Go Back  R/C Tech Forums > International Forums > Manila Racers
The Big Locked Thread >
View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
Like Tree1Likes
Old 05-30-2011, 11:14 PM
  #66961
etivac13's Avatar
Trader Rating: 10 (92%+)
Default for sale or trade
etivac13 is offline
Old 05-30-2011, 11:33 PM
  #66962
Konrad's Avatar
Default For Sale HPI Savage
SOLD - Thanks RCTECH!
with
SH .28 Engine (w/o air filter yung foam)
Traxxas TQ Radio
Proline Crime Fighter (used for display only)
Unpainted body
Igniter
12K only
RFS: no time to play. bawas kalat na rin.
Txt me @ 0918 930 9956 or 0919 835 4266
Attached Thumbnails The Big Locked Thread-100_0656.jpg   The Big Locked Thread-100_0654.jpg   The Big Locked Thread-100_0649.jpg   The Big Locked Thread-100_0647.jpg   The Big Locked Thread-100_0655.jpg
Konrad is offline
Old 05-30-2011, 11:51 PM
  #66963
Night Thrasher's Avatar
1. NIB Blue Head OS .28XZ Engine w/ OS P8 GP - Php 12,000 (Will give the OS T-2060SC Pipe for free)
2. Used OS Speed T-2060SC Pipe - Php 3,000
3. Brand New w/ Manual (No Box) Futaba 3PM 2.4Ghz with R603FS Receiver - Php 7,000
4. 2nd Hand Kyosho V-One RRR with:
-Max Power .12 Racer Engine
-JP Header and K-Factory 6.0mm Missile 12 Pipe
-Prolux S-5009 Steering/Throttle Servo
-2pcs. New Novarossi C6TF Turbo Glow Plug
-Front and Rear Differential (Installed)
-2 pcs. Complete Set One-way Diff (1pc. complete with pulley and outdrive/1pc. without pulley)
-NIB One Set ATS Foam Tires
-Lots of Spare Set of GQ and GRP Foam Tires
-Lots of Assorted Spare Parts
-Selling for Php 16,000
5. *NIB (Already Built) Hongnor X1CR - Php 12,500
-New Hitec HS-325HB (Throttle/Steering)
-Will give the Street Tires and Used SH Engine for free
6. New Street Gunmetal Wheels and Threaded Rubber Tires - Php 3,000
7. Used SH .21 Pull-Start Engine - Php 2,000
All items are currently overseas, all items will be available during my vacation (in Las Pinas starting on July 3, 2011 till August 7, 2011 except for the *Hongnor X1CR which I will bring with me if anyone wants to buy it (waste of space in the baggage if no one wants to buy).
Prices are negotiable on some items especially on package deal (Engine and Pipe, V-One and Futaba 3PM, Hongnor X1CR/OS Engine & Pipe/Futaba 3PM)
Pictures http://s105.photobucket.com/albums/m...%20for%20sale/
Night Thrasher is offline
Old 05-31-2011, 02:03 AM
  #66964
tagasagwan's Avatar
Trader Rating: 58 (100%+)
Hirobo Shuttle ZXX with Jr-Propo X-388S Tx & Rx, O.S. Engine, Jr-Propo Gyro system. Stock pipe. Best offer!
-Open for Swap-
5.5K
Brand New! just opened the box to check the contents. 2S to 3S lipos. 100% waterproof, fully programmable acceleration, drag brake, reverse lock, Pitcard included, built-in data logger (data cable sold separately) designed and made in U.K., for complete specs please visit http://www.mtroniks.net/details1.asp...d/59/G2Pro.htm
KEDA BRUSHLESS (540size)MOTOR 5,900KV Bnew 3.5K only (Open For Swap)
Dimensions: 36~50mm
Front mount holes are 25mm apart.
Shaft size: 5mm
Weight: 220g
Turns: 6
Spec.
Kv: 5900rpm/V
Idle Current: 6.9A
Resistance: .0034
Max Amp: 108A
Mtroniks Viper ECO20- 2,000 each, (last piece)
B/New, 20Turn motor limit, built in failsafe to protect against complete loss of signal or when out of range (compatible with all manufacturers receivers), Dual core microprocessor, 4-8 cells input voltage , 4 Layer super power circuit board, Thermal integrated protection system , Digital one touch setup, Legendary 100% waterproof design, Dimensions : L39.0mm x W34.0mm x H13.0mm, Weight : 55g, Designed & Made in U.K.
IP6 Competition ESC- 7,300 (last piece)
  • 100% Waterproof
  • No motor limit
  • 4 to 7 cells operating voltage (1.2VDC/cell)
  • Selectable drive frequency from 1.5KHz to 11.0KHz
  • Selectable throttle curves
  • Selectable acceleration rates
  • Selectable initial brake power
  • Selectable drag brakes - on/off
  • 5.6V /8.0Amp BEC (0.08V drop out @ 6A)
  • Maximum current rating, 2640Amps
  • Continuous current rating, 660Amps
  • Dimensions : L33.0mm x W25.0mm x H15.0mm (Small Footprint)
  • Weight : 20.0g
  • Designed & Made in United Kingdom
Perfect for speed & power junkies!
Mtroniks ZGM (Zero Glitch Module)- 1,400 each (Open For Swap)
B/N, 100% waterproof, dimensions: L28mm x W14mm x D7mm Designed & Made in United Kingdom
Mtroniks Signal Booster-1,400 each (Open For Swap)
B/N, the signal booster has been designed to improve the signal received from the channel it is connected in series with. The signal booster conditions the signal, filtering out any nonsense noise and amplifies the remaining data leaving a strong clean signal, giving crystal clear operation! This unit is also 100% waterproof! Designed & Made in United Kingdom
3Racing Alum. Knuckle Arm for Tamiya CR01 crawler B/new 1.2K set (2sets available) (Open For Swap)
DEANS TYPE ( T- Connectors)- 200 Pesos/Pack
(3 males, 3 females, with Shrink tubes/ pack)
BULLET Connectors 3.5mm- 200 Pesos/Pack
(3 males, 3 females, 6 Shrink tubes)
http://s304.photobucket.com/albums/n...wan/?start=all
I accept payments via Bank Transfers ( BPI & Chinabank), SMART Money/Padala or Credit cards via
Text or Call Stephen 0919-8888865 or 09326783188 Pls. include your real name and RCTech username. Sorry No Trade unless specified! Pick up at 214Racing Unit 1A #4 Liwayway St. Sta. Ana, Taguig City (In front of St. Anne Shrine). Thanks to RCTech.net and Moderators
tagasagwan is offline
Old 05-31-2011, 02:41 AM
  #66965
Default selling: BL combo
sold,, pasensya sa picture size guys,, thanks rctech
beginner1218 is offline
Old 05-31-2011, 02:48 AM
  #66966
doen08's Avatar
Trader Rating: 38 (100%+)
GENERAL POSTING GUIDELINES.
1. Avoid In-line images or pictures. Use the "Manage Attachment" Option. Let's give the viewers the choice of selecting which thumbnail to be loaded in larger version. If you prefer In-Line Images please make sure it's not too big as to skew the format of the forums (suggested size of 640 x 480).
2. Post appropriate Signature information. Avoid indexing or listing information.
3. Use the PM feature as much as possible.
4. Avoid double posting.
5. Use plain language (avoid usage of coded, textspeak, or telegraph type language).
5. No opening of new threads. Consult any moderator.
LET'S KEEP THIS FORUM CLEAN AND ORDERLY. PLEASE COOPERATE. THANK YOU.
doen08 is offline
Old 05-31-2011, 03:56 AM
  #66967
Originally Posted by aizycool0611
Looking for Standard servo for MT 1:10 scale, hi torque servo budget 1.5k below
pm me.
up
aizycool0611 is offline
Old 05-31-2011, 04:53 AM
  #66968
keisuke's Avatar
sige kung gusto nyo ako mag check ng auto nyo. lapag niyo sa lamesa ko pagtapos ng heat niyo. kung ok lang sa inyo. kasi every race may ganyan eh. dba? hahaha. ako nalang mag inspect. oks? anu ba check dun dapat all tamiya parts? parehas parin ng dati?
question sa organizers. paano ba yung dropping system? paano yung drop ng double points? gusto ko sanang malaman kasi marami din nagtatanong sakin. diko rin alam ang isasagot ko. hehe.
keisuke is offline
Old 05-31-2011, 05:32 AM
  #66969
westproof's Avatar
Trader Rating: 41 (98%+)
visit www.rcvine.com
Brandnew Hitec HS-7965MG Digital High Speed Metal Gear Coreless 2,000 each
otor Type: Coreless
Bearing Type: Dual Ball Bearing
Speed (4.8V/6.0V): 0.13 / 0.10
Torque oz./in. (4.8V/6.0V): 111 / 139
Torque kg./cm. (4.8V/6.0V): 8.0 / 10.0
Size in Inches: 1.57 x 0.78 x 1.45
Size in Millimeters: 39.88 x 19.81 x 36.83
Weight ounces: 2.18
Weight grams: 61.80
09154681992
westproof is offline
Old 05-31-2011, 05:37 AM
  #66970
Post LF:
LF tamiya 415 msxx diff joint rear......
09216013419
tapapaking777 is offline
Old 05-31-2011, 05:52 AM
  #66971
Default NITRO ON-ROAD
For Sale:
KYOSHO RRR SHIMO EDITION-20,000
INCLUDED:
.12 O.S. TZ TUNED ENGINE
BRAND NEW IS KIT IS AROUND 25K
BRAND NEW ENGINE IS AROUND 13K
PM/TXT 09209180395
jonp is offline
Old 05-31-2011, 06:02 AM
  #66972
jamespat's Avatar
Trader Rating: 20 (100%+)
Updated : May 30, 2011
(Free Shipping Nationwide thru LBC) (except FUELS)
FUTABA SERVO
(Digital Servos)
1.) Futaba S3156 Micro Digital Hi-Torque metal gear servos P1500.00
2.) Futaba S9156 Digital High-Torque Air Servo P3800.00
3.) Futaba S9256 Heli High-Speed for GY601/GY611 Gyro - P3800.00
4.) Futaba S9257 EP Heli Digital Rudder Servo - P2800.00
5.) Futaba S9351 Digital High Torque Servo - P3800.00
6.) Futaba S9451 Digital High Torque Servo - P3200.00
7.) Futaba S9070 Digital Programbl Mini BB Hi-Voltage Servo P3300.00
(Brushless Servos)
1.) Futaba BLS252 Brushless High-Torque Servo Helicopters - P4000.00
2.) Futaba BLS253 Brushless 3D Heli Servo - P4000.00
3.) Futaba BLS451 Digital Brushless High Torque/Speed Servo - P4200.00
4.) Futaba BLS551 Brushless Low Profile Car Servo BLS 551 P4600.00
FUTABA RECEIVER
1.) Futaba R6014HS 14-Channel 2.4GHz FASST Receiver - P6500.00 - P4000.00
2.) Futaba R617FS 7-Channel 2.4GHz FASST Receiver - P3500.00 - P3000.00
3.) Futaba R608FS 8-Channel 2.4GHz FASST Receiver - P4500.00 - P3500.00
4.) Futaba R603FS 3-Channel 2.4GHz FASST Receiver - P3500.00 - P3000.00
5.) Futaba R604FS-E 4-channel 2.4GHz receiver for Electronic Car - P3000.00
6.) Futaba R604FS 4-Channel 2.4GHz FASST Receiver 4PK - P3800.00 - P3300.00
7.) Futaba R614FF 4-Channel 2.4GHz FASST Receiver 4PK/4PKS - P4000.00 - P3500.00
FUTABA GYRO
1.) Futaba GY520 Gyro w/Heading Hold P6500.00 - P4500.00
2.) Futaba GY520 Gyro w/S9254 Servo & Heading Hold- P7500.00 (Negotiable) P6500.00 (sale)
3.) Futaba GY401 Gyro w/SMM Technology P3000.00 (Sold Out)
4.) FUTABA GY401 + S9254 Mini Digital Servo P5000.00 - Repriced P4660.00
TAMIYA RC ITEMS (all items here are less 10%)
1.) 54026-Tamiya TA04 Racing Body mount Set-264.00 (2)
2.) 54194-M-05 Ball Diff Set-1320.00 (1)
3.) 53694-Tamiya TT-01 Front Stabilizer Set-660.00 (2)
4.) 53842-Tamiya TA05 Stabilizer Set (F&R)-528.00 (1)
5.) 54052-RC TB03 Aluminum Universal - Propeller Shaft Set-792.00 (1)
6.) 53672-Carbon Upper Frame TT-01-680.00 (1)
7.) 53159-Anodized Flange Lock Nuts 4mm Blue 5pcs-220.00 (2)
8.) 53790-Cup Joint For Universal Shaft TT-01 and DF-02-396.00 (1)
9.) 53876-Aluminum Damper Returner-528.00 (1)
10.) 53671-Tamiya Front One-Way Unit TT-01-1672.00 (1)
11.) 53670- Aluminum Racing Steering Set TT-01 -1232.00 (1)
12.) 53590- Tamiya Cup Joint TB-01 Front One-Way Unit-220.00 (1)
FUELS (manila only)
COSMO 20% Field Master (Racing & Buggy) - P1400.00 (4L) (new stocks) promo Php1000.00only
COSMO 20% Black Hawk Special - P1400.00 (4L) (new stocks)promo Php1000.00 only
MISC
1.) OS Glow Plugs available prices start at P200.00
Glow Plugs- #8, A3, P6 (sold out)
2.) OS engine MAX-CV-R SERIES MX-18CV-R)18CV-RX (B/NEW, WITH OUT BOX) - P7000.00 promo P5500.00 (Hot Items)
ITEM LOCATION:
Pasig City and CEBU CITY
PAYMENT MODE:
a.) Bank deposit (BPI, CHINABANK)
b.) Paypal Payment accepted (Charge 50.00 for banking fee)
SHIPPING:
LBC, AIR21 and Pambato.
Meet Ups:
By arrangement only on specific area and time.
CONTACT:
JAMES
09236500500 (sun) (Preffered during office hours)
09176256500 (Globe)
"If our price is much higher please don't hesitate to tell us. We are much willing to give our Customers the best deals"
THX RCTECH
jamespat is offline
Old 05-31-2011, 06:52 AM
  #66973
bmmer701's Avatar
Trader Rating: 17 (100%+)
For Sale:
F8 Team magic Hauler bag offroad/onroad for 1/8th or 1/10 th scale - 3k neg
LRP X12 4.5 motor 2.5k neg
LRP x12 4.0 motor 2.5k neg
Reedy 4900 35c lipo packs 2k neg.
trinity tire warmers purple- 1.2k
09178134619
bmmer701 is offline
Old 05-31-2011, 06:54 AM
  #66974
Default Circuit Stadium Truck (RTR)
* This is a RTR 1/10th scale truck by Dynamite. It comes with the following:
- RTR Truck
- Radio
- Battery Pack
- Battery Pack Charger
- Decals and Tools
* It's a good car for bashing and for beginners and its upgradeable. Car was used 3 times only and comes with everything including the box and manual. It will be on display tomorrow afternoon @ Pit Shop so if you want just check it out there.
* http://www.electrixrc.com/ then check http://www.electrixrc.com/Products/D...ProdId=ECX1100
P 7,000.00
PowerPee is offline
Old 05-31-2011, 07:00 AM
  #66975
Crsdee's Avatar
Trader Rating: 24 (100%+)
Default AE truggy parts
Anyone selling AE truggy parts?
Crsdee is offline
