Go Back  R/C Tech Forums > International Forums > Manila Racers
The Big Locked Thread >
View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
Like Tree1Likes
Old 04-28-2013, 12:41 AM
  #84811
phil_anselmo's Avatar
Trader Rating: 18 (100%+)
2 items and up free shipping...thanks RCtech
phil_anselmo is offline
Old 04-28-2013, 03:14 AM
  #84812
Default hsp pacesetter
Good day! I have a pacesetter mga sir, pano po ba set up para hindi malikot sa straight line,pano po ba yung camber?toe-in/out? thanks
nixsparx121 is offline
Old 04-28-2013, 04:18 AM
  #84813
miggyhipolito's Avatar
Trader Rating: 21 (100%+)
TEH R31 drift kit fully hopped up cf chassis alum parts
swap to any
4x4 rig scx10, cr01, pangolin etc...
text me 09156124683
miggyhipolito is offline
Old 04-28-2013, 04:43 AM
  #84814
jether's Avatar
Default ...
jether is offline
Old 04-28-2013, 06:04 AM
  #84815
rdl77's Avatar
Trader Rating: 27 (100%+)
toe in sa rear (2-3 deg), toe out sa front (1 deg)
rdl77 is offline
Old 04-28-2013, 06:47 AM
  #84816
louie curillo's Avatar
Default looking for traxxas emax rtr
Lf traxxas emaxx rtr
louie curillo is offline
Old 04-28-2013, 06:49 AM
  #84817
rzdudz's Avatar
Default Short course RTR!!
Selling my Losi SCTE rtr
Price - 11k-- Negotiable
Includes - Spektrum DX3E , Team AE diff gear oil 7k, Tire Adhesive and Spare Parts (plz see pics for verifi
cation)
RFS:Need na Need ang pera
Free Shipping
Contact me at 09176222351 - Dudz
rzdudz is offline
Old 04-28-2013, 06:55 AM
  #84818
Trader Rating: 40 (100%+)
Flysky GT3C with the new redesigned and improved steering wheel
Available Colors: Silver + Black and Orange + Black
Price: 2600
Rapicon RC Fuel (Car)
25% 1430 per gallon
30% 1570 per gallon
Tornado RC Fuel (Car)
25% 1055 per 2.5L can
30% 1225 per 2.5L can
30% 1860 per gallon
we also sell per box (4 gallons or 6 2.5L cans) with discounts, txt or call for more info
we ship anywhere in the philippines
ITEM: 200cc Fuel Gun
Status: On Stock
Price: 950
ITEM: Turnigy nano-tech A-SPEC 6200mah 2S (7.4v) 65~130C Hardcase (NEW)
Status: On Stock
Price: 3365
ITEM: Turnigy Nanotech 6600mah 2s (7.4v) 65-130C hardcase
Status: On Stock
Price: 3160
ITEM: Turnigy Nanotech 6000mah 2s (7.4v) 65-130C hardcase
Status: out of stock
Price: 2760
ITEM: Turnigy Nanotech 5600mah 2s (7.4v) 50-100C hardcase
Status: On stock
Price: 2360
ITEM: Transmitter Radio Wheel (Aluminum)
Status: On Stock
Price: 600
ITEM: Flysky Reciever
Model: FS-GR3C
Channels: 3
Frequency: 2.4Ghz
Compatible with all flysky 2 and 3 channel radios (GT2, GT3 & GT3B)
Status: On Stock
Price: 700
Item: Flysky FS-SM100 USB RC simulator adaptor cable
Status: On Stock
price: 350
Item: Turnigy A-6-10 200W Balance charger & discharger
Input Voltage: 10~18v
Circuit power: Max Charge: 200W / Max Discharge: 25W
Charge Current Range: .1~10.0A
Discharge current range: .1~5.0A
Ni-MH/NiCd cells: 1~18
Li-ion/Poly cells: 1~6
Pb battery voltage: 2~24v
Status: On stock
Price: 3320
Item: 350w Power Supply
Input Voltage: 220~240V AC
Output Voltage: 13.8v DC
Output Amps: 25A
Output Watts: 350W
Status: On Stock
Price: 3700
ITEM: Turnigy Accucel 6 Balance Charger
Status: On Stock
Price: 2000
ITEM: Power Supply 100~240v 5A (for battery chargers)
Status: On Stock
Price: 1000
BM-6 Cell Voltage Monitor 2-6S Lipo (Latest Version) (New Item)
Battery cell range: 2S-6S Lipo/Li-ion/LiFe
Voltage display resolution: 0.001V
Voltage Detection precision: 0.005V
Cell Voltage display range: 1.50-4.99V
Total Voltage display range : 3.00 ~29.94V
Alarm cell voltage: 2.00 ~ 4.00V
Status: On Stock
Price: 985
Item: Digital Caliper
range: 0-150mm
Accuracy: +/- .02mm
Status: On Stock
Price: 1380
Item: BMS-660DMG+HS Super Strong Digital Servo
torque: 14.2kg/cm @ 6v
speed: 0.17sec/60° @ 6v
status: On Stock
price: 1570
Item: BMS-820DMG+HS High Performance Digital Metal Gear
Torque: 10.6kg/cm , 142 oz/in @ 6v
Speed: 0.09 sec /60° @6v
Status: Out of Stock
Price: 2610
ITEM HK15298B High Voltage Coreless Digital MG/BB Servo
Torque: 18kg @ 6v, 20kg @ 7.4v
Weight: 66g
Speed: 0.18 / 60deg @ 6v, 0.16 / 60deg @ 7.4v
Voltage: 4.8v~7.4v
Motor type: Coreless
Status: On Stock
Price: 1395
Item: Turnigy 620DMG+HS High Torque Digital Metal Gear
Servo
Torque: 10.6kg/cm
Speed: .13sec/ 60°
Status: On Stock
price: 1510
Item: Turnigy 25mm Flywheel Removal Tool
For engines .21-.32
Status: On Stock
Price: 435
Item: Hard Steel Tweezer either Straight or Curved
Length: Straight 125mm Curved 120mm
Status: On Stock
Price: 135 (when ordering, please indicate if you want straight or curved)
X-BLADE Precision knife with replaceable SK-5 blade
Status: On Stock
Price: 70
Item: Hex Metric driver set 4pcs
Set includes: 1.5, 2.0, 2.5 & 3.0
Status: On Stock
Price: 700
Item: Hex Standard/Imperial/English driver set 4pcs
Set includes: 050, 1/16, 5/64 & 3/32
Status: On Stock
Price: 730
ITEM: 4mm long shaft Flat Head Screwdriver (for engine tuning)
Length: 105mm
Number of units: 3
Status: On Stock
Price: 170
Item: Turnigy 4mm XL shaft Flat Head Screwdriver (for engine tuning)
Tip Length: 170mm
Status: On Stock
price: 265
Item: Turnigy 5mm long shaft Flat Head Screwdriver
Tip Lenth: 105mm
Status: On Stock
price: 235
Item: Turnigy Long Shaft Exhaust Spring Tool
Status: On Stock
price: 235
ITEM: TURNIGY 4pcs hex socket driver set
Status: On Stock
Price: 460
ITEM: Knife Edge Reamer 0.5-18mm
Status: On Stock
Price: 570
Item: Multifunction wheel nut wrench
with 17mm and 23mm hex nut
and 4mm and 5mm hex key
Status: On Stock
price: 470
Item: Turnigy Flywheel Key w/ H17mm Wrench Tool
Status: On Stock
Price: 370
***pictures at http://rccebu.blogspot.com/ ***
Brand new and used RC parts for sale. (ON HAND)
For inquiries, please text or call to 0922-9661909.
ITEM LOCATION: Cebu
ITEM # 3: Slightly used Hobao monster tires with chrome rims 14mm hex (some curb rash and flaking crome on the rims) tread left 90% - P2250
ITEM # 9: Brand new Proline Velocity Rims 14mm hex (set of 2) - P1260
ITEM # 17: Brand new HPI Savage 2 speed transmission (taken from a brand new Savage X 4.6) - P2700
ITEM # 19: Brand new Flux shocks (1 pack contains 2 shocks) – P1885
ITEM # 20: Brand new Savage X, XL Battery Box only – P625
OR choice of having it with charging jack and switch (taken from a brand new savage xl) – P1250
ITEM # 21: Brand new Savage XL Front/Rear Differential assembly with bulk head (taken from a brand new never used Savage XL) – P2365
ITEM # 22: Team Losi XXL Shocks (taken from a brand new Losi XXL) set of 2 - P1520
ITEM # 23: HPI Savage X, XL turn buckles (Brand new) –P650
ITEM # 24: Used Savage 21/25/X roll cage with mounting hardware (nothing broken, just paint scrapes) - P1350
ITEM # 29: Brand new O’Donnell medium hot glow plugs standard purple long plugs for 25% - 30% nitro content (for picco, novarossi, rb concept and more, check manual for compatibity) – P300/piece
ITEM # 31: HPI Savage XL engine plate w/ brace (taken from a brand new savage xl) – P978
ITEM # 32: HPI Savage XL center dogbones (taken from a brand new savage xl) - P1030
OR choice of having it with cups - P1320
ITEM # 33: CEN 23mm hex (taken from a brand new CEN GST 7.7) - P890
ITEM # 34: HPI Savage Flux complete Bulletproof differential assembly with bulk head, bearings & drive cups (brand new) – P3125
ITEM # 35: Venom fuel tubing (OD=6mm ID=3mm) - P55/foot
ITEM # 37: Dynamite Silicone Switch Cover (transparent blue/florescent yellow) 2pcs per pack - P265
ITEM # 39: Mugen MBX6T wing, wing mount & mounting hardware(taken from a brand new kit) – P1520
ITEM # 49: Brand New Proline wabash rims 40 series 23mm hex 2 pcs per pack – P1155
ITEM # 54: Used standard MT size Proline bowtie tires on 14mm hex aluminum rims MT tires #1079 very good condition tread left 90% - P3560
ITEM # 65: HPI savage 17mm hex and lock nuts (set of 4) - P630
ITEM # 67: HPI savage 14mm hex and lock nuts (set of 4) - P350
ITEM # 68: HPI savage xl extended wheel axles (set of 4) – P2115
ITEM # 69: HPI savage xl outer dogbones (set of 4) - P1195
ITEM # 70: Brand new O’Donnell hot glow plugs standard red long plugs for 5% - 20% nitro content (for picco, novarossi, rb concept and more, check manual for compatibity) – P300
ITEM # 73: RPM Center skidplate for savage x – P1215
ITEM # 74: Losi 15mm shock boots for big bores – P640
ITEM # 77: Du-bro 2-56 safety lock kwik link (clevis) - P245
ITEM # 78: Ofna throttle linkage kit blue (part # 10724) - P255
ITEM # 81: HPI savage high body mount post & throttle horn - P365
ITEM # 83: HPI cap head screw 2.6x12mm 12pcs - P310
ITEM # 90: RB Concept Headshims for .28 engine thickness available .10mm & .3mm. Can be used with other .28 size engines (sold per pack) - P285
ITEM # 91: RB Concept exhaust gasket – P480/pack of 4
ITEM # 92: Dynamite Max-life aluminum clutch shoes – P1570
ITEM # 93: Mugen clutch spring 1.0mm - P155
ITEM # 94: Dynamite clutch shim kit - P440
ITEM # 100: Factory Team Shock oil 35wt - 70wt – P240
ITEM # 103: CLUTCH BELL BEARINGS NEOPRENE SEAL 5x10x4 - P800/pack of 10
ITEM # 104: AXLE BEARING NEOPRENE SEAL 8x16x5 – P700/pack of 10
ITEM # 107: CEN Genesis/Nemesis/GST 7.7 Fuel Tank 220cc - P1095
ITEM # 108: HPI Savage Heavy duty servo saver spring - P248
ITEM # 109: RB Concept Aerosol Lubricant - P435
ITEM # 111: Used Nova Cooling Head for Picco .26 - P1750
ITEM # 113: New Speedmind transmitter bag for 3pk - P1766
ITEM # 114: Fail safe – P750
ITEM # 115: Exhaust gasket – P500/pack of 5
ITEM # 116: Exhaust Spring long –240/ pack of 2
ITEM # 117: Antenna tube with silicone end cap (250mm) – P85
ITEM # 119: Bones Speed Cream Bearing Lubricant - P465
ITEM # 121: Integy Rear Hub Carrier for HPI Savage purple/silver (pre-X, X, XL, Flux) – P1830
ITEM # 122: Castle Creations 6.5mm High Current Bullet Connector – P540
ITEM # 123: Brand New Savage XL 3 Speed Transmission - P3875
ITEM # 125: 3Racing Aluminum fuel tank protector for Savage (silver/pruple) – P1045
ITEM # 126: NIB JR Digital High Voltage Servo Z9100HVS - P8775
ITEM # 128: NIB Tekin Brushless Truggy Motor T8 TT2361 4038 - P8540
ITEM # 130: CorrosionX 16 oz Trigger Spray Bottles - P1685 - Protects your expensive electronics, will not trap heat within the components unlike Plasti Dip, much safer and easier to use than ballons. See this video ===> http://www.youtube.com/watch?v=6jpSW50cobs (Now on Stock!!!)
ITEM # 147: HPI Machined Bulletproof Diff Gear Set – P2350
ITEM # 148:Savage x/xl/flux upper and lower arms with pins (pair) – P880
ITEM # 149:Savage x ss adjustable upper arms (set of 4) – P725
ITEM # 151:Savage 25/x/ss/flux center drive shaft – P635
ITEM # 152:NEW HPI Savage X Roll Bar, Handle, Engine Protector – P685
ITEM # 153:Savage X SS Clear Body with complete decals and antenna tube - P2125
ITEM # 154: HPI Savage Battery Level Indicator – P1967
ITEM # 160: HPI Differential Case Washer 0.7mm (PN 86099) - P240
ITEM # 161: Exhaust manifold spring: 110/ pack of 3
Shipping details:
- Additional shipping charges apply
- Payment must be made through BDO or LBC prior to shipping
- Payment may also be made through PAYPAL (Customer add 3.75% of the total amount to cover the paypal fees)
- Once payment is verified, items will be Shipped through Air21 unless the buyer make other arrangements
- A tracking number will be provided for buyer’s reference
We accept orders for hard to find parts (please call or text for more details)
RCebu is offline
Old 04-28-2013, 08:16 AM
  #84819
TEH R31 Fully Upgraded drift kit - swap to any 4x4 rig: SCX10, CR-01, Pangolin etc...or text me your price offer (no low ballers)
- spool / front one way
- 63% cs
- fully upgraded too many to mention
*free Futaba s3003 servo
shipping through LBC
0915-612-4683
Attached Thumbnails The Big Locked Thread-aff6fe23-b4d9-4b08-bffa-c4e2f96ca26e-2978-00000185623d10b2_zps18e33283.jpg   The Big Locked Thread-5126b380-01ff-4d1b-b22b-33bdb227d204-2978-000001856ca618d5_zps86b4292a.jpg   The Big Locked Thread-bce151b4-b8c3-471f-8aad-4ea2c28ab433-2978-00000185762c2581_zps388c1e18.jpg
Old 04-28-2013, 09:01 AM
  #84820
powerslide9's Avatar
Original Tamiya Monster Beetle ready-to-run
P6500 only
located in Libis, QC
0917-8973307
powerslide9 is offline
Old 04-28-2013, 05:50 PM
  #84821
Default Futaba R603FS Receivers
Originally Posted by bonididit
A friend is looking for several pcs of this item.
- in good condition
- reasonably priced
Pls contact Mang Paul De Jesus
0917 843 8000 Globe
0947 996 6303 Smart
0922 843 8111 Sun
Thanks.
Still looking for this item.
bonididit is offline
Old 04-28-2013, 05:57 PM
  #84822
LF:
1. Dean's Micro Plugs (Mini T) or something similarly small
i need at least two pairs.
and
2. Buggy Dish 2.2 wheels (black preferably)
Dex 09177018522
voodoo is offline
Old 04-28-2013, 06:20 PM
  #84823
please buy my impulse buys.
if may naka Gmade R1 crawler dyan, here's some hop-up items for you... or pwede rin sa ibang build, d.i.y. nalang. all brand new in package.
(from upper left, clockwise)
1. Gmade R1 Front CVA Kit hardened steel - 840 petot
2. Gmade R1 High Clearance bent links 70mm M4 - 530 petot
3. Gmade R1 Skidplate Aluminum for Axle - 610 petot
4. Gmade R1 Delrin Skidplate for chassis - 880 petot
5. Junfac Hardened Universal Shaft Carbon Steel (107-142mm) 5mm hole - 1600 and pair SOLD SOLD SOLD
shipping is 160 via LBC no matter how many items you get.
package all in 3,900 petot including shipping (for items 1 to 5)
refer to Junfac.com for actual prices.
09177018522
voodoo is offline
Old 04-28-2013, 07:48 PM
  #84824
Smile's Avatar
BNEW FLYSKY FS-GT3C 3CH 2.4ghz W/ TX LIPO BATTERY
@P2500 only
The best radio at this price!!!
only 2 stocks left available
CONTACT ME: 09329190625
price is fixed
I do meetups in manila
Smile is offline
Old 04-28-2013, 08:09 PM
  #84825
rdl77's Avatar
Fs: seldom used, never raced tamiya f201 4wd f1 chassis with
bnew front cvd,
bnew adjustable motor mount,
bnew extra parts, 2 bodies (yellow and carbon fiber look) , extra fr/rr springs,
bnew set of tires and rims.
bnew low profile metal geared hi speed servo
bnew 52t hi speed spur gear
no part out/swap/trade
12k. 0932-6069331 sms/pm me
Attached Thumbnails The Big Locked Thread-photo0069.jpg   The Big Locked Thread-photo0070.jpg
rdl77 is offline
