/albums/...psd9eedcc1.jpg
MORE PICS. pa CHECK nalang po yung mga Pictures dito
RFS : Planning to get 1:1, and nagiging too much busy nadin sa work....
For Inquiries
Send me SMS or CALL 09065812324
Open for PART OUT
Open For Meet Ups Depende sa Magiging usapan
No Lowballer Please ! only for Serious buyers
UP !
VERY RUSH ! !
TOOLBOX -1000php
For Individual purchase , Meet u place
-The District Mall ( ayala mall ) dulo ng Daang Hari )
-SM Dasmarinas
or get this both for 5500php ( Pick-UP SM DASMARINAS only for this two item ) )
FIXED PRICE na po !
wntdcarbon is offline
Old 05-13-2013, 03:31 AM
  #85106
miles514's Avatar
For Sale:
very slightly used 3Racing FGX f1 car
with Pit shimizu racing tires front and rear
extra pit shimizu front (medium comp)
stabilizer bar
Bnew BMS 706MG low profile hi-speed servo
extra speed tuned gears
silvercan stock motor
some spares, box and manual
6K
Attached Thumbnails The Big Locked Thread-img_3056.jpg   The Big Locked Thread-img_3295.jpg
miles514 is offline
Old 05-13-2013, 03:36 AM
  #85107
miles514's Avatar
Bawas gamit Sale!!!
HPI RS4 Rally Slipper clutch w/ manual - 1000 (free new 84 teeth 48p spur gear)
Proline SC10 2wd beadlock rims front & rear - 1000
Bnew F103 Carbon reinforced arms set - 500
Bnew F103 Type A front rubber tires mounted - 800
Bnew GPM alloy rear damper mount for CC01(silver) - 800
Bnew 3racing alumn. belt pulley for HB cyclone- 500 ea
LRP Vector X11 4.5T BL motor - 2K - GOOD FOR MOD RACING!
09178903878
sa jp lang ang meet up![/size]
Attached Thumbnails The Big Locked Thread-img_3274.jpg   The Big Locked Thread-img_3066.jpg   The Big Locked Thread-b_cc030.jpg   The Big Locked Thread-rim.jpg   The Big Locked Thread-dsc_0049.jpg
miles514 is offline
Old 05-13-2013, 03:40 AM
  #85108
miles514's Avatar
FOR SALE
Novak GT7 brushed esc no motor limit
good for F1 and Mini racing
box and manual
free Tamiya stock motor!
2.8K
09178903878
Attached Thumbnails The Big Locked Thread-img_3309.jpg   The Big Locked Thread-img_3310.jpg
miles514 is offline
  #85109
zaint_l13's Avatar
FOR SALE YOKOMO DRB RED LTD. EDITION FULLY HOPPED+SPEED PASSION VER. 3 13.5T BL MOTOR ,STOCK SPARES, AND YOKOMO SUPER DRIFT SPRINGS....... ASKING PRICE P35K
HOPPED UP ADDED. CS GEARS 2.0, REAR UPRIGHTS, KAZAMA BULKHEAD, 10 DEGREES C-HUBS, KNUCKLES, ENROUTE 12T RED PULLEY, 2.0 REAR SUSPENSION BLOCK... 09292006666
kit only ...http://i913.photobucket.com/albums/a...psdb04188f.jpg
http://i913.photobucket.com/albums/a...ps7bc99277.jpg
http://i913.photobucket.com/albums/a...ps860f4644.jpg
zaint_l13 is offline
Old 05-13-2013, 06:06 AM
  #85110
janalexx1's Avatar
Trader Rating: 22 (100%+)
Default For Sale Tamiya Toyota GT86 Bodyshell
Hello Guys,
Selling a brand new Tamiya Toyota GT86 Bodyshell
2,000.00pesos
Light buckets
Twin Mufflers
Side Mirror
Wiper
Yokomo Wing
Contact number 09175400903
Meetup at Boni MRT or Magallanes MRT Stations
Attached Thumbnails The Big Locked Thread-734047_278455952286926_1329746992_n.jpg   The Big Locked Thread-882866_287724698026718_1175788873_o.jpg   The Big Locked Thread-884343_287724664693388_701018515_o.jpg
janalexx1 is offline
