Go Back  R/C Tech Forums > International Forums > Manila Racers
The Big Locked Thread >
View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
Like Tree1Likes
Old 02-06-2012, 08:33 AM
  #74431
shock@yahoo.com's Avatar
Trader Rating: 7 (82%+)
Default FOR SALE
FOR SALE
DAGGER PHP 1.5K
BRUCELEE PHP 25K
09273868095
Attached Thumbnails The Big Locked Thread-dagger.jpg   The Big Locked Thread-dsc05068.jpg
shock@yahoo.com is offline
Old 02-06-2012, 09:21 AM
  #74432
molislithcentos's Avatar
Thumbs up RC CEBU FOR SALE THREAD
PARA HINDE NA AKO MAHIRAPAN SA PAG POST NE RC CEBU NG HALOS ISANG PEYGE
All Fuel are Repriced, now more affordable!
Rapicon RC Fuel (Car)
25% 1430 per gallon
30% 1570 per gallon
Tornado RC Fuel (Car)
25% 1055 per 2.5L can
30% 1225 per 2.5L can
30% 1880 per gallon
we also sell per box (4 gallons or 6 2.5L cans) with discounts, txt or call for more info
we ship anywhere in the philippines
Item: ProTek R/C LiFe 4PK/S Car Transmitter Battery Pack (6.6V/2100mAh)
Voltage: 6.6V
Capacity: 2100mah
Chemistry: LiFePO4
Balance Charge Plug: XH
Charge Rate: 1C
Discharge Plug: JR/Futaba
Dimension (LxWxH): 76x41x17mm
Weight: 105g
Status: On Stock
Price: 2000
ITEM: Flysky GT3B
Status: On Stock
Price: 2400
ITEM: Flysky Reciever
Model: FS-GR3C
Channels: 3
Frequency: 2.4Ghz
Compatible with all flysky 2 and 3 channel radios (GT2, GT3 & GT3B)
Status: On Stock
Price: 700
Item: Flysky FS-SM100 USB RC simulator adaptor cable
Status: On Stock
price: 350
Item: Turnigy Accucel 8 150w Balance Charger
Status: On Stock
Price: 3900
Item: 350w Power Supply
Input Voltage: 220~240V AC
Output Voltage: 13.8v DC
Output Amps: 25A
Output Watts: 350W
Status: On Stock
Price: 3700
ITEM: Turnigy Accucel 6 Balance Charger
Status: On Stock
Price: 2000
ITEM: Power Supply 100~240v 5A (for battery chargers)
Status: On Stock
Price: 1000
BM-6 Cell Voltage Monitor 2-6S Lipo (Latest Version) (New Item)
Battery cell range: 2S-6S Lipo/Li-ion/LiFe
Voltage display resolution: 0.001V
Voltage Detection precision: 0.005V
Cell Voltage display range: 1.50-4.99V
Total Voltage display range : 3.00 ~29.94V
Alarm cell voltage: 2.00 ~ 4.00V
Status: On Stock
Price: 985
Hobbyking Cell Meter 8 - Lipoly Battery Checker
This indispensible tool gives you the following information in a logical and easy to follow pattern with a simple push of a button.
Screen 1 - Cell count, total voltage, remaining capacity.
Screen 2 - Number of cells in series, cell balance guage and cell voltage differential.
Screen 3 - Highest cell voltage and lowest cell voltage + voltage differential.
battery cell range: 2-8S Lipo/Li-ion/LiFe
Status: On Stock
Price: 1370
Item: Digital Caliper
range: 0-150mm
Accuracy: +/- .02mm
Status: On Stock
Price: 1380
Item: Turnigy Laser Guided Thermometer
Measuring Range : -60 to 550°C (-76 to 1022°F)
Operating Range : 0 to 50°C (32 to 122°F)
Accuracy : Tobj = 0~550°c: +/- 2% or reading or 2°C (4°F) Whichever is greater
Emissivity Range : default 0.95 Adjustable 0.1 to 1 step .01
Power Supply : 2 x AAA (Included)
Status: On Stock
Price: 1650
Item: BMS-660DMG+HS Super Strong Digital Servo (New Item)
torque: 14.2kg/cm @ 6v
speed: 0.17sec/60° @ 6v
status: On Stock
price: 1845
Item: BMS-820DMG+HS High Performance Digital Metal Gear (New Item)
Torque: 10.6kg/cm , 142 oz/in @ 6v
Speed: 0.09 sec /60° @6v
Status: On Stock
Price: 2610
ITEM: Turnigy MG959 Alloy Digital Metal Gear Servo
torque: 15kg/cm @ 6v
speed: 0.2sec/60° @ 6v
Status: On Stock
Price: 1880
Item: Turnigy MG958 Composite Digital Metal Gear Servo
torque: 15kg/cm
speed: 0.2sec/60°
Status: On Stock
price: 1305
Item: Turnigy 620DMG+HS High Torque Digital Metal Gear
Servo
Torque: 10.6kg/cm
Speed: .13sec/ 60°
Status: On Stock
price: 1510
Item: Turnigy 25mm Flywheel Removal Tool (New Item)
For engines .21-.32
Status: On Stock
Price: 435
Item: Hard Steel Tweezer Set (New Item)
Length: Straight 125mm Curved 120mm
Status: On Stock
Price: 135 (when ordering, please indicate if you want straight or curved)
X-BLADE Precision knife with replaceable SK-5 blade
Status: On Stock
Price: 70
Item: Hex driver set 4pcs
Set includes 1.5, 2.0, 2.5 & 3.0
Status: On Stock
Price: 700
ITEM: 4mm long shaft Flat Head Screwdriver (for engine tuning)
Length: 105mm
Number of units: 3
Status: On Stock
Price: 170
Item: Turnigy 4mm XL shaft Flat Head Screwdriver (for engine tuning)
Tip Length: 170mm
Status: On Stock
price: 265
Item: Turnigy 5mm long shaft Flat Head Screwdriver
Tip Lenth: 105mm
Status: On Stock
price: 235
Item: Turnigy Long Shaft Exhaust Spring Tool
Status: On Stock
price: 235
ITEM: TURNIGY 4pcs hex socket driver set
Status: On Stock
Price: 460
ITEM: Knife Edge Reamer 0.5-18mm
Status: On Stock
Price: 570
Item: Multifunction wheel nut wrench
with 17mm and 23mm hex nut
and 4mm and 5mm hex key
Status: On Stock
price: 470
Item: Turnigy Flywheel Key w/ H17mm Wrench Tool
Status: On Stock
Price: 370
***pictures at http://rccebu.blogspot.com/ ***
Brand new and used RC parts for sale. (ON HAND)
For inquiries, please text or call to 0922-9661909.
ITEM LOCATION: Cebu
ITEM # 3: Slightly used Hobao monster tires with chrome rims 14mm hex (some curb rash and flaking crome on the rims) tread left 90% - P2250
ITEM # 8: Used 40 series proline crimefighter tires with velocity rims 23mm hex. tread left 85% - P2525
ITEM # 9: Brand new Proline Velocity Rims 14mm hex (set of 2) - P1260
ITEM # 10: Brand new HPI Savage Reverse Module -P2730
ITEM # 11: New HPI Savage XL TVP (Taken from a brand new never used Savage XL) - P2400
ITEM # 12: New HPI Savage XL conversion kit plus front drive shaft and engine mount w/ brace – (taken from a brand new never used Savage XL) - P4100
ITEM # 13: Brand new Team TCS 5mm thick Black Flux TVP - P2300
note regarding item 13:
- these tvp are a good upgrade to the stock tvp, they are so much stronger and looks better than the stock tvp, and they look so much better than the stock!
- http://www.tcscrawlers.com/TCS-5mm-C...d-p-17758.html
- http://www.youtube.com/watch?v=G5vILOPVX54
ITEM # 16: Brand new HPI Roto Start 2 with shaft (xl length) - P2750
ITEM # 17: Brand new HPI Savage 2 speed transmission (taken from a brand new Savage X 4.6) - P2700
ITEM # 18: Brand new 23mm Hex set (colors available white) - P950
ITEM # 19: Brand new Flux shocks (1 pack contains 2 shocks) – P1885
ITEM # 20: Brand new Savage X, XL Battery Box only – P625
OR choice of having it with charging jack and switch (taken from a brand new savage xl) – P1250
ITEM # 21: Brand new Savage XL Front/Rear Differential assembly with bulk head (taken from a brand new never used Savage XL) – P2365
ITEM # 22: Team Losi XXL Shocks (taken from a brand new Losi XXL) set of 2 - P1520
ITEM # 23: HPI Savage X, XL turn buckles (Brand new) –P650
ITEM # 24: Used Savage 21/25/X roll cage with mounting hardware (nothing broken, just paint scrapes) - P1350
ITEM # 29: Brand new O’Donnell medium hot glow plugs standard purple long plugs for 25% - 30% nitro content (for picco, novarossi, rb concept and more, check manual for compatibity) – P300/piece
ITEM # 31: HPI Savage XL engine plate w/ brace (taken from a brand new savage xl) – P978
ITEM # 32: HPI Savage XL center dogbones (taken from a brand new savage xl) - P1030
OR choice of having it with cups - P1320
ITEM # 33: CEN 23mm hex (taken from a brand new CEN GST 7.7) - P890
ITEM # 34: HPI Savage Flux complete Bulletproof differential assembly with bulk head, bearings & drive cups (brand new) – P3125
ITEM # 35: Venom fuel tubing (OD=6mm ID=3mm) - P55/foot
ITEM # 36: OFNA throttle linkage kit blue (part # 10724) - P690
ITEM # 37: Dynamite Silicone Switch Cover (transparent blue/florescent yellow) 2pcs per pack - P265
ITEM # 39: Mugen MBX6T wing, wing mount & mounting hardware(taken from a brand new kit) – P1520
ITEM # 41: Dubro Body Clip retainer w/ 8 body clips - P452
ITEM # 49: Brand New Proline wabash rims 40 series 23mm hex 2 pcs per pack – P1155
ITEM # 54: Used standard MT size Proline bowtie tires on 14mm hex aluminum rims MT tires #1079 very good condition tread left 90% - P3560
ITEM # 60: GRP TRC 1:8 buggy Cubic tires w/ rims buggy tires tread left 95% - P1635
ITEM # 65: HPI savage 17mm hex and lock nuts (set of 4) - P630
ITEM # 67: HPI savage 14mm hex and lock nuts (set of 4) - P350
ITEM # 68: HPI savage xl extended wheel axles (set of 4) – P2115
ITEM # 69: HPI savage xl outer dogbones (set of 4) - P1195
ITEM # 70: Brand new O’Donnell hot glow plugs standard red long plugs for 5% - 20% nitro content (for picco, novarossi, rb concept and more, check manual for compatibity) – P300
ITEM # 73: RPM Center skidplate for savage x – P1215
ITEM # 74: Losi 15mm shock boots for big bores – P640
ITEM # 75: Dynamite Fuel filter – P512
ITEM # 76: HPI Slipper Clutch Pad – P537
ITEM # 77: Du-bro 2-56 safety lock kwik link (clevis) - P245
ITEM # 78: Ofna throttle linkage kit blue (part # 10724) - P255
ITEM # 80: HPI savage x engine protector - P365
ITEM # 81: HPI savage high body mount post & throttle horn - P365
ITEM # 83: HPI cap head screw 2.6x12mm 12pcs - P310
ITEM # 86: RB Concept TM728 standard combustion chamber
ITEM # 87: RB Concept one way bearing
ITEM # 89: Duratrax rotostart backplate - P995
ITEM # 90: RB Concept Headshims for .28 engine thickness available .10mm & .3mm. Can be used with other .28 size engines (sold per pack) - P285
ITEM # 91: RB Concept exhaust gasket – P480/pack of 4
ITEM # 92: Dynamite Max-life aluminum clutch shoes – P1570
ITEM # 93: Mugen clutch spring 1.0mm - P155
ITEM # 94: Dynamite clutch shim kit - P440
ITEM # 100: Factory Team Shock oil 35wt - 70wt – P240
ITEM # 103: CLUTCH BELL BEARINGS NEOPRENE SEAL 5x10x4 - P800/pack of 10
ITEM # 104: AXLE BEARING NEOPRENE SEAL 8x16x5 – P700/pack of 10
ITEM # 105: HPI Rotostart Starting shaft- P700
ITEM # 106: Losi tire glue standard - P570
ITEM # 107: CEN Genesis/Nemesis/GST 7.7 Fuel Tank 220cc - P1095
ITEM # 108: HPI Savage Heavy duty servo saver spring - P248
ITEM # 109: RB Concept Aerosol Lubricant - P435
ITEM # 111: Used Nova Cooling Head for Picco .26 - P1750
ITEM # 113: New Speedmind transmitter bag for 3pk - P1766
ITEM # 114: Fail safe – P750
ITEM # 115: Exhaust gasket – P500/pack of 5
ITEM # 116: Exhaust Spring long –240/ pack of 2
ITEM # 117: Antenna tube with silicone end cap (250mm) – P85
ITEM # 119: Bones Speed Cream Bearing Lubricant - P465
ITEM # 120: : Integy Heavy Duty Rear Hub Carrier for HPI Savage purple/silver (pre-X, X, XL, Flux) - P2370
ITEM # 121: Integy Rear Hub Carrier for HPI Savage purple/silver (pre-X, X, XL, Flux) – P1830
ITEM # 122: Castle Creations 6.5mm High Current Bullet Connector – P540
ITEM # 123: Brand New Savage XL 3 Speed Transmission - P3875
ITEM # 124: Slightly Used Proline Big Joe Tires on 14mm hex – P3160
ITEM # 125: 3Racing Aluminum fuel tank protector for Savage (silver/pruple) – P1045
ITEM # 126: NIB JR Digital High Voltage Servo Z9100HVS - P8775
ITEM # 128: NIB Tekin Brushless Truggy Motor T8 TT2361 4038 - P8540
ITEM # 130: CorrosionX 16 oz Trigger Spray Bottles - P1685 - Protects your expensive electronics, will not trap heat within the components unlike Plasti Dip, much safer and easier to use than ballons. See this video ===> http://www.youtube.com/watch?v=6jpSW50cobs
ITEM # 143: Used Losi XTT truggy tires w/ Losi dish rims 17mm hex. 75% tread – P1260
ITEM # 144: Used Proline 40 series Crime Fighter Tires w/ proline dish rims 23mm hex. 80% tread – P2315
ITEM # 147: HPI Machined Bulletproof Diff Gear Set – P2350
ITEM # 148:Savage x/xl/flux upper and lower arms with pins (pair) – P880
ITEM # 149:Savage x ss adjustable upper arms (set of 4) – P725
ITEM # 151:Savage 25/x/ss/flux center drive shaft – P635
ITEM # 152:NEW HPI Savage X Roll Bar, Handle, Engine Protector – P685
ITEM # 153:Savage X SS Clear Body with complete decals and antenna tube - P2125
ITEM # 154: HPI Savage Battery Level Indicator – P1967
ITEM # 155: Panther Buggy Tires MT998SY Switch on yellow rims 17mm hex (set of 4) - P1885
ITEM # 158: HPI Exhaust Coupling 12x18x30mm (PN 87040) – P389
ITEM # 159: HPI Slipper Clutch pad (PN 72131) – P340
ITEM # 160: HPI Differential Case Washer 0.7mm (PN 86099) - P240
ITEM # 161: Exhaust manifold spring: 110/ pack of 3
Shipping details:
- Additional shipping charges apply
- Payment must be made through BDO prior to shipping
- Payment may also be made through PAYPAL (Customer add 3.6% of the total amount to cover the paypal fees)
- Once payment is verified, items will be Shipped through Air21 unless the buyer make other arrangements
- A tracking number will be provided for buyer’s reference
We accept orders for hard to find parts (please call or text for more details)
THANX RCTECH !!!
molislithcentos is offline
Old 02-06-2012, 09:43 AM
  #74433
mjp
good day im looking for lipo/nimh/nicd balance charger my budget is max 2k pls pm me your offers manila/makati area. thanks and godbless
mjp is offline
Old 02-06-2012, 12:06 PM
  #74434
pitshop's Avatar
Trader Rating: 56 (98%+)
2nd HAND GOODIES AND CONSIGNED ITEMS SALE!!!!!!!
FEBRUARY 7 EDITION
ASSOCIATED RC12 NEW!ASSEMBLED ONLY WITH ESC/BODY P12,000
ASSOCIATED SC10 4x4 FRESH! KIT ONLY P8,000
NEW PROLINE MONSTER TRUCK TIRES P1,500 PER SET of 4 - tires only
NEW SERPENT 811 COBRA BUGGY opened kit but not assembled P17,000
KYOSHO SCR SHORT COURSE TRUCK FRESH!! KIT ONLY P6,000
TRAXXAS PLATINUM SLASH 4x4 WITH ORIGINAL ESC/MOTOR LOTS OF NEW PARTS INCLUDED P12,000
TRAXXAS SUMMIT WITH NEW MOTOR (BRUSHED) P22,000
HYPERION SINGLE AC/DC CHARGER P4,000
NOVAK BALLISTIC 13.5 MOTOR ONCE USED P2,500
LRP SXX VER 2 ONCE USED P7,000
MORE TO FOLLOW!!!
pitshop is offline
Old 02-06-2012, 06:11 PM
  #74435
Default semi truck
How I wanted to join Problem is I don't have semi truck..clod or bigfoot meron
ahfrend is offline
Old 02-06-2012, 06:15 PM
  #74436
Dongskie's Avatar
Trader Rating: 44 (100%+)
Default SALE: eRC B-25 Plug and Fly Used
SOLD to ROBERTO & SAX
Dongskie is offline
Old 02-06-2012, 06:43 PM
  #74437
eight's Avatar
Trader Rating: 27 (100%+)
proline gladiator tires 90% threadlife mounted on 2.2" wheels fits on AE b4/t4 (not hex type)
600php
proline bowtie tires for rear and proline blade (bearing type) for front tires 80% threadlife mounted on 2.2"wheels (not hex type)
good for stadium trucks and buggy.
package at 800php
proline crime fighter 17mm hex type rims 95% threadlife perfect for truggies and monster trucks
1700php
hobby king gt2 2.4ghz radio
includes 2 reciever.
bnew condition.
-1600php-
can meet anywhere in NCR for sure buyer.
SMS or call 0946-4188788 now
eight is offline
Old 02-06-2012, 08:06 PM
  #74438
bentoy101's Avatar
Trader Rating: 74 (99%+)
Default For sale!
MOVED!
bentoy101 is offline
Old 02-06-2012, 10:57 PM
  #74439
team mugen's Avatar
5 days togo and lets get it Onnnnnnnnnnn!!!!! Prepare your Truggy and Buggy and Race till you droppppppppp.......on Feb 12,2012 at JUNKYARD RACETRACK
team mugen is offline
Old 02-06-2012, 11:50 PM
  #74440
Registered User
Default Hobbies R' Us - Southern Philippines Fastest Growing Hobbyshop
Hobbies R' Us
c/o Cebu Lucky Machinery, Inc.
ML Quezon Street, Casuntingan
Mandaue City 6014, Cebu
0922-8964777 | 0917-3244252
Eric Galvin Go
hobbiesrus @ PRCD
hobbiesrus @ Facebook
ericgo @ Istorya.net
Shipping nationwide through LBC.
Accepted payment method: Paypal (fee charge to buyer), BPI, BDO, Metrobank, Chinabank, LBC.
hobbiesrus is offline
Old 02-06-2012, 11:52 PM
  #74441
Registered User
reserve area for products listings.
Old 02-06-2012, 11:59 PM
  #74442
Registered User
reserve area for product listings. thanks.
Old 02-07-2012, 12:11 AM
  #74443
VooDooPH's Avatar
Trader Rating: 18 (100%+)
there's a buy and sell thread already... no need to add your own thread to advertise your products.
please refer to the posting guidelines (espeically #6)
http://www.rctech.net/forum/2811541-post6.html
VooDooPH is offline
Old 02-07-2012, 03:55 AM
  #74444
Voodoo ang problema wala na ata moderators
rccartips is offline
Old 02-07-2012, 04:21 AM
  #74445
Registered User
Tamiya Original Version Clod Buster - 4,000.00
Tamiya Original Version Blackfoot - 4,500.00
Tamiya Wild Willy Original First Release Version - 4,000 SOLDOUT
Team Vintage Associated RC10 - 5,000
Kyosho Vintage Shadow - 5,000
Laser Zx - 4,000
Pictures to be posted soon. Contact:
Eric Galvin Go
0922-8964777
Cebu City
