Go Back  R/C Tech Forums > International Forums > Manila Racers
The Big Locked Thread >
View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
Like Tree1Likes
Old 12-05-2012, 06:45 AM
  #81766
VooDooPH's Avatar
Trader Rating: 18 (100%+)
VooDooPH is offline
Old 12-05-2012, 07:26 AM
  #81767
Default fs: TB03D 80% countersteer
Forsale: TB03D 1.8 CS
Hops:
Tamiya FOW
Tamiya COW
Yokomo 1.8 cs gear (modded)
Eagle 8 camber 10 caster hubs
Eagle 55 degree 44mm universals
Alum suspension blocks
Alum rear hub carrer
Alum knuckle arms
Trf dampers
CF front and rear shock towers
Modded 45+ degree steering
Lots of freebies
Free: 2 shells. Asking: 6k negotiable 09175200092
djrixx is offline
Old 12-05-2012, 07:42 AM
  #81768
monanj's Avatar
Default looking for
sensorless bl motor 540 size standard shaft 3mm....
call/text.....09154817559
tnx rc tech!
monanj is offline
Old 12-05-2012, 08:14 AM
  #81769
bentoy101's Avatar
Trader Rating: 74 (99%+)
Originally Posted by skuter-race-ta
akala ko sir may nakuha ka na pang t-maxx parts mo? i think meron din ako pang revo na stock manifold and wheel axle bearing bnew din.....
ayyy sorry di ko nadelete LOL. Deleted napo boss
bentoy101 is offline
Old 12-05-2012, 02:42 PM
  #81770
ta06 pro with upgraded front and rear trf 416 uprights.
All metal suspension pivot balls.
bought sept. 2012
with protective sticker underchassis since day 1.
kit only complete with box and manual.
09272590777
goodvibes is offline
Old 12-05-2012, 02:50 PM
  #81771
Hobbyking X-Car 45A Brushless Car ESC (sensored/sensorles
(picture reference)
Hobbyking X-Car series ESCs offer excellent performance and features. With precise throttle linearity, smooth startup/acceleration, strong brakes and fully adjustable programming options, you will not find a better value in R/C car ESCs on the market today!
Built with high quality components, and offering both sensored and senorless motor operation, this is a truly versatile high performance ESC.
Features:
Enhanced throttle response, precise throttle linearity, excellent acceleration and strong brakes
Programmable with the Hobbyking X-Car programming card to make adjustments. (sold separately)
Automatically detects the number of cells within the battery pack.
Multiple protection features: Low voltage cut-off protection, over-heat protection, throttle signal loss protection and motor blocked protection.
Supports both sensored and sensorless brushless motors.
Compatible with NOVAK, LRP and ORION, ETC. sensored brushless motor.
Built-in cooling fan
Specs:
Continuous Current: 45A
Burst Current: 190A
Resistance: 0.0010ohm
Suitable Car: 1/10, 1/12 on and off road
Battery: 2-3 cells Lipo (5-9 cells NI-xx)
BEC output: 6V/2A switch mode built-in
Motor type: Sensorless and sensored brushless motors
Running mode: Forward only or forward with reverse (user programmable mode)
Dimension: 42 x 28 x 36mm
Weight: 78g
Speed Energy Sensored 13.5t motor
09272590777
Old 12-05-2012, 03:10 PM
  #81772
oro27's Avatar
Trader Rating: 33 (100%+)
LOOKING FOR THE FOLLOWING ITEMS:
Stock Emaxx1 (3906) chassis
Spur Gear For Emaxx1/Tmaxx
Tamiya CVA Oil Shocks For TT-01
PM me your offers or text me @ 09162100627 / 09228450727
oro27 is offline
Old 12-05-2012, 04:52 PM
  #81773
mon
Default LRP short course 550 BL motor
LRP short course 5.5T brushless sensored motor
550 size motor for short course truck
Used 8x only
Php 3,500 or pwede trade sa Personal Transponder
Meet ups along del monte and Banawe area
Contact Richmond
09277170090
Attached Thumbnails The Big Locked Thread-lrp.jpg   The Big Locked Thread-lrp2.jpg
mon is offline
Old 12-05-2012, 06:40 PM
  #81774
killer's Avatar
it's been a while!.. I am looking for LOSI Micro SCT in good working condition (of course hehehe) tanong lang po nasa magkano po ba ang brand new nito? thanks in advance!
killer is offline
Old 12-05-2012, 08:29 PM
  #81775
JohnLloydii's Avatar
JohnLloydii is offline
Old 12-05-2012, 08:41 PM
  #81776
Trader Rating: 27 (97%+)
Almost new TTO1-E full hop ups race ready! 12k Only! Artr na!
Full ballbearings
Universal on all corners
Aluminum center drive shaft
Aluminum outdrive for drive shaft
Aluminum steering arm
Aluminum steering link
Aluminum front hub carrier
Reinforce rear hub 2deg toe in
Aluminum motor mount*
Aluminum hex on all corners
TRF shocks on all corners
TRF springs on all shocks
Hi speed spur gear new 55t
New pinion 25t
New motor silver can
Blue tamiya heatsink
Hi speed hi trq servo
Hi trq tamiya servo saver
Titanium servo linkage
Tamiya blue foam bumper
New tire and rims
Blue lock nuts
New painted body un cut of your choice of skyline,eclipes or integra type r.
NEW lipo 4000mah 40c deans plug
Only needs teu esc and radio gear and off you go
10k (selling for a friend)
FULL OPTION Hot bodies moore-speed *edition
Sorex r36 tires on dish rims*
Free body
7k NOW ONLY 6k fix!
Hsp rockcrawler brand new RTR
2.4ghz remote with reciver
Esc with motor
Hi trq heavy duty servo
Battery and charger
Jeep rubicon body black*
Novak cyclone esc no motor limit
---3,000
2pcs Turnigy lipo nano tech 5.3ah *50-100c hard case ---1,700 each
Futaba BLS-352 servo 1/4 ear cut--- 3,000
Flysky gt3b with reciver used only 3times--- 2,000
Flysky gt3C brandnew with reciver--2800
Lipo buzzer/alarm with volt setting new--500
New *clone TRF shocks all blue all aluminum,with aluminum bottom spring retainer ---1200 (3sets available) tested on tto1 and tao5 ok performance
New unpainted lexan body with light bucket and wing-1000
Levin86
S15
Volks hatchback
Painted and new--1000
Levin86 yellow
Eclipse white/red
Skyline yellow and blue
Honda integra R *black/white
Note: Some scratches on the pre-loved kits but nothing biggie,i can email the picture to you just pm me your email address.*
All items are in cabanatuan city nueva ecija i only do shipping unless im in manila. Buyer shoulder the shipping cost via lbc
mike22 is offline
Old 12-05-2012, 08:42 PM
  #81777
Will be in manila divisoria this saturday so i can do meet up on that day and on futaba cup also thanks
mike22 is offline
Old 12-05-2012, 09:01 PM
  #81778
Looking for a wasp .26 button head
Rc kids is offline
Old 12-05-2012, 11:19 PM
  #81779
champion's Avatar
Trader Rating: 24 (100%+)
Default Sanwa X'mas special M12-16,995 only
Champion hobbies 3766006 3471856 09232802214
Sanwa M12 W/ RX471 -16,995
Sanwa Mx-Sports W/RX371Fs-2,995
Sanwa EXZES-X W/Rx451- 13,995
champion is offline
Old 12-05-2012, 11:49 PM
  #81780
Default FORSALE
selling my tt-01D type E chasis for with: SOLD
rtrtt01 is offline
