View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
Hi Guys,
I am selling my used torque Servo TowerPro MGR946R, good for brake and throttle in nitro card or crawling application.
Weight- 55g
Dimension 40.7*19.7*42.9mm
Stall torque 12kg/cm
Operating speed 0.20sec/60degree(4.8v)
Operating voltage 4.8-7.2V
Temperature range 0- 55deg
Servo Plug: JR (Fits JR and Futaba)
PHP 300 (Pick up Makati Area)
Call or text me 09178218338
REPRICED
Weight- 55g
REPRICED
hello... how much is this package?... how about esc and program card only?
Axial scx10 jeep rubicon RTR
Hi.. Looking for a brand new axial scx10 jeep rubicon RTR or trail honcho RTR. PM me.. Thanks
For sale HPI rally car
HPI rally car for sale P 9,000.00 ARR repriced to P7,000.00
TX,RX and nitro nalang kulang Takbo na.....
Text or call 09189083598
Item is in Ortigas Avenue, Pasig City
Axial crawler parts lot for sale
Stock tranny with driveshafts
Stock front and rear axles with aluminum 12mm hex
Stock axial 2.2 rims
Hpi 2.2 rock grabber tires
Imex tdawg 2.2 tires
Jr hi torque servo
Aluminum upper ylink (axial)
Aluminum bent lower links (axial)
Aluminum steering link
Just needs chassis, tx, rx, batt, esc and motor
Txt me ur best offer 09088803712
Rfs d talga kaya mag fabricate ng tube chassis/ quiting this scale of crawlers
Pwede rin swap sa cc01 or losi micro crawler kht rolling kits lang
NO PART OUT!!!!!!
Jr hi torque servo
NO PART OUT!!!!!!
cessna 400; f4 corsair
fms cessna 400 1.4m wingspan(flown few times only)
no tx/rx
6.5k neg
f4 corsair bnew 800mm(cmplt electronics)
displayed only
no tx/rx
4.5k neg
rfs: no tym flying, will focus on surface rcs
09102974444
no tx/rx
6.5k neg
displayed only
no tx/rx
4.5k neg
09102974444
Turnigy 5000mAh 2S2P 40C hardcase pack lipo battery(ROAR APPROVED)
Php 2500 per pc
First come first served. No connector yet. Brand NEW.
Spec.
Minimum Capacity: 5000mAh
Configuration: 2S2P / 7.4v / 4Cell
Constant Discharge: 40C
Peak Discharge (22sec): 50C
Pack Weight: 326g
Pack Size: 137.5 x 46 x 25mm
Charge Plug: JST-XH
Discharge plug: 5.5mm Bullet-connector
Now officialy approved by ROAR for race use!
Contact Me: SUN 09333486315
Php 2500 per pc
Spec.
Pack Weight: 326g
Charge Plug: JST-XH
FOR SALE!!!!!!!
USED HOBAO 1/10 GP GPX4!!!!!
-WITH BRAND NEW CVD's!!!
-ALUMINUM HOP UPS INCLUDED!!!
-BRAND NEW BELTS INCLUDED!!
-NOVA L5 TUNED ENGINE INCLUDED!!!( NOT SURE IF ITS STILL WORKING)
-CARBON FIBER RADIO PLATE!!!
-ALUMINUM HEX'S!!!
-BODY POST STIFFENERS INCLUDED!!!
-NEW SPARES LIKE BULKHEAD FRONT AND REAR INCLUDED!!!!
-NO ELECTRONICS INCLUDED.
-ONE WAY IN THE FRONT
-DIFFERENTIAL IN THE BACK
-CALL OR TEXT 0943 505 51 17 FOR YOUR OFFER
REASON FOR SELLING:
-I HAVE A NEW CAR ALREADY.BUT IF NO ONE BUYS, IL USE THE CAR. THATS HOW MUCH I LIKE IT EVEN IF ITS OLD ALREADY
FOR SALE!!!!
that thing you plug your 7.4v lipo to so that it can work with a receiver that uses 6volts only.i think its called a power regulator
1000pesos
FOR SALE!!!
OLD BUGGY TIRES AKA ibeam
1 SET 4 PIECES, JUST HAVE TO RE-GLUE THE TIRES TO THE RIMS
400PESOS FOR THE SET
FOR SALE!!!
BUGGY NOVA 1/8 SCALE MANIFOLD FOR ALL BUGGIES EXCEPT MUGEN. MUGEN USES A SHORTER MANIFOLD.
USED FOR ONE RACE LANG,IM SELLING THE MANIFOLD BECAUSE I USE A MUGEN AND IT DOES NOT FIT THAT BUGGY
1000PESOS
TEXT OR CALL 0943 505 51 17 MEET UP IN ORTIGAS CENTER AREA LIKE METROWALK
THANKS GUYS!
-ALUMINUM HEX'S!!!
REASON FOR SELLING:
FOR SALE!!!!
1000pesos
FOR SALE!!!
FOR SALE!!!
1000PESOS
THANKS GUYS!
f104
F104 with hop ups like alum diff, trf damper, front turnbuckles4k na lng parang binili lng hop ups
09178320133
09178320133
Flysky GT3C with the new redesigned and improved steering wheel
Available Colors: Silver + Black and Orange + Black
Price: 2600
Rapicon RC Fuel (Car)
25% 1430 per gallon
30% 1570 per gallon
Tornado RC Fuel (Car)
25% 1055 per 2.5L can
30% 1225 per 2.5L can
30% 1860 per gallon
we also sell per box (4 gallons or 6 2.5L cans) with discounts, txt or call for more info
we ship anywhere in the philippines
ITEM: 200cc Fuel Gun
Status: On Stock
Price: 950
ITEM: Turnigy nano-tech A-SPEC 6200mah 2S (7.4v) 65~130C Hardcase (NEW)
Status: On Stock
Price: 3365
ITEM: Turnigy Nanotech 6600mah 2s (7.4v) 65-130C hardcase
Status: On Stock
Price: 3160
ITEM: Turnigy Nanotech 6000mah 2s (7.4v) 65-130C hardcase
Status: out of stock
Price: 2760
ITEM: Turnigy Nanotech 5600mah 2s (7.4v) 50-100C hardcase
Status: On stock
Price: 2360
ITEM: Transmitter Radio Wheel (Aluminum)
Status: On Stock
Price: 600
ITEM: Flysky Reciever
Model: FS-GR3C
Channels: 3
Frequency: 2.4Ghz
Compatible with all flysky 2 and 3 channel radios (GT2, GT3 & GT3B)
Status: On Stock
Price: 700
Item: Flysky FS-SM100 USB RC simulator adaptor cable
Status: On Stock
price: 350
Item: Turnigy A-6-10 200W Balance charger & discharger
Input Voltage: 10~18v
Circuit power: Max Charge: 200W / Max Discharge: 25W
Charge Current Range: .1~10.0A
Discharge current range: .1~5.0A
Ni-MH/NiCd cells: 1~18
Li-ion/Poly cells: 1~6
Pb battery voltage: 2~24v
Status: On stock
Price: 3320
Item: 350w Power Supply
Input Voltage: 220~240V AC
Output Voltage: 13.8v DC
Output Amps: 25A
Output Watts: 350W
Status: On Stock
Price: 3700
ITEM: Turnigy Accucel 6 Balance Charger
Status: On Stock
Price: 2000
ITEM: Power Supply 100~240v 5A (for battery chargers)
Status: On Stock
Price: 1000
BM-6 Cell Voltage Monitor 2-6S Lipo (Latest Version) (New Item)
Battery cell range: 2S-6S Lipo/Li-ion/LiFe
Voltage display resolution: 0.001V
Voltage Detection precision: 0.005V
Cell Voltage display range: 1.50-4.99V
Total Voltage display range : 3.00 ~29.94V
Alarm cell voltage: 2.00 ~ 4.00V
Status: On Stock
Price: 985
Item: Digital Caliper
range: 0-150mm
Accuracy: +/- .02mm
Status: On Stock
Price: 1380
Item: BMS-660DMG+HS Super Strong Digital Servo
torque: 14.2kg/cm @ 6v
speed: 0.17sec/60° @ 6v
status: On Stock
price: 1570
Item: BMS-820DMG+HS High Performance Digital Metal Gear
Torque: 10.6kg/cm , 142 oz/in @ 6v
Speed: 0.09 sec /60° @6v
Status: Out of Stock
Price: 2610
ITEM HK15298B High Voltage Coreless Digital MG/BB Servo
Torque: 18kg @ 6v, 20kg @ 7.4v
Weight: 66g
Speed: 0.18 / 60deg @ 6v, 0.16 / 60deg @ 7.4v
Voltage: 4.8v~7.4v
Motor type: Coreless
Status: On Stock
Price: 1395
Item: Turnigy 620DMG+HS High Torque Digital Metal Gear
Servo
Torque: 10.6kg/cm
Speed: .13sec/ 60°
Status: On Stock
price: 1510
Item: Turnigy 25mm Flywheel Removal Tool
For engines .21-.32
Status: On Stock
Price: 435
Item: Hard Steel Tweezer either Straight or Curved
Length: Straight 125mm Curved 120mm
Status: On Stock
Price: 135 (when ordering, please indicate if you want straight or curved)
X-BLADE Precision knife with replaceable SK-5 blade
Status: On Stock
Price: 70
Item: Hex Metric driver set 4pcs
Set includes: 1.5, 2.0, 2.5 & 3.0
Status: On Stock
Price: 700
Item: Hex Standard/Imperial/English driver set 4pcs
Set includes: 050, 1/16, 5/64 & 3/32
Status: On Stock
Price: 730
ITEM: 4mm long shaft Flat Head Screwdriver (for engine tuning)
Length: 105mm
Number of units: 3
Status: On Stock
Price: 170
Item: Turnigy 4mm XL shaft Flat Head Screwdriver (for engine tuning)
Tip Length: 170mm
Status: On Stock
price: 265
Item: Turnigy 5mm long shaft Flat Head Screwdriver
Tip Lenth: 105mm
Status: On Stock
price: 235
Item: Turnigy Long Shaft Exhaust Spring Tool
Status: On Stock
price: 235
ITEM: TURNIGY 4pcs hex socket driver set
Status: On Stock
Price: 460
ITEM: Knife Edge Reamer 0.5-18mm
Status: On Stock
Price: 570
Item: Multifunction wheel nut wrench
with 17mm and 23mm hex nut
and 4mm and 5mm hex key
Status: On Stock
price: 470
Item: Turnigy Flywheel Key w/ H17mm Wrench Tool
Status: On Stock
Price: 370
***pictures at http://rccebu.blogspot.com/ ***
Brand new and used RC parts for sale. (ON HAND)
For inquiries, please text or call to 0922-9661909.
ITEM LOCATION: Cebu
ITEM # 3: Slightly used Hobao monster tires with chrome rims 14mm hex (some curb rash and flaking crome on the rims) tread left 90% - P2250
ITEM # 9: Brand new Proline Velocity Rims 14mm hex (set of 2) - P1260
ITEM # 17: Brand new HPI Savage 2 speed transmission (taken from a brand new Savage X 4.6) - P2700
ITEM # 19: Brand new Flux shocks (1 pack contains 2 shocks) P1885
ITEM # 20: Brand new Savage X, XL Battery Box only P625
OR choice of having it with charging jack and switch (taken from a brand new savage xl) P1250
ITEM # 21: Brand new Savage XL Front/Rear Differential assembly with bulk head (taken from a brand new never used Savage XL) P2365
ITEM # 22: Team Losi XXL Shocks (taken from a brand new Losi XXL) set of 2 - P1520
ITEM # 23: HPI Savage X, XL turn buckles (Brand new) P650
ITEM # 24: Used Savage 21/25/X roll cage with mounting hardware (nothing broken, just paint scrapes) - P1350
ITEM # 29: Brand new ODonnell medium hot glow plugs standard purple long plugs for 25% - 30% nitro content (for picco, novarossi, rb concept and more, check manual for compatibity) P300/piece
ITEM # 31: HPI Savage XL engine plate w/ brace (taken from a brand new savage xl) P978
ITEM # 32: HPI Savage XL center dogbones (taken from a brand new savage xl) - P1030
OR choice of having it with cups - P1320
ITEM # 33: CEN 23mm hex (taken from a brand new CEN GST 7.7) - P890
ITEM # 34: HPI Savage Flux complete Bulletproof differential assembly with bulk head, bearings & drive cups (brand new) P3125
ITEM # 35: Venom fuel tubing (OD=6mm ID=3mm) - P55/foot
ITEM # 37: Dynamite Silicone Switch Cover (transparent blue/florescent yellow) 2pcs per pack - P265
ITEM # 39: Mugen MBX6T wing, wing mount & mounting hardware(taken from a brand new kit) P1520
ITEM # 49: Brand New Proline wabash rims 40 series 23mm hex 2 pcs per pack P1155
ITEM # 54: Used standard MT size Proline bowtie tires on 14mm hex aluminum rims MT tires #1079 very good condition tread left 90% - P3560
ITEM # 65: HPI savage 17mm hex and lock nuts (set of 4) - P630
ITEM # 67: HPI savage 14mm hex and lock nuts (set of 4) - P350
ITEM # 68: HPI savage xl extended wheel axles (set of 4) P2115
ITEM # 69: HPI savage xl outer dogbones (set of 4) - P1195
ITEM # 70: Brand new ODonnell hot glow plugs standard red long plugs for 5% - 20% nitro content (for picco, novarossi, rb concept and more, check manual for compatibity) P300
ITEM # 73: RPM Center skidplate for savage x P1215
ITEM # 74: Losi 15mm shock boots for big bores P640
ITEM # 77: Du-bro 2-56 safety lock kwik link (clevis) - P245
ITEM # 78: Ofna throttle linkage kit blue (part # 10724) - P255
ITEM # 81: HPI savage high body mount post & throttle horn - P365
ITEM # 83: HPI cap head screw 2.6x12mm 12pcs - P310
ITEM # 90: RB Concept Headshims for .28 engine thickness available .10mm & .3mm. Can be used with other .28 size engines (sold per pack) - P285
ITEM # 91: RB Concept exhaust gasket P480/pack of 4
ITEM # 92: Dynamite Max-life aluminum clutch shoes P1570
ITEM # 93: Mugen clutch spring 1.0mm - P155
ITEM # 94: Dynamite clutch shim kit - P440
ITEM # 100: Factory Team Shock oil 35wt - 70wt P240
ITEM # 103: CLUTCH BELL BEARINGS NEOPRENE SEAL 5x10x4 - P800/pack of 10
ITEM # 104: AXLE BEARING NEOPRENE SEAL 8x16x5 P700/pack of 10
ITEM # 107: CEN Genesis/Nemesis/GST 7.7 Fuel Tank 220cc - P1095
ITEM # 108: HPI Savage Heavy duty servo saver spring - P248
ITEM # 109: RB Concept Aerosol Lubricant - P435
ITEM # 111: Used Nova Cooling Head for Picco .26 - P1750
ITEM # 113: New Speedmind transmitter bag for 3pk - P1766
ITEM # 114: Fail safe P750
ITEM # 115: Exhaust gasket P500/pack of 5
ITEM # 116: Exhaust Spring long 240/ pack of 2
ITEM # 117: Antenna tube with silicone end cap (250mm) P85
ITEM # 119: Bones Speed Cream Bearing Lubricant - P465
ITEM # 121: Integy Rear Hub Carrier for HPI Savage purple/silver (pre-X, X, XL, Flux) P1830
ITEM # 122: Castle Creations 6.5mm High Current Bullet Connector P540
ITEM # 123: Brand New Savage XL 3 Speed Transmission - P3875
ITEM # 125: 3Racing Aluminum fuel tank protector for Savage (silver/pruple) P1045
ITEM # 126: NIB JR Digital High Voltage Servo Z9100HVS - P8775
ITEM # 128: NIB Tekin Brushless Truggy Motor T8 TT2361 4038 - P8540
ITEM # 130: CorrosionX 16 oz Trigger Spray Bottles - P1685 - Protects your expensive electronics, will not trap heat within the components unlike Plasti Dip, much safer and easier to use than ballons. See this video ===> http://www.youtube.com/watch?v=6jpSW50cobs (Now on Stock!!!)
ITEM # 147: HPI Machined Bulletproof Diff Gear Set P2350
ITEM # 148:Savage x/xl/flux upper and lower arms with pins (pair) P880
ITEM # 149:Savage x ss adjustable upper arms (set of 4) P725
ITEM # 151:Savage 25/x/ss/flux center drive shaft P635
ITEM # 152:NEW HPI Savage X Roll Bar, Handle, Engine Protector P685
ITEM # 153:Savage X SS Clear Body with complete decals and antenna tube - P2125
ITEM # 154: HPI Savage Battery Level Indicator P1967
ITEM # 160: HPI Differential Case Washer 0.7mm (PN 86099) - P240
ITEM # 161: Exhaust manifold spring: 110/ pack of 3
Shipping details:
- Additional shipping charges apply
- Payment must be made through BDO or LBC prior to shipping
- Payment may also be made through PAYPAL (Customer add 3.75% of the total amount to cover the paypal fees)
- Once payment is verified, items will be Shipped through Air21 unless the buyer make other arrangements
- A tracking number will be provided for buyers reference
We accept orders for hard to find parts (please call or text for more details)
Price: 2600
25% 1430 per gallon
30% 1570 per gallon
30% 1860 per gallon
Status: On Stock
Price: 950
Status: On Stock
Price: 3365
Status: On Stock
Price: 3160
Price: 2760
Status: On stock
Price: 2360
Status: On Stock
Price: 600
Model: FS-GR3C
Channels: 3
Frequency: 2.4Ghz
Status: On Stock
Price: 700
Status: On Stock
price: 350
Status: On stock
Price: 3320
Output Amps: 25A
Output Watts: 350W
Status: On Stock
Price: 3700
Status: On Stock
Price: 2000
Status: On Stock
Price: 1000
Status: On Stock
Price: 985
range: 0-150mm
Accuracy: +/- .02mm
Status: On Stock
Price: 1380
status: On Stock
price: 1570
Price: 2610
Weight: 66g
Voltage: 4.8v~7.4v
Status: On Stock
Price: 1395
Servo
Torque: 10.6kg/cm
Speed: .13sec/ 60°
Status: On Stock
price: 1510
For engines .21-.32
Status: On Stock
Price: 435
Status: On Stock
Status: On Stock
Price: 70
Status: On Stock
Price: 700
Status: On Stock
Price: 730
Length: 105mm
Number of units: 3
Status: On Stock
Price: 170
Tip Length: 170mm
Status: On Stock
price: 265
Tip Lenth: 105mm
Status: On Stock
price: 235
Status: On Stock
price: 235
Status: On Stock
Price: 460
Status: On Stock
Price: 570
Status: On Stock
price: 470
Status: On Stock
Price: 370
ITEM LOCATION: Cebu
Shipping details:
THE RETURN TO SONIC BOOM!!!
FIRST PHASE OF THE RENOVATION HAS BEEN FINISHED
TIME TO TEST IT OUT WITH OUR VERY OWN RACE!!!
FEBRUARY 24 2013
SUNDAY
10:00 QUALIFIERS
SONIC BOOM TRACK, BOOM NA BOOM GROUNDS
1/8 NITRO BUGGY
1/8 NITRO TRUGGY
COMPLETE LUNCH WILL BE SERVED!!!
TROPHIES TO BE GIVEN AWAY!!!!!!!!!!
SEE YOU THERE!!!!!!!!
still looking for front 12mm hex stadium truck
hello rc guys
im still looking for
>front /traxxas or HPI firestorm FRONT 12mm HEX kahit plastik or metal
>used ok lang basta ok sa budget ung price kahit lumang luma na
kindly txt me at 0915-923-8449,seldom me mag online mga sir.thank you
