Go Back  R/C Tech Forums > International Forums > Manila Racers
The Big Locked Thread >
View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
Like Tree1Likes
Old 08-26-2012, 10:32 PM
  #79531
Trader Rating: 29 (100%+)
Default AX10
LOOKING for
AX10 STEERING KNUCKLE ARM (HIGH CLEARANCE) USED or BRAND NEW.
PM na lang po.
thanks
aramacir is offline
Old 08-26-2012, 11:01 PM
  #79532
enan_08's Avatar
Default FOR SALE OR SWAP
FOR SALE
Tamiya TBO3-IFS with Manual 4K
Rolling Kit includes
- Alum dumpers
- Alum rear body post Extension
- XSA chrome lip red center with 60% driftech tires
- Full Ballbearings
- Ball Diff Front & Lock Rear Ball Diff ( with mods on lock diff )
- Bashed Honda Acura & Subaru Shell ( DIY Decals )
- Alloy Wheel Nuts
Tamiya Nissan Skyline GT-R34 Shell
( F/R Light Buckets, Stock Wing & Side Mirror ) 1.3K
Generic Nissan Sylvia S15 Shell
( F/R Light Buckets, Rear Wing, Side Mirror, Never Been Use) 1.3K
Yokomo Wing with Mount 300 only
RFS: Upgrade Kit
Contact Number:
Sun: 0923-5644050 ( NEW NUMBER )
Look for nan
Meetups can be scheduled.
and please indicate your name, username and location
Just PM if questions only
Still Available
Thanks RCTECH
enan_08 is offline
Old 08-26-2012, 11:03 PM
  #79533
marvs091873's Avatar
Trader Rating: 3 (80%+)
Originally Posted by marvs091873
Package sale only.
5K Only
- Fast Tire Touring
- Tamiya Radial Tires with 5 Spokes White Rims
- Tamiya RC2400SP Zapped NiCd
- Futaba MC231CR ESC
- Tamiya Super Stock Motor
- Tamiya Lightly Tuned Motor
- Peak Power Lipo Battery Case with Cables
- Motor Heat Zinc
- TRF415 Belt Drive Set
- TRF 416 Battery Strap
- Sweep X3 Tire formula
- Pinion Gear 20T, 22T, 25T, 38T, 39T
- TRF Damper O-ring
- Futaba S3001 Standard Servo
- Futaba S3050 Digital Servo
- TA04 Gear Diff.
- Turn Buckles Set
- LED Stopper
- Damper Spacer/Link/Small Parts
Call or text for faster transaction 0932-8511677
Thanks RCTECH.
Repriced..... 4K only
marvs091873 is offline
Old 08-27-2012, 01:20 AM
  #79534
Trader Rating: 14 (100%+)
FS Yokomo BD5WX
fresh rolling kit
Chassis run only once
Newly rebuilt
New bearings
Perfect racing condition
Super Stock podium finisher
Will include 2 sets of bashed tires
RFS spare car, have 2 other BD5's
15k
FS Orca Vritra Pro Spec mark II SOLD
Used only at Thailand International Touring Car Championships
With high speed Orca cooling fan
With Orca hi power 4 pc capacitor
With unopened Program card
With box and manuals
RFS spare ESC
mikeygar is offline
Old 08-27-2012, 02:16 AM
  #79535
Default LF center pulley
LF: 16t ta05 center pulley tamiya#51213 khit 2ndhand ok lng bsta good condition atska 22t center pulley na same itsura dun sa 16t.. 1pc each lng..
pa pm or tx nalng po 0922 887 8475.. kng meron kyo at pa include nalng price mas okkng sa isang tao lng nag benta para ma isa ung shipping.. tnx
RNK911 is offline
Old 08-27-2012, 03:09 AM
  #79536
LowBallertype's Avatar
Originally Posted by LowBallertype
FOR SALE!!!
PACKAGE ONLY
-KDS-7xII Radio with 8ch reciever
-4pcs KDS 9g digital servo
-KDS 820 gyro
-KDS BL ESC 40a
-KDS BL motor 3500KV
-KDS LIPO 11.1v 2200mah 20c
-KDS Balance charger (KDS-3S)
-With manuals yung ibang parts
-All electronics working well
PHP 6.5k
lahat yan galing sa kds 450qs heli.(pwede din kasama heli kaso sira yung main rotor housing)
PHP7.5k pag kasama yung heli kit.
09156541981
REPRICED TO 5K kasama na yung defective heli kit.(replace nlng yun
LowBallertype is offline
Old 08-27-2012, 03:30 AM
  #79537
im looking a short course truck kit, (nitro) pm me. thanks 09161651562
clinton is offline
Old 08-27-2012, 04:29 AM
  #79538
jether's Avatar
Default ...
jether is offline
Old 08-27-2012, 05:06 AM
  #79539
koyski's Avatar
mga bro, baka may extra kayo djan or a new set. i need this for my wraith. thanks
koyski is offline
Old 08-27-2012, 06:48 AM
  #79540
noobierc's Avatar
Default DIRT TUNED MOTOR
FS : TAMIYA DIRT TUNED MOTOR
Almost New pa
hindi masyado gamit
Php. 900.00 (fixed)
meet up Manila Area lang po
RFS : upgraded to bl
TXT : 09152175662
Attached Thumbnails The Big Locked Thread-20120827_001.jpg   The Big Locked Thread-20120827_002.jpg   The Big Locked Thread-20120827_003.jpg   The Big Locked Thread-20120827_004.jpg
noobierc is offline
Old 08-27-2012, 07:39 AM
  #79541
Default axial wraith, sc10, 2.2 tires
fs: good condition sc10 readylift rtr, with scratches on body and under chassis form normal use...with box and manual.
P7k for rtr...5k for kit only
meet ups can be scheduled in qc area for serious buyers, or for pick up in pampanga.
some info:
This is the electric powered, radio controlled, 1/10 scale, ready to run
SC10 Short Course Race Truck with the Ready Lift Body Trim from Associated.
FEATURES: Chassis: Molded composite low CG design with side nerf bars,
hinged battery hold down strap fits NiMH and LiPo battery packs
Drive: Rear wheel with steel rear dogbone drive shafts
Motor: Associated Reedy Radon 17 turn
Radio: Associated XP2 2-channel pistol grip with metal gear steering
servo, transmitter does not have charge jack
ESC: Associated XP SC200 forward/reverse with LiPo low voltage cut-
off and reverse lockout
Shocks: Oil-filled with blue aluminum bodies
Body: 0.040" (1mm) thick painted and trimmed with Ready Lift trim
Differential: Sealed, planetary gear
Spur Gear: 87 tooth
Slipper Clutch: Dual sided, externally adjustable
Wheels: KMC style, 3" (76mm) diameter, 1.6" (41mm) wide, black in
color
Tires: Multi terrain scale with reinforced sidewalls, 4.25" (108mm)
diameter, 1.7" (43mm) wide
fs: 2.2 tires...losi rock claws and axial rock lizards. both in very good condition.
P 1k per set(4pcs) ( free shipping )
***axial wraith rolling kit(rtr version), no electronics. With box and manual only. Everything is stock aside frome some screws which i changed to stainless... 1 month old only and very minimal scratches. Bought brand new... Rfs: change project. meet ups in qc area for serious buyers.... P10.5k
0927-9228656
please include your name when texting
ody120 is offline
Old 08-27-2012, 07:54 AM
  #79542
pointforward's Avatar
Default Looking for Kyosho MP9 TKI3
Looking to buy:
KYOSHO MP9 TKI3, Complete kit. Brand new or used. PM me.
pointforward is offline
Old 08-27-2012, 07:57 AM
  #79543
shock@yahoo.com's Avatar
Trader Rating: 7 (82%+)
Default FOR SALES
kol 09273868095
Attached Thumbnails The Big Locked Thread-dsc08111.jpg   The Big Locked Thread-dsc08109.jpg   The Big Locked Thread-dsc08116.jpg   The Big Locked Thread-dsc08124.jpg   The Big Locked Thread-dsc08118.jpg
shock@yahoo.com is offline
Old 08-27-2012, 08:04 AM
  #79544
Default FOR SALES
09273868095
Attached Thumbnails The Big Locked Thread-dsc08106.jpg   The Big Locked Thread-dsc08112.jpg   The Big Locked Thread-dsc08117.jpg
Old 08-27-2012, 08:08 AM
  #79545
LF: Tamiya TEU 104 or 105 ESC. Thanks!
leonv is offline
