Go Back  R/C Tech Forums > International Forums > Manila Racers
The Big Locked Thread >
View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
Like Tree1Likes
Old 05-04-2013, 05:21 AM
  #84961
drptnx30vg's Avatar
Trader Rating: 14 (100%+)
Smile
Originally Posted by kikorafael
looking for: aluminum servo horn for hitec ( 24t )
any brand will do, basta yung mataba at mahaba...
parang ganito:
sir meron nyan c sonic vp pro ang brand....
drptnx30vg is offline
Old 05-04-2013, 05:55 AM
  #84962
kikorafael's Avatar
thanks sir, may contact number po ba kayo? bukas pa ba sonic boom? kala ko sir nagsara napo.
kikorafael is offline
Old 05-04-2013, 06:00 AM
  #84963
X32garrick's Avatar
Trader Rating: 41 (100%+)
Originally Posted by chrstr
pidi pala tt01 sa rally bukod sa tires at rally body mga boss ano pa need palitan sa stock? thanks
I recommend you cut the tub chassis around the suspension arm area to give the arms more clearance. After you do, check if the shocks need to be extended by changing the rod ends to longer ones. Other than that, you're good to go!
X32garrick is offline
Old 05-04-2013, 06:45 AM
  #84964
Default repriced!
Originally Posted by infection
for sale:
1. used Spektrum SR3100 DSM2
1,700 pesos repriced! --> 1500 nalang!
2. Bnew Gt power rc led system
includes:
1 x LED Main Control Box
1 x 5mm Red LED Light
2 x 5mm White LED Light
1 x 3mm White LED Light
2 x 3mm Orange LED Light
2 x Connection Y-cable accessories
600 pesos repriced! --> 500 nalang!
commonwealth meetups.
will ship, buyer shoulders the cost
09155190006
repriced!
infection is offline
Old 05-04-2013, 07:47 AM
  #84965
PhilippineEagle's Avatar
I decided to stick with stock motor for now instead of upgrading. Bought these from HobbyKing.
For Sale BRAND NEW/UNUSED: Turnigy TrackStar 17.5T Sensored Brushless Motor 2270KV
Php 2500 (firm)
Features:
• Sensor-Based for Excellent Torque and Low-Speed Driveability
• Adjustable Timing
• Compatible with any Sensored/Sensorless ESC
• CNC Machined Aluminum Motor Can
• High Purity Copper Windings
• Powerful Sintered Neodymium Magnets
• High Power Solder Tabs
• Removable/Replaceable Rotor
• Precision Engineered for Maximum Energy Conversion
*Note: Sensor cable included
Specs:
Can Size: 540
Turns: 17.5
RPM/v: 2270kv
Sensored: Yes (Standard 6 pin harness)
Max voltage: 7.4 (2S)
Max Current: 28A
Max Watts: 190w
Can Diameter: 36mm
Can Length: 53mm
Shaft Size: 3.175mm
Weight: 177g
For Sale BRAND NEW/UNUSED: Hobbyking X-Car 45A Brushless Car ESC (sensored/sensorless)
Php 2500 (Firm)
Continuous Current: 45A
Burst Current: 190A
Resistance: 0.0010ohm
Suitable Car: 1/10, 1/12 on and off road
Battery: 2-3 cells Lipo (5-9 cells NI-xx)
BEC output: 6V/2A switch mode built-in
Motor type: Sensorless and sensored brushless motors
Running mode: Forward only or forward with reverse (user programmable mode)
Dimension: 42 x 28 x 36mm
Weight: 78g
PhilippineEagle is offline
Old 05-04-2013, 08:51 AM
  #84966
bentoy101's Avatar
Trader Rating: 74 (99%+)
Default For sale!
FOR SALE or SWAP!!!
NEGOTIABLE! MAKE A REASONABLE OFFER LANG!
Extra kits!
1) Sakura Zero S Nissan GTR Touring Car Set-up ARTR 7,000 php Only!
Includes: Teu104bk esc, Futaba S3003 servo, Tamiya Sport Tuned Motor (replace ko silvercan sa pic), Nissan Gtr R34 body (good condition), Rubber tires and FREE drift wheels and tires. Runs really great! Radio,Receiver and Batt nalang kulang READY TO RUN NA! Alloy servo mount post and alloy steering assembly nadin.
2) Sakura Zero S PARTS LOT 2,500 php Only! FREE SHIPPING!
My extra spare parts car. Almost a roller kit nadin. You'll only need the front and rear belts, 1 diff bearing, spur gear assembly, front and rear body mounts and 1 diff pulley. OR 1,500 package nalang with the Sakura ARTR.
3) BNEW Condition INIX Racing 13 Turn 3030kv Brushless Motor 1,700 php Only!
SWAP to 9turn bl Motor. Basically a rebranded hobbywing EZrun motor. 10th scale po ito.
4) BlueBird Servo 660MG+HS Servo 1,800 php Only!
Made in Taiwan.
Weight: 52g / 1.84oz
Dimensions: 40.5 x 20 x 42mm / 1.60" x 0.78" x 1.62"
Torque At 6.0V: 14.2kg/cm , 190 oz/in
Speed At 6.0V: 0.17 sec / 60 at no load
Operating voltage: 4.8 - 6.0V
5) EZrun Program Card 500 php Only!
Came from my Bullistorm Bl esc but works with EZrun esc's din. Pics above.
6) Traxxas Revo Platinum USED Body 500 php Only!
Pics above.
7)
2) Tamiya TT-01 Rally Converted ARTR 6,000 php Only!FREE SHIPPING!
Modded tt-01 with raised ride height with electronics. Sanwa servo, Teu104bk esc and sport tuned motor. Radio,rx and batt nalang kulang ready to run na!
1) Tamiya Durga 4x4 Buggy BRUSHLESS ARTR 10,500 php Only!
Very fresh tamiya durga 4x4 BELT DRIVE buggy. With standard servo, brushless motor and esc. Body painted on the outside and comes with team AE B4 alloy shocks and alloy rear hingepin holder.
6.5k for the kit OR SWAP to CC-01 kit!
3) Traxxas Slash STRC LCG Converted BRUSHLESS ARTR 10,500 php Only!
Letting go of my beloved HANDLES LIKE A DREAM and BETTER than my BLITZ ese!
SWAP to DX3S,DX3R, 3PK, or 4PL Radio and receiver combo!
Package Includes:
FRESH Traxxas Slash 2wd chassis (converted to LCG na)
STRC LCG Conversion kit
Rustler Chassis
RPM Knuckle arms
RPM Rear Hub Carriers
RPM Rear Arms
Traxxas Alloy Shock Caps
BRAND NEW Proline FORD Shell (painted Tamiya Met Blue)
USED hyper 10TT wheels and tires
Brushless Motor and esc
Standard Servo
3) PROLINE Ford Body for SC 2,400 php Only!
BRAND NEW with scale lightbar, DIY lights. Holes are for traxxas slash. Fits MOST 10th scale SC's. Painted tamiya metallic blue!
4) EZrun Program card 450 php Only! HATI TAYO SHIPPING
5) Turnigy TRACKSTAR Program Card 500 php Only!
MORE ITEMS to be added!
David Suico
NEW NUMBER!09323394609
ITEM IS IN CEBU
bentoy101 is offline
Old 05-04-2013, 10:24 AM
  #84967
auto's Avatar
Trader Rating: 18 (100%+)
Default Lf: ofna/hobao hyper tuned pipe 1/8
Hi fellow rc guys
Looking for
-ofna hyper buggy tuned pipe,or any tuned pipe for 1/8 scale.
-prefer ko ung end coupler type Hindi ung spring type
-baka merun kayo lalo na sa mga nag from nitro to brushless ang nagging focus
Pls txt me at 0915-9238449. Thank you guys
auto is offline
Old 05-04-2013, 11:00 AM
  #84968
binzki's Avatar
Trader Rating: 15 (100%+)
binzki shop is back with more items
-bnew ABC hobbies s14 persona
unpainted / uncut
with light buckets
with stickers
plastic film still intact
Price: P2,000
-bnew Civic FD shell
unpainted / uncut
with light buckets
with body kits
with accessories
with stickers
plastic fil still intact
Price: P2,000
-bnew mags with drift tires
spare ones ko ito
bnew still in packaging
26mm and 3mm offset ito...
Price: P700
-evolution 3 shell
used na ito
outside painted (bagong pinta)
black and yellow scheme
no cracks
with s15 light buckets
Price: P2,000
-used ta06 pro (for drifting) kit
comes with box
used na ito
complete parts
for drifting (steering and CS rate pinalitan na)
Price: 13,000
note: kit lang ito.. for drifting...
RFS: upgrade
pics to follow
if you are interested you may contact me thru:
cp: 0 9 1 6 6 9 1 0 6 0 3
ym: antii.hack
pls respect my post
Thank You
-binzki
binzki is offline
Old 05-04-2013, 03:28 PM
  #84969
miles514's Avatar
For Sale:
very slightly used 3Racing FGX f1 car
with Pit shimizu racing tires front and rear
extra pit shimizu front (medium comp)
stabilizer bar
Bnew BMS 706MG low profile hi-speed servo
extra speed tuned gears
silvercan stock motor
some spares, box and manual
09178903878
6K
Exotek FGX chassis - SOLD! thanks Lester
Attached Thumbnails The Big Locked Thread-img_3296.jpg   The Big Locked Thread-img_3295.jpg
miles514 is offline
Old 05-04-2013, 04:36 PM
  #84970
phil_anselmo's Avatar
Originally Posted by phil_anselmo
TRAXXAS EMAXX Electric Monster Truck RTR 12K only or text/pm me your offer FREE SHIPPING!!!!
ITEM IS IN DAVAO
CONTACT NO. 09189590528
Specificications:
Motor : Two Traxxas Titan Monster 550 electric motors
ESC : HPI Racing GT Speed Controller 14.4v (designed for twin 550 motor operation)- Deans plugs installed
Servo : Traxxas 2018 shifting servo(high & low) & Towardpro MG996R high torque servo for steering
TX/RX : Traxxas TQ3 three channel transmitter and receiver
Original Traxxas Emaxx pre-painted and decaled body (fresh with no cracks, only slight scratches)
Original Traxxas Emaxx chrome wheels and Traxxas All Terrain Ripper monster truck tires installed
Hopped-UP Parts
Shock Towers : RPM heavy duty shock towers (front/rear blue)
DriveShaft : Revo-spec heavy duty (4pcs)
Steering Knuckles : Revo-spec heavy duty front (2pcs)
Axle/Bearing : Revo-spec heavy duty (2pcs)
Center Drive Shaft: Revo-spec rear (1pc)
All Stainless-steel screws used on entire kit
You Need:
2 Stick lipo batteries up to 4s to maximize Emaxx power
8 AAA for the Transmitter
Up for this...free shipping!!!!
phil_anselmo is offline
Old 05-04-2013, 05:23 PM
  #84971
miles514's Avatar
Bawas gamit Sale!!!
HPI RS4 Rally Slipper clutch w/ manual - 1000 (free new 84 teeth 48p spur gear)
Proline SC10 2wd beadlock rims front & rear - 1000
Bnew F103 Carbon reinforced arms set - 500
Bnew F103 Type A front rubber tires mounted - 800
Bnew GPM alloy rear damper mount for CC01(silver) - 800
Bnew 3racing alumn. belt pulley for HB cyclone- 500 ea
LRP Vector X11 4.5T BL motor - 2K
SC10 2wd gear diff rebuild kit - 500
09178903878
sa jp lang ang meet up![/size]
Attached Thumbnails The Big Locked Thread-img_3274.jpg   The Big Locked Thread-img_3276.jpg   The Big Locked Thread-img_3066.jpg   The Big Locked Thread-img_3067.jpg   The Big Locked Thread-img_3068.jpg
miles514 is offline
Old 05-04-2013, 09:38 PM
  #84972
knightwalker's Avatar
Default F/S RC DEVIL DRIFT Kit RTR - 10.5k (package)
Can be part out
Assembled DEVIL KIT (Brand New unused)
Tiger 5400mAh 60C Lipo Buzzer and Reader (Brand New unused)
IMAX B6AC (Brand New unused)
Brand New GT3C (Brand New unused)
Generic Shell w/ Decals Monster Drift Car Inspired no holes (Brand New unused)
Tamiya Super Stock Motor (used)
Tamiya 104bk (used)
Towerpro Servo (Brand New unused)
09224790923 / Meet up in any MRT LRT Station
discount on meet up SM North
knightwalker is offline
Old 05-05-2013, 06:23 AM
  #84973
monanj's Avatar
Default for sale
LOSI strike rolling kit with all ateel differential...4k neg
TXRX 2.4ghz hsp....800
hpi tuned pipe black plastic...800
xtm tuned pipe...500
hobao hyper 10sc bodyshell with gt power light kit...1,7k
losi scte rolling kit flotek body...9k
call/text.....09358032737
tnx rc tech!
monanj is offline
Old 05-05-2013, 08:16 AM
  #84974
A X O's Avatar
Trader Rating: 51 (100%+)
FOR SALE
HYPERION Duo Charger
0917-8996600
A X O is offline
Old 05-05-2013, 09:06 AM
  #84975
miggyhipolito's Avatar
Trader Rating: 21 (100%+)
Originally Posted by miggyhipolito
TEH R31 DRIFT KIT FULLY HOPPED UP - P7,500 slightly negotiable or swap to any 4x4 rig text your offers
- front one way / spool / 63%cs
- Futaba s3003 servo
- bunch of upgrades too many to mention
SPUR GEARS P200 each or P700 all five
1. 87T / 48p (not sure what brand)
2. 83T / 06 (tamiya)
3. 120T / 04 (tamiya)
4. 112T / 04 (tamiya)
5. 100t / 64p (yokomo) bnew sealed not in the pic
PINION GEARS P200 each or P350 for both
1. 20T / 06 (tamiya)
2. 34T / 04 (tamiya) RESERVED
Items in Pampanga, Angeles
Shipping through LBC but the buyer handles the fee
0915-612-4683
UP!
miggyhipolito is offline
