Go Back  R/C Tech Forums > International Forums > Manila Racers
The Big Locked Thread >
View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
Like Tree1Likes
Old 10-08-2012, 07:28 PM
  #80431
Originally Posted by rdl77
kaladkarin ka talaga!
@joel: how about tamiya rally block tires? pahirapan din ba yun?
its a disease that im not looking for any cure
stormtrooper is offline
Old 10-08-2012, 07:31 PM
  #80432
VooDooPH's Avatar
Trader Rating: 18 (100%+)
BTW, the rally block tires looks nice... BUT they are very grippy (based on very limited experience from the oldskul race) with or without inserts... so if the objective is to slip and slide a bit... i don't think they're the way to go.
suggestion... medium narrow radials with hard sorex inserts...
VooDooPH is offline
Old 10-08-2012, 07:49 PM
  #80433
Default Looking for...
6v 4200mah NiMH Hump RX Pack
Battery Type: Nickel Metal Hydride (NiMH)
Length: 2.67" (68mm)
Height: 1.8" (46mm)
Width: 1.6" (43mm)
Weight: 12.8 oz (0.36kg)
Plug Type: Tamiya
Capacity: 4200mAh
Cell Configuration: 5-Cell Hump Pack
Voltage: 6V
Amp Rating: 4.2 amps
sana meron kayo.. sms na lang. 09399021507
thanks!
pepesmith is offline
Old 10-08-2012, 08:36 PM
  #80434
Stpaul's Avatar
Trader Rating: 29 (100%+)
Default looking for crawler tires
Looking for flat iron 1.9 crawler tires and wheels or anything with the same specs.
Please pm photos of it and text me your offers at 09278660119.
Paul
Stpaul is offline
Old 10-08-2012, 10:18 PM
  #80435
Game ako !
Basta hindi slicks, pwede na!
Para maumpisahan lang.
Originally Posted by rccartips
Ok! Let me state it here first, for the record. 1) 190mm rally type body, 2) any chassis, 3) any motor/esc/battery. Must be realistic, with interior cockpit (driver, rollbars) and no dish wheels. Realism + rally driving style/level of grip is the objective. Jumps and bumps will determine your ride height, suspension setting, etc. Traction compound definitely not allowed. Technical inspection non-existent, it will be based on circle of trust. Spools not allowed. Must use differentials front and rear.
The speed limiting factor will be the tire grip. I am looking for a spec tire that will give grip in between sorex and drift tires. So that we can still drift/grip around a corner. And with such limited traction, power is not a factor. We will all use same spec tire (long lasting, limited grip, cheap).
Ok ba?
JPRacing is offline
Old 10-08-2012, 10:26 PM
  #80436
Default fs losi micro sct
fs: LOSI micro sct-rush
brushed system
27mhz am tx n rx
item is in davao but willing to ship...buyer pays for shipping
price is 3.8k nego konti
txt me 09173562311
gennomaria is offline
Old 10-08-2012, 10:27 PM
  #80437
Trader Rating: 27 (97%+)
10k (selling for a friend)
FULL OPTION Hot bodies moore-speed *edition
Sorex r36 tires on dish rims*
Free body
*10k (selling for a friend)
Tamiya TRF 416x with
Spec-R gear diff rear
Spool front
Extra chassis smokem
Extra carbonfiber shock tower
Spare 2pcs belt long 1pc belt short
Spare spur gear new*
Motor and pinion
Sorex tires
Box included
*9k
Tamiya RTR TT01 E with hop ups
Oil filled shocks*
Carbonfiber upper deck
Aluminum blue center shaft
Aluminum blue propeller joint
Front universals
Front oneway
Sorex tires*
Futaba am radio with reciver
Esc*
nimh battery with charger
Acoms servo
Sport tuned motor*
58/25 spur pinion
Free protoform body (bashed)
6k*
Tto1 e brand new with audi r8 body*
Extra set of rims
7k
Hsp rockcrawler brand new
2.4ghz remote with reciver
Esc with motor
Jeep rubicon body black*
Novak cyclone esc no motor limit
---3,000
2pcs Turnigy lipo nano tech 5.3ah *50-100c hard case ---1,700 each
Futaba BLS-352 servo 1/4 ear cut--- 3,000
Futaba 3050 metal gear servo digital ---1,500
Flysky gt3b with reciver used only 3times--- 2,000
Tamiya TRF shocks blue---1,200
Note: Some scratches on the pre-loved kits but nothing biggie,i can email the picture to you just pm me your email address.*
All items are in cabanatuan city nueva ecija i only do shipping unless im in manila*
mike22 is offline
Old 10-08-2012, 10:50 PM
  #80438
Default for sale rc crawler
hsp pangolin based
axial ax10 rear diff assembly
gmade bent lower links
gmade hardened steel drive shafts
proline flat irons 2.2
tube body made from 3/16 steel tubing
styrene panels
no electronics
d po kasama ung traxxas na servo
everything else is stock
will include all the spare sparts na andito
item is in davao but willing to ship, buyer pays for shipping fee
price is 5k
txt me 09173562311
rfs may coming na crawlers
sold!!!
Attached Thumbnails The Big Locked Thread-imageeni.jpg   The Big Locked Thread-imagegiw.jpg   The Big Locked Thread-imagejof.jpg   The Big Locked Thread-imageujv.jpg
Old 10-08-2012, 11:10 PM
  #80439
mix237's Avatar
Almost CompleteTamiya Tundra Bodyset (see other pics below)-P3,750.00
Axial SCX-10 Front and rear axles - P3,500.00
Axial SCX-10 Tranny - P1,800.00
Axial AE-1 ESC - Forward/Reverse P1,000.00
Atlas 50T Rock Climber Motor - P800.00
PM or Contact me: Noel 0917-8916422 or 0922-8916422
Please mention your rctech username when sending me a text.
Thanks.
Attached Thumbnails The Big Locked Thread-tundrap_zps13ebea76.jpg   The Big Locked Thread-dscn6212_zps96f168a9.jpg
mix237 is offline
Old 10-08-2012, 11:22 PM
  #80440
reichsmarshal24's Avatar
So I guess it will be a spec tire to ensure the same amount of grip levels for all. Do we need to heavily modify an existing kit to make give it the rally style ride height and handling?
reichsmarshal24 is offline
Old 10-08-2012, 11:37 PM
  #80441
Default revo 2.5r
Originally Posted by aizycool0611
RTR traxxas REVO 2.5R
naka display lang
few scratch lang po sa ilalim (isang beses lang nilaro sa lupa)
fs gt3b gud as new rx tx (already installed)
1 gal 25% rapikon nitro fuel
cainta area
14K
Almost new imax b6
w/power supply adaptor box,manual,cables
1800
RFS: MTB na
up ko lang
aizycool0611 is offline
Old 10-08-2012, 11:45 PM
  #80442
wingdingspro's Avatar
Default FS
selling my extra rc stuff, all Brandnew:
1unit futaba rx (4pks) fasst R614FS HV high voltage = 4,000.
1unit futaba brushless servo BLS252 = 3,500.
1unit futaba brushless servo BLS253 = 3,500.
1unit futaba digital servo S9551 low profile servo = 3,000.
all brandnew, original packaging case.
fix prices, no swap, items for pick up only house san juan city.
call/txt alvin 0917 527 3595 or 359 1689.
thank you RcTech.
wingdingspro is offline
Old 10-08-2012, 11:52 PM
  #80443
VooDooPH's Avatar
B-B-B
buy it... build it... bash it.
VooDooPH is offline
Old 10-08-2012, 11:56 PM
  #80444
JohnLloydii's Avatar
Default rc stuffs for sale! las pinas area
esc:
TEKIN RS PRO ESC for brushed/brushless and sensored/sensorless motor w/ box(deans plug ready)- 6K
team losi waterproof esc for brushed motor - 800
bl combo:
speed passion cirtix d-manager 2.0 4000kv bl combo w/ program card - 4k
kit:
NANDA BD8E 1/8 BUGGY KIT W/ PROLINE TIRES - 4K
lipo batt:
2 PCS. 7.4V LIPO BATT 5000MAH xt60 plug(slightly bloated lang yung isa)- 800 each
7.4V LIPO BATT 5200MAH EXCEED POWER lipo plug(not bloated) - 1K
2 PCS. 7.4v intellect 6800mah roar approved(xt60 plug) - 3k each
RTR short course:
Hobao hyper 10sc 1/10 scale kit
w/ ezrun 4000kv and sc8 120amps bl combo, futaba bls451 brushless digital servo, 1pc 7.4v intellect 6800mah lipo batt "roar approved"
-makinis pa yung kit at good cond pa motor sobrang lakas
16k only for all. tx rx na lang need.
For pics pa search nalang po ng mga post ko hehe, yung hobao hyper 10sc pics upon request
0915 933 4 zero 65
sm southmall las pinas area only ang meet ups thanks rctech
JohnLloydii is offline
Old 10-09-2012, 12:12 AM
  #80445
octopus prime's Avatar
Trader Rating: 17 (100%+)
Voodoo dagdagan mo pa, gawin mong 5 Bs
... break it... buy again!
octopus prime is offline
