Go Back  R/C Tech Forums > International Forums > Manila Racers
The Big Locked Thread >
View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
Like Tree1Likes
Old 01-22-2013, 07:14 PM
  #82711
jdm_ae92's Avatar
Trader Rating: 16 (100%+)
Originally Posted by RRC
sir ako yung naka white na BMW seated behind the Fernandez father and sons team. grabeng beginner ah, champion sa A Main. so anong beginner motor tuning tip mabibigay mo sa amin?
ah oo.. yung kausap ni doc dennis.. hindi naman sir.. wala din ako maisip.. si jason at gerome ang tanungan ko ngayon sa tuning nung auto.. meron pang isang importante, yung taga buyo.. hehehe! si tutoy! parating sinasabi sakin wala daw ako pag hindi ko nai-panalo..
jdm_ae92 is offline
Old 01-22-2013, 07:40 PM
  #82712
BoMag's Avatar
I met some guys during practice for the Phil Masters. Sabi nila, hindi sila gumagamit ng After Run Oil (ARO). Linis lang ng kit then storage na.
After awhile, one of them was having engine problems..... His engine sounded so bad. We asked him to stop and if ok lang buksan para masilip. True enough, kalawang yung bearing and kalas na mga bulitas. Piston and sleeve meron damage...... and this was a Novarossi ROMA that was stored for months w/out ARO and w/out sealing after break in.... SAYANG!
My procedure for ARO.
1. I start the engine on the box. While the engine is at idle, i pull the fuel line from the carb. Let it idle until mamatay. (wag kalimutan i-plug yung fuel line)
2. Start again and most likely it will idle briefly. Keep dong this 3-4 more times until wala na talaga.
3. I remove the air filter assembly/boot being careful no dirt gets inside the carb.
4. Apply ARO then crank the engine on the box for a few seconds para kumalat sa loob ng engine.
5. Seal the engine ( carb filter openning, fuel inlet, and exhaust)
BTW, puro flame out ako ng Phil Masters...TOINK!!!
CONNECTING ROD
One of the most stressed engine part during break in when engine is at its tighest.... VIRGIN at sariwa!
I replace at 2-2.5 glns after break in period then 4-5 glns after.
BoMag is offline
Old 01-22-2013, 07:57 PM
  #82713
tama parang ... lang yan ni berkin
stormtrooper is offline
Old 01-22-2013, 08:26 PM
  #82714
mudguard's Avatar
Default 9 Eagles 3D Solo Pro 100D RC Helicopter
SOLD Practically new in box. Complete set. Tested once. No time to learn or play it. 5.5K only Thanks! SOLD
mudguard is offline
Old 01-22-2013, 08:34 PM
  #82715
Hindi ko napansin pinaguusapan pala ako dito! Capt. gaya nga ng sabi ko kung magkakasunod lang tayo sa grid mas maganda bakbakan..
RRC: Sir sino po sila doon nung sat? Yes nakakaadik itong class na ito.. At dahil doon hindi ko tinitigilan si voodoo, gerome at tutoy sa paghingi ng tips.. beginner lang din ako hindi lang sa class na ito, pati sa track..
HOY! anong "beginner" ka dyan!?!? kung beginner ka, ano nalang tatawag mo samin?!?! hahaha
berkin is offline
Old 01-22-2013, 08:38 PM
  #82716
jdm_ae92's Avatar
parang ano?
berkin: beginner naman tayo lahat.. kaya nga pwede tayo sa super stock..
jdm_ae92 is offline
Old 01-22-2013, 08:43 PM
  #82717
seanski's Avatar
parang ano?
Beginner kayo lahat? Ano na lang kami??? hehehehe Kitakits sa Saturday!
seanski is offline
Old 01-22-2013, 09:44 PM
  #82718
Kabul_RC's Avatar
Still looking for 5000 mah or above hard case Lipos.. Only can do meet ups around makati or paranaque area.. I have cash ready.. The hobby shops here want oo much for Lipos.. Thanks.. Please pm what you got...
Kabul_RC is offline
Old 01-22-2013, 10:22 PM
  #82719
WildThang's Avatar
Good day Sir, buy online... Hobbyking, amain, towerhobbies, it will be cheaper...
WildThang is offline
Old 01-22-2013, 11:10 PM
  #82720
A X O's Avatar
Trader Rating: 51 (100%+)
Ready na ba mga kapatid? Tatlong tulog nalang. Kitakis!
A X O is offline
Old 01-22-2013, 11:31 PM
  #82721
jdm_ae92's Avatar
Para kang multo ah...
jdm_ae92 is offline
Old 01-23-2013, 12:20 AM
  #82722
CONNECTING ROD
Bradir, can you analyze why namamatayan ka which I think is probably the most important part of your post.
GPXJOE is offline
Old 01-23-2013, 12:39 AM
  #82723
Pare great and detailed post,tnx. The only difference for me is I run and restart the engine until no more gas in the tank and fuel line so that its completely dry before I remove the fuel line.same procedure though and I agree with your procedure.
GPXJOE is offline
Old 01-23-2013, 01:07 AM
  #82724
awin's Avatar
Q: sir, paano kung wala nang stock para sa spec tires na pwede sa stock touring? wala na daw kasing stock sa mega/ps. thanks!
awin is offline
Old 01-23-2013, 01:23 AM
  #82725
Default LF: roto start shaft
Hi, im looking for a shaft for the rotostart
Txt me at 09328593261
Trd717 is offline
