Go Back  R/C Tech Forums > International Forums > Manila Racers
The Big Locked Thread >
View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
Like Tree1Likes
Old 02-19-2013, 09:14 PM
  #83416
Default HPI 1/10 Nitro car for sale
HPI rally car for sale P 9,000.00 ARR repriced to P7,000.00
TX,RX and nitro nalang kulang Takbo na.....
Text or call 09189083598
Item is in Boni Avenue Mandaluyong City
Pwede trade ng 1/8 Crawler RTR
Pix nasa page 30 RML2009
rml2009 is offline
Old 02-19-2013, 10:14 PM
  #83417
huaicin's Avatar
LF: Proline Protrac suspension kit for Traxxas Slash 4x4 / Stampede 4x4
PM me or txt me 09274235803
huaicin is offline
Old 02-19-2013, 11:33 PM
  #83418
motionpotion's Avatar
Default L/f
anyone selling a 1:18 or 1:16 rc brushless sana off road po sana at rtr n din
p.m n lang po....
motionpotion is offline
Old 02-20-2013, 12:38 AM
  #83419
leevanm's Avatar
Trader Rating: 20 (100%+)
For Sale : Nitro powered Pipercub-J3
Wing span -- 50" inches (approx. 127 cm)
package includes the ff:
- .25 OS LA series engine with glow plug (needs pre-flight proper tuning)
- fiberglass engine cowling
- fuel tank
- complete analog standard size servos (rudder/elevator/aileron and throttle - Futaba)
- 8Amp external BEC (brand: 3E model)
- aluminum landing gear
- big diameter foam wheel 3-1/4" (approx. 8 cm)
almost complete.... receiver, battery at fuel nalang lilipad na
5k negotiable madali akong kausap try me.
RFS: new project.
call/text 0947-782-0114 (smart)
location is in Pasay (near Naia Terminal 2)
Attached Thumbnails The Big Locked Thread-img_4644.jpg   The Big Locked Thread-img_4647.jpg   The Big Locked Thread-img_4652.jpg   The Big Locked Thread-img_4649.jpg   The Big Locked Thread-img_4650.jpg
leevanm is offline
Old 02-20-2013, 01:19 AM
  #83420
Default swapped
Originally Posted by gennomaria
Axial crawler parts lot for sale
Stock tranny with driveshafts
Stock front and rear axles with aluminum 12mm hex
Stock axial 2.2 rims
Hpi 2.2 rock grabber tires
Imex tdawg 2.2 tires
Jr hi torque servo
Aluminum upper ylink (axial)
Aluminum bent lower links (axial)
Aluminum steering link
Just needs chassis, tx, rx, batt, esc and motor
Txt me ur best offer 09088803712
Rfs d talga kaya mag fabricate ng tube chassis/ quiting this scale of crawlers
Pwede rin swap sa cc01 or losi micro crawler kht rolling kits lang
NO PART OUT!!!!!!
Swapped!! Thanks rctech...
gennomaria is offline
Old 02-20-2013, 04:13 AM
  #83421
Looking for stock trailfinder rims and tires... Ung used lang sana kasi im on a tight budget... Tia
09088803712
Old 02-20-2013, 05:01 AM
  #83422
emer's Avatar
Trader Rating: 32 (97%+)
3RACING B6 CHARGER LIPO, LION, LIFE, NMH, NICAD, PB.
SOFT TOUCH BOTTON.....................2K
NOVAK BRUHLESS COMBO (ESC #1732) (Motor Ballistic 13.5R).....6K
XXT-CR BODY (Stadium truck) A8017................1000.00
XXX 2WD BUGGY BODY A-8041.............800.00
T.O.P. (#AW-SNF4LB) - M4 Alum.Serrated Wheel Nut colors Blue, red....250.00/4pcs,
Great for SC 4x4, scte, will fit most 4MM wheel axle.
3Racing Cooling Fan 7.2V 30 x 30 x10MM ................250.00
(Will not fit MMM)
Castle Creation MMM 2200kv combo new.........16K
picture reference only
Team X-ray XB8 parts package deal various parts.
I dont have time to itemize them for the price of 3.0k
TEAM LOSI XX-4 KIT NO.1.................3.0K
NO ELECTRONICS INCLUDED.
ACCEPTS ONLY SADDLE PACKS.
http://i1235.photobucket.com/albums/.../DSC00300s.jpg
TEAM LOSI XX4 KIT NO.2...................2.5K
NEEDS WING AND WING MOUNT, ALL RUBBER BELTS INSTALLED.
http://i1235.photobucket.com/albums/.../DSC00303s.jpg
http://i1235.photobucket.com/albums/.../DSC00305s.jpg
MAMBA MONSTER MAXX COMBO 2200KV
BNEW ..............15K
FUTABA TX AND RX WALL CHARGER..............200.00
Hardex nut and bolt lock................150.00
Team losi tires, 8rib, ifmar pin, step-pin, t-bone 400.00/pr
EMAXX RPM BODY MOUNTS #80162 ..................800.00
EMAXX YOKES, STUB AXLE #5463...................200.00
REVO SPUR 36T.................................200.00
http://i32.photobucket.com/albums/d1...XASSPUR36T.jpg
REVO SPUR 40T.................................200.00
http://i32.photobucket.com/albums/d1...XXASSPUR66.jpg
EMAXX OUTPUT GEAR 31-T 2ND SPEED #3985........200.00
http://i32.photobucket.com/albums/d1...SOUTPUT31T.jpg
EMAXX OUTPUT GEAR 36-T 1ST SPEED #3984........200.00
EMAXX IDLER GEAR 20T #3996...................400.00
PM or txt 0917-8911698 office hrs. landline 743-2653
pls. include you name with your user name so I can reply.
pls dont txt 10 pm to 6am.
emer is offline
Old 02-20-2013, 06:32 AM
  #83423
skuter-race-ta's Avatar
Trader Rating: 34 (100%+)
p.m n lang po....
pm sent sir...
skuter-race-ta is offline
Old 02-20-2013, 06:49 AM
  #83424
Default Sanwa fhss2 3 channel rx
Looking for SANWA AIRTRONICS RX 3channel fhss2. Just PM me. Thanks
Jam1983 is offline
Old 02-20-2013, 07:47 AM
  #83425
CARakter's Avatar
Trader Rating: 30 (100%+)
Default Wanted!
Looking for:
Tamiya TG10 banana rims
1/8 scale - Tamiya part # 50843
. . . . or any similar size mini lite rims.
need set of 4 . . . PM if you have . . . thanks!
CARakter is offline
Old 02-20-2013, 04:13 PM
  #83426
phil_anselmo's Avatar
Trader Rating: 18 (100%+)
Originally Posted by phil_anselmo
I'm currently looking for an Hop Up parts of Traxxas E maxx , just pm me or contact me thru this no. 09189590528
thanks RCtech
still looking
phil_anselmo is offline
Old 02-20-2013, 05:17 PM
  #83427
Trader Rating: 29 (100%+)
Default for SALE
aramacir is offline
Old 02-20-2013, 05:19 PM
  #83428
mix237's Avatar
Default LF
Looking for:
- Used Tamiya Buggy Champ (Rough Rider) or Sand Scorcher Body.
- Axial (or any brand) Y-Link, used or new.
Pls. call/text (09178916422) or PM.
Thanks.
mix237 is offline
Old 02-20-2013, 05:34 PM
  #83429
huaicin's Avatar
FS:
BNIP Pro-Line Body Mount Replacement Kit (Slash 4x4)
This is a replacement Pro-Line Body Mount Kit, and is intended for use with the Traxxas Slash 4x4 1/10 scale short course truck equipped with the Pro-Line Extended Front and Rear Body Mounts (PRO6087-00).
Price = 360PHP
PM or txt me 09274235803
huaicin is offline
Old 02-20-2013, 08:42 PM
  #83430
Default Hitec Optic 6 radio transmitter and Optima 7 receiver For Sale
For sale : HITEC OPTIC 6 WITH OPTIMA 7 RECEIVER
Almost New. Minsan lang nagamit.
With box and manual.
With simulator cable
PM me if interested.
or Text to +639155455074
don7777 is offline
