Go Back  R/C Tech Forums > International Forums > Manila Racers
The Big Locked Thread >
View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
Like Tree1Likes
Old 04-05-2013, 10:59 PM
  #84331
champion's Avatar
Trader Rating: 24 (100%+)
Default Tamiya Original goods
Champion Hobbies 3471856 3766006 09228013535 09232802214
Tamiya
#15414 JR Mini 4WD Portable Pit-995
#73004 Display Case C- 495
#66924 Waist Pouch (Small, Blue/Gray)- 895
#66009 Apron (White) - 495
#76620 Miniature Parfait Glass- 95
Upcoming Tamiya Car kits sale from only @ 1595 on April 7 to April 14
don't miss this!
champion is offline
Old 04-05-2013, 11:21 PM
  #84332
pa3ck33's Avatar
Pulled off some favors and ended up inside sa processing center ng philpost looking for my parcel from rcmart and found out na ang delay is caused by undervaluing of items. Hay badtrip ang rcmart dineclare lng nila na ang value e $10 kaya ayun na hold sa customs and iniisa isa ng customs officer yung prices ng items. One tip for future online buyers aware na ang customs for undervaluing of items lalo na pag galing ng china, sg at hk. Kaya ingat lng mga sir nagreresearvh na sila about sa items
pa3ck33 is offline
Old 04-05-2013, 11:51 PM
  #84333
Pirty's Avatar
Trader Rating: 35 (97%+)
For Sale:
Sanwa SRG-BZ brushless servo
2,200 each. 2pcs available
http://www.rc-mushroom.com/product_i...-servo-p-19920
09178224217
Pirty is offline
Old 04-05-2013, 11:55 PM
  #84334
phil_anselmo's Avatar
Trader Rating: 18 (100%+)
Pero nakuha muna item mo sir? Magkano nabayad mo sir?
phil_anselmo is offline
Old 04-06-2013, 12:37 AM
  #84335
pa3ck33's Avatar
Inaantay ko na lng maforward sa cainta kasi at the time na nandun ako di mahanap e ang gulo kasi ng sistema ng registered mail/parcel (had a chance to look at sa side ng ems mas maayos yung sistema nila) and kinausap ko na lng yung customs office and inaccept na lng nya yung declaration ko ng $30 kahit wala ako invoice
pa3ck33 is offline
Old 04-06-2013, 12:41 AM
  #84336
CARakter's Avatar
Trader Rating: 30 (100%+)
Warned you guys about seemingly "undervalued" items. If the prices don't seem to match your shipment, be ready to be "assessed" by them. If you can show your original receipt, that might make things move along faster and probably save you from being slapped with ridiculous tax amounts.
CARakter is offline
Old 04-06-2013, 12:47 AM
  #84337
pa3ck33's Avatar
Di ko naman inistruct ang rcmart to undervalue the items kaya nagulat na lng ako pagpunta ko dun yesterday na ang dineclare nila e $10 lng. And another note yung customs officer sa registered mail/parcel side e mukhng techy at aware din sa rc items natin
pa3ck33 is offline
Old 04-06-2013, 02:53 AM
  #84338
powerslide9's Avatar
Tamiya Monster Beetle
original including box. RTR nothing to fix
P8500-- repriced P7500 only!
Libis, Quezon city
Op17-8973307
powerslide9 is offline
Old 04-06-2013, 04:18 AM
  #84339
Originally Posted by wntdcarbon
For sale TEH R31 ARTR
OPEN FOR Part OUT
UPDATED : PRICELIST for Part out
Some Item are NEGOTIABLE (But please NO LOW BALLER po)
TEH-R31 Eagle Racing CF convertion - 8000php
FUTABA 4PK w/ R614FF 2.4GHz - 8500php
SAVOX SC-1257 TG -RESERVEDp
YOKOMO Shell (JZX100) -2000php
IMAX B6 Charger w/ Power Supply -RESERVED
TOOLBOX -RESERVED
Kit:
R31 Eagle Racing CF Convertion
R31 Eagle Racing Front One Way
R31 Eagle Racing Multi Diff Solid Spool axle
R31 Eagle Racing Aluminum Steering
R31 Eagle Racing Wide Angle Unis. F/R
R31 Eagle Racing Aluminum 10deg. C-hub
R31 Eagle Racing Aluminum Motor mount (Gold)
R31 Eagle Racing Aluminum Spur Gear Holder
Aluminum Dampers (not sure Eagle Racing)
R31 Eagle Racing Aluminum Servo Post
55% CS/Overdrive
F- 40 / 14 (Aluminum)
C- 18 / 18 both Aluminum Pulleys
R- 21 (Aluminum) / 36
Spring
F= Tamiya RED shoft Spring (but binalatan ko na dahil nababakbak para mas malinis tignan)
R= Super SOFT (from inertia)
FREEBIES for KIT
-almost B.new Tamiya 112T Spur
-Eagle Racing Front One Way tube for TA05 w/ 39T Pulley
-Eagle Racing 21T Front Center Aluminum Pulley
-TEH-R31 TUB CHASSIS
-TEH-R31 Front and Rear Shock Tower
-TAMIYA Adjustable offset rims with USED Threaded Tire (70%)
-BASHING SHELL YOKOMO S14 w/ Light Buckets ang Wing
-USED Painted Yokomo Rims (OFFSET maybe 6 or 7mm)
-1set China Rims and Stretch Tire 80%
NOTE : body post cut (advice to replace for other type or brand of shell)
Shock Piston need to replace for better performance but still in good working condition (may 2 piston modified 4 holes)
No Rear Diffuser
Electronics
Servo -RESERVED
SAVOX SC-1257 TG
NOTE: SERVO Wire is Cut almost 2inches nalang yun wire nya but malinis ang pag kakagawa
http://i1002.photobucket.com/albums/...ps4eff3e42.jpg
TX / RX
TX : FUTABA 4PK with USER MANUAL
hop ups:
Aluminum Steering wheel
short Antenna
2100mAh Li-Fe Battery
RX : R614FF 2.4GHz FASST
http://i1002.photobucket.com/albums/...ps8482a2fb.jpg
SHELL (no Damage, minimal scratch) this shell is from sir Kariton Drifting
YOKOMO JZX100 GOODYEAR
ROLLCAGE
LIGHT KIT
LIGHT BUCKETS
NOTE : SHELL Wing Mount damage but already fixed
http://i1002.photobucket.com/albums/...pseb490ef6.jpg
CHARGER -RESERVED
IMAX B6 w Power Supply
http://i1002.photobucket.com/albums/...pse7e70dd2.jpg
TOOLBOX -RESERVED
almost b.new bought last Dec. 2012 may price tag pa
(yung part na Orange is made of metal kasya ang kit w/ shell and some spare parts)
http://i1002.photobucket.com/albums/...psd9eedcc1.jpg
MORE PICS. pa CHECK nalang po yung mga Pictures dito
http://s1002.beta.photobucket.com/user/carb0n/library/
RFS : Planning to get 1:1, and nagiging too much busy nadin sa work....
For Inquiries
Send me SMS or CALL 09065812324
Open for PART OUT
Open For Meet Ups Depende sa Magiging usapan
No Lowballer Please ! only for Serious buyers
UP !
8000php for FUTABA 4PK w/ R614FF 2.4GHz
7500php for TEH-R31 Eagle Racing CF convertion
only for this week !
wntdcarbon is offline
Old 04-06-2013, 07:19 AM
  #84340
Pls Support us... You are the Guys that keep us Going
iamadriftmaniac is offline
Old 04-06-2013, 07:25 AM
  #84341
blind666's Avatar
Trader Rating: 8 (90%+)
Lightbulb For sale
sold
Thanks RCTECH!
blind666 is offline
Old 04-06-2013, 08:14 AM
  #84342
Default For sale!!!!!!!!!!!!!!!!!!
Originally Posted by GPXJOE
FOR SALE!!!!!!!
USED HOBAO 1/10 GP GPX4!!!!!
-WITH BRAND NEW CVD's!!!
-ALUMINUM HOP UPS INCLUDED!!!
-BRAND NEW BELTS INCLUDED!!
-NOVA L5 TUNED ENGINE INCLUDED!!!( NOT SURE IF ITS STILL WORKING)
-CARBON FIBER RADIO PLATE!!!
-ALUMINUM HEX'S!!!
-BODY POST STIFFENERS INCLUDED!!!
-NEW SPARES LIKE BULKHEAD FRONT AND REAR INCLUDED!!!!
-NO ELECTRONICS INCLUDED.
-ONE WAY IN THE FRONT
-DIFFERENTIAL IN THE BACK
-CALL OR TEXT 0943 505 51 17 FOR YOUR OFFER.
REASON FOR SELLING:
-I HAVE A NEW CAR ALREADY.BUT IF NO ONE BUYS, IL USE THE CAR. THATS HOW MUCH I LIKE IT EVEN IF ITS OLD ALREADY
FOR SALE!!!!
that thing you plug your 7.4v lipo to so that it can work with a receiver that uses 6volts only.i think its called a power regulator
1000pesos
FOR SALE!!!
BUGGY NOVA 1/8 SCALE MANIFOLD FOR ALL BUGGIES EXCEPT MUGEN. MUGEN USES A SHORTER MANIFOLD.
USED FOR ONE RACE LANG,IM SELLING THE MANIFOLD BECAUSE I USE A MUGEN AND IT DOES NOT FIT THAT BUGGY
1000PESOS
TEXT OR CALL 0943 505 51 17 MEET UP IN ORTIGAS CENTER AREA LIKE METROWALK
THANKS GUYS!
GPXJOE is offline
Old 04-06-2013, 08:19 AM
  #84343
roniehan's Avatar
Hi Sonic guys, especially fellow nicest MTRCC guys that we miss a lot. I just want to let you know that my friends and I have been moved our regular routine in CV race track. Hope to see you guys there, at least before the new Sucat race track opens.
We need to continue this Saturday MTRCC gathering tradition, RC power guys. God Bless.
roniehan is offline
Old 04-06-2013, 05:16 PM
  #84344
solidcarlo's Avatar
Originally Posted by solidcarlo
UP! Negotiable, package only!
RC Drift Car
JXR Enroute v2 with Box / Manual / Pouch
as per previous owner, it was upgraded to cs 1.8 (please check nlng, i have the stock gears namn)
Servo - Futaba BLS452 Brushless servo
ESC - Nosram
Motor - Novak Ballistic 13.5Turns
Battery - 1pc. Fullymax 6000mah in good condition, 2pcs. BNEW Generic 5000mah battery
Shell - Generic Nissan GTR R35 with led lights and underground lights
With stealth mounts
TX - BNEW Condition Futaba 4PL, upgraded the steering wheel
Transmitter Metal Case - very good quality, dont know the brand
Receiver - 2pcs. Futaba R2104GF
Selling as package only for 30k
RFS: No time to play
09175003548
For pictures, please visit
http://www.sulit.com.ph/index.php/vi...6/RC+Drift+Car
solidcarlo is offline
Old 04-06-2013, 05:42 PM
  #84345
CARakter's Avatar
As for me, I order in small quantities, which equates to low shipping charges , which means they won't even think it's worth the time and effort to even assess it since it's way below the limit and comes in a small box, which means I get it in 3 weeks at my local post office in QC.
CARakter is offline
