Go Back  R/C Tech Forums > International Forums > Manila Racers
The Big Locked Thread >
View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
Like Tree1Likes
Old 12-22-2012, 02:51 AM
  #82081
May lalaro bukas?
Some big photos from Taka.
Attached Thumbnails The Big Locked Thread-img_1111.jpg   The Big Locked Thread-img_1115.jpg   The Big Locked Thread-img_1100.jpg
rccartips is offline
Old 12-22-2012, 04:37 AM
  #82082
shock@yahoo.com's Avatar
Trader Rating: 7 (82%+)
Default LF
LOOKING FOR
AIR FILTER FOR MY KYOSHO V1RR
RB ENGINE
1/10 SCALE
NEED KO PO NG FILTER TNX
09273868095
found na sa v1rr tnx
need ko s fazer ko po mas maliit sa v1rr
tnx rctech
shock@yahoo.com is offline
Old 12-22-2012, 05:28 AM
  #82083
cocojam's Avatar
Trader Rating: 47 (100%+)
Originally Posted by rccartips
May lalaro bukas?
Kami! See you tom.
cocojam is offline
Old 12-22-2012, 05:48 AM
  #82084
Default Rush!
1 Mugen MBX6 Buggy- no elecs Rolling Chassis-10k
1 Mugen MBX6T Truggy -12k no elecs Rolling Chassis
1 Novarossi Plus 4C team edition .21-9k
1 Novarossi Toro Nero Team edition .21-9k
Sanwa m11x 3 receivers (Lipo bat w/box and manual) -12k
Rolling Chassis (Buggy or truggy) - Engine,Tires,Servos, no controller and rec. 25k Negotiable.
Lots of Mugen spare parts.
Batteries and charger.
Special item: Futaba 3PK converted 3.4ghz. w/ lipo,2 receivers,manual. No box. 10k negotiable
Contact numbers :
09173579428(text only)
09188387546(Text and call)
Give your best offers!! No Pm...
TEXT/Call YOUR OFFERS NOW!! Pick up only!! (We can talk it over) New Manila Area!!!
EVERYTHING NEGOTIABLE!!
marco1lim is offline
Old 12-22-2012, 05:58 AM
  #82085
b2k
Originally Posted by b2k
hi guys, i want to sale my losi 8eight parts.
please pm me, if you want to buy.
thanks
Up!
b2k is offline
Old 12-22-2012, 07:56 AM
  #82086
Trader Rating: 40 (100%+)
Christmas Sale!
10% Off on all items listed (except all liquids)
Valid from Dec 9-31, 2012
Flysky GT3C with the new redesigned and improved steering wheel
Available Colors: Silver + Black and Orange + Black
Price: 2600
Rapicon RC Fuel (Car)
25% 1430 per gallon
30% 1570 per gallon
Tornado RC Fuel (Car)
25% 1055 per 2.5L can
30% 1225 per 2.5L can
30% 1860 per gallon
we also sell per box (4 gallons or 6 2.5L cans) with discounts, txt or call for more info
we ship anywhere in the philippines
ITEM: 200cc Fuel Gun
Status: On Stock
Price: 950
ITEM: Turnigy nano-tech A-SPEC 6200mah 2S (7.4v) 65~130C Hardcase (NEW)
Status: On Stock
Price: 3365
ITEM: Turnigy Nanotech 6600mah 2s (7.4v) 65-130C hardcase
Status: On Stock
Price: 3160
ITEM: Turnigy Nanotech 6000mah 2s (7.4v) 65-130C hardcase
Status: out of stock
Price: 2760
ITEM: Turnigy Nanotech 5600mah 2s (7.4v) 50-100C hardcase
Price: 2360
ITEM: Transmitter Radio Wheel (Aluminum)
Status: On Stock
Price: 600
ITEM: Flysky Reciever
Model: FS-GR3C
Channels: 3
Frequency: 2.4Ghz
Compatible with all flysky 2 and 3 channel radios (GT2, GT3 & GT3B)
Status: On Stock
Price: 700
Item: Flysky FS-SM100 USB RC simulator adaptor cable
Status: On Stock
price: 350
Item: Turnigy Accucel 8 150w Balance Charger
Status: On Stock
Price: 3900
Item: 350w Power Supply
Input Voltage: 220~240V AC
Output Voltage: 13.8v DC
Output Amps: 25A
Output Watts: 350W
Status: On Stock
Price: 3700
ITEM: Turnigy Accucel 6 Balance Charger
Status: On Stock
Price: 2000
ITEM: Power Supply 100~240v 5A (for battery chargers)
Status: On Stock
Price: 1000
BM-6 Cell Voltage Monitor 2-6S Lipo (Latest Version) (New Item)
Battery cell range: 2S-6S Lipo/Li-ion/LiFe
Voltage display resolution: 0.001V
Voltage Detection precision: 0.005V
Cell Voltage display range: 1.50-4.99V
Total Voltage display range : 3.00 ~29.94V
Alarm cell voltage: 2.00 ~ 4.00V
Status: On Stock
Price: 985
Item: Infrared Thermometer
Temp range: -33 to 180°C (-27.4 to 356°F)
Accuracy: +/- 2.5%
Status: Out of Stock
Price: 760
Item: Digital Caliper
range: 0-150mm
Accuracy: +/- .02mm
Status: On Stock
Price: 1380
Item: BMS-660DMG+HS Super Strong Digital Servo
torque: 14.2kg/cm @ 6v
speed: 0.17sec/60° @ 6v
status: Out of Stock
price: 1845
Item: BMS-820DMG+HS High Performance Digital Metal Gear (New Item)
Torque: 10.6kg/cm , 142 oz/in @ 6v
Speed: 0.09 sec /60° @6v
Status: On Stock
Price: 2610
ITEM: Turnigy MG959 Alloy Digital Metal Gear Servo (out of stock)
torque: 15kg/cm @ 6v
speed: 0.2sec/60° @ 6v
Price: 1880
Item: Turnigy MG958 Composite Digital Metal Gear Servo (out of stock)
torque: 15kg/cm
speed: 0.2sec/60°
price: 1305
Item: Turnigy 620DMG+HS High Torque Digital Metal Gear
Servo
Torque: 10.6kg/cm
Speed: .13sec/ 60°
Status: On Stock
price: 1510
Item: Turnigy 25mm Flywheel Removal Tool
For engines .21-.32
Status: On Stock
Price: 435
Item: Hard Steel Tweezer either Straight or Curved
Length: Straight 125mm Curved 120mm
Status: Out of Stock for curved
Price: 135 (when ordering, please indicate if you want straight or curved)
X-BLADE Precision knife with replaceable SK-5 blade
Price: 70
Item: Hex driver set 4pcs
Set includes 1.5, 2.0, 2.5 & 3.0
Status: On Stock
Price: 700
ITEM: 4mm long shaft Flat Head Screwdriver (for engine tuning)
Length: 105mm
Number of units: 3
Status: On Stock
Price: 170
Item: Turnigy 4mm XL shaft Flat Head Screwdriver (for engine tuning)
Tip Length: 170mm
Status: On Stock
price: 265
Item: Turnigy 5mm long shaft Flat Head Screwdriver
Tip Lenth: 105mm
Status: On Stock
price: 235
Item: Turnigy Long Shaft Exhaust Spring Tool
Status: On Stock
price: 235
ITEM: TURNIGY 4pcs hex socket driver set
Status: On Stock
Price: 460
ITEM: Knife Edge Reamer 0.5-18mm
Price: 570
Item: Multifunction wheel nut wrench
with 17mm and 23mm hex nut
and 4mm and 5mm hex key
Status: On Stock
price: 470
Item: Turnigy Flywheel Key w/ H17mm Wrench Tool
Status: On Stock
Price: 370
***pictures at http://rccebu.blogspot.com/ ***
Brand new and used RC parts for sale. (ON HAND)
For inquiries, please text or call to 0922-9661909.
ITEM LOCATION: Cebu
ITEM # 3: Slightly used Hobao monster tires with chrome rims 14mm hex (some curb rash and flaking crome on the rims) tread left 90% - P2250
ITEM # 9: Brand new Proline Velocity Rims 14mm hex (set of 2) - P1260
ITEM # 17: Brand new HPI Savage 2 speed transmission (taken from a brand new Savage X 4.6) - P2700
ITEM # 19: Brand new Flux shocks (1 pack contains 2 shocks) – P1885
ITEM # 20: Brand new Savage X, XL Battery Box only – P625
OR choice of having it with charging jack and switch (taken from a brand new savage xl) – P1250
ITEM # 21: Brand new Savage XL Front/Rear Differential assembly with bulk head (taken from a brand new never used Savage XL) – P2365
ITEM # 22: Team Losi XXL Shocks (taken from a brand new Losi XXL) set of 2 - P1520
ITEM # 23: HPI Savage X, XL turn buckles (Brand new) –P650
ITEM # 24: Used Savage 21/25/X roll cage with mounting hardware (nothing broken, just paint scrapes) - P1350
ITEM # 29: Brand new O’Donnell medium hot glow plugs standard purple long plugs for 25% - 30% nitro content (for picco, novarossi, rb concept and more, check manual for compatibity) – P300/piece
ITEM # 31: HPI Savage XL engine plate w/ brace (taken from a brand new savage xl) – P978
ITEM # 32: HPI Savage XL center dogbones (taken from a brand new savage xl) - P1030
OR choice of having it with cups - P1320
ITEM # 33: CEN 23mm hex (taken from a brand new CEN GST 7.7) - P890
ITEM # 34: HPI Savage Flux complete Bulletproof differential assembly with bulk head, bearings & drive cups (brand new) – P3125
ITEM # 35: Venom fuel tubing (OD=6mm ID=3mm) - P55/foot
ITEM # 37: Dynamite Silicone Switch Cover (transparent blue/florescent yellow) 2pcs per pack - P265
ITEM # 39: Mugen MBX6T wing, wing mount & mounting hardware(taken from a brand new kit) – P1520
ITEM # 49: Brand New Proline wabash rims 40 series 23mm hex 2 pcs per pack – P1155
ITEM # 54: Used standard MT size Proline bowtie tires on 14mm hex aluminum rims MT tires #1079 very good condition tread left 90% - P3560
ITEM # 65: HPI savage 17mm hex and lock nuts (set of 4) - P630
ITEM # 67: HPI savage 14mm hex and lock nuts (set of 4) - P350
ITEM # 68: HPI savage xl extended wheel axles (set of 4) – P2115
ITEM # 69: HPI savage xl outer dogbones (set of 4) - P1195
ITEM # 70: Brand new O’Donnell hot glow plugs standard red long plugs for 5% - 20% nitro content (for picco, novarossi, rb concept and more, check manual for compatibity) – P300
ITEM # 73: RPM Center skidplate for savage x – P1215
ITEM # 74: Losi 15mm shock boots for big bores – P640
ITEM # 77: Du-bro 2-56 safety lock kwik link (clevis) - P245
ITEM # 78: Ofna throttle linkage kit blue (part # 10724) - P255
ITEM # 81: HPI savage high body mount post & throttle horn - P365
ITEM # 83: HPI cap head screw 2.6x12mm 12pcs - P310
ITEM # 90: RB Concept Headshims for .28 engine thickness available .10mm & .3mm. Can be used with other .28 size engines (sold per pack) - P285
ITEM # 91: RB Concept exhaust gasket – P480/pack of 4
ITEM # 92: Dynamite Max-life aluminum clutch shoes – P1570
ITEM # 93: Mugen clutch spring 1.0mm - P155
ITEM # 94: Dynamite clutch shim kit - P440
ITEM # 100: Factory Team Shock oil 35wt - 70wt – P240
ITEM # 103: CLUTCH BELL BEARINGS NEOPRENE SEAL 5x10x4 - P800/pack of 10
ITEM # 104: AXLE BEARING NEOPRENE SEAL 8x16x5 – P700/pack of 10
ITEM # 107: CEN Genesis/Nemesis/GST 7.7 Fuel Tank 220cc - P1095
ITEM # 108: HPI Savage Heavy duty servo saver spring - P248
ITEM # 109: RB Concept Aerosol Lubricant - P435
ITEM # 111: Used Nova Cooling Head for Picco .26 - P1750
ITEM # 113: New Speedmind transmitter bag for 3pk - P1766
ITEM # 114: Fail safe – P750
ITEM # 115: Exhaust gasket – P500/pack of 5
ITEM # 116: Exhaust Spring long –240/ pack of 2
ITEM # 117: Antenna tube with silicone end cap (250mm) – P85
ITEM # 119: Bones Speed Cream Bearing Lubricant - P465
ITEM # 121: Integy Rear Hub Carrier for HPI Savage purple/silver (pre-X, X, XL, Flux) – P1830
ITEM # 122: Castle Creations 6.5mm High Current Bullet Connector – P540
ITEM # 123: Brand New Savage XL 3 Speed Transmission - P3875
ITEM # 125: 3Racing Aluminum fuel tank protector for Savage (silver/pruple) – P1045
ITEM # 126: NIB JR Digital High Voltage Servo Z9100HVS - P8775
ITEM # 128: NIB Tekin Brushless Truggy Motor T8 TT2361 4038 - P8540
ITEM # 130: CorrosionX 16 oz Trigger Spray Bottles - P1685 - Protects your expensive electronics, will not trap heat within the components unlike Plasti Dip, much safer and easier to use than ballons. See this video ===> http://www.youtube.com/watch?v=6jpSW50cobs (Now on Stock!!!)
ITEM # 147: HPI Machined Bulletproof Diff Gear Set – P2350
ITEM # 148:Savage x/xl/flux upper and lower arms with pins (pair) – P880
ITEM # 149:Savage x ss adjustable upper arms (set of 4) – P725
ITEM # 151:Savage 25/x/ss/flux center drive shaft – P635
ITEM # 152:NEW HPI Savage X Roll Bar, Handle, Engine Protector – P685
ITEM # 153:Savage X SS Clear Body with complete decals and antenna tube - P2125
ITEM # 154: HPI Savage Battery Level Indicator – P1967
ITEM # 155: Panther Buggy Tires MT998SY Switch on yellow rims 17mm hex (set of 4) - P1885
ITEM # 160: HPI Differential Case Washer 0.7mm (PN 86099) - P240
ITEM # 161: Exhaust manifold spring: 110/ pack of 3
Shipping details:
- Additional shipping charges apply
- Payment must be made through BDO or LBC prior to shipping
- Payment may also be made through PAYPAL (Customer add 3.75% of the total amount to cover the paypal fees)
- Once payment is verified, items will be Shipped through Air21 unless the buyer make other arrangements
- A tracking number will be provided for buyer’s reference
We accept orders for hard to find parts (please call or text for more details)
RCebu is offline
Old 12-22-2012, 09:35 AM
  #82087
Leo V.'s Avatar
going to TQ racetrack later. Vince, kuya Chito kita tayo dun
Leo V. is offline
Old 12-22-2012, 03:01 PM
  #82088
ao97b's Avatar
Take pictures idol. Sori read ur msg late. I was out of the country that time. Pabili kami parts sa tq hehe. Is ur cel in roaming?
ao97b is offline
Old 12-22-2012, 03:37 PM
  #82089
RRRoy23's Avatar
sa Jan. 5 ang next UF1 race. see you there.
RRRoy23 is offline
Old 12-22-2012, 04:17 PM
  #82090
RRRoy23's Avatar
Originally Posted by cocojam
Kami! See you tom.
Sa monday ba to?
RRRoy23 is offline
  #82091
ei roy, kim here, i think i left my pliers on your table.. naiwan ata ni mike last futaba cup
Minami is offline
Old 12-22-2012, 05:35 PM
  #82092
iansantos1975's Avatar
@ Rains, sir, bka pwede makisabay.
Ride 24018 - 2pairs (mini)
PS 0572 - 1pair
PS 0571 - 1pair
Ian santos - 09178427966
iansantos1975 is offline
Old 12-22-2012, 05:36 PM
  #82093
cocojam's Avatar
Sa monday ba to?
Hi Roy! No, today sunday afternoon. JP Raceway is closed on Mondays kasi.
cocojam is offline
Old 12-22-2012, 07:25 PM
  #82094
RRRoy23's Avatar
i do have your plier. i forgot to give it to Ramil. I will give it to him so he can give it to you.
RRRoy23 is offline
Old 12-22-2012, 07:26 PM
  #82095
RRRoy23's Avatar
ok.... try ko punta mamaya. what time kayo maglalaro?
RRRoy23 is offline
