Go Back  R/C Tech Forums > International Forums > Manila Racers
The Big Locked Thread >
View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
Like Tree1Likes
Old 09-02-2009, 08:44 PM
  #48931
arjayreyes's Avatar
Default FOR SALE!!!
FOR SALE:
HONG-NOR X2 ( PRO-KIT )
1/8 SCALE TRUGGY
NOVAROSSI 28-7 ENGINE
1. NEW DIFF OIL
FRONT-10
CENTER-30
REAR-5
2. NEW SHOCK OIL
FRONT 50
REAR 60
3. NEW NOVAROSSI CONROD
14T CLUTCH BELL
NEW ALLUMINUM CLUTCH AND BEARINGS
4. ALLUMINUM CHASSIS BRACE
FRONT AND REAR
5. ( ON-OFF ) SWITCH INCLUDED
6. NO ELECTRONICS
FIXED PRICE: PHP 18,000.00 ONLY
RFS: I HAVE 2 TRUGGY NA THIS IS MY EXTRA KIT, I'LL GET 1/8 BUGGY NAMAN
RJ-09228252547
arjayreyes is offline
Old 09-02-2009, 09:10 PM
  #48932
ROBORAT's Avatar
kiri: pano ka naging novice e may "dats my move" ka nga diba? hehehe podium ka pa sa King of the Hill ..... tama na kangkungan. kerrera na! hehehe
ROBORAT is offline
Old 09-02-2009, 09:37 PM
  #48933
bigz's Avatar
Originally Posted by RCManila
Kala ko sabi mo si Jay sa novice din Baka wala na kami makalaro sa novice nyan! Lahat nasa PRO na
ako novice din ako. hahahaha!!!!
watch my move!
bigz is offline
Old 09-02-2009, 09:52 PM
  #48934
gab3r7's Avatar
Trader Rating: 21 (100%+)
Default LF: futaba 3pk
Glow plug igniter - 1k
-anodize blue
-d-size battery
-you can put any kind of d size batts (energizer, rechargeable)
http://s438.photobucket.com/albums/q...t=SSC_0450.jpg
T-wrench - 200pesos
-with its original packaging
-for glow plug and other nuts
http://s438.photobucket.com/albums/q...t=SSC_0451.jpg
Aluminum dampers - 800pesos
-transparent oil casing
-metal finish
-with medium yellow springs
-with oil
http://s438.photobucket.com/albums/q...t=SSC_0453.jpg
Tamiya CVA dampers - 500 pesos
-with adjustable c-clamp
-tamiya red tuned springs (soft)
-newly oiled
(pics to follow)
Kyosho v one r -6k (neg)
-new belts
-fuel filter
-.12 sirio engine turbo (very race worthy, good compression)(polished)(tuned well)
-os T-1032 tuned pipe
-aluminum threaded shocks
-one servo attached (steering)(s3003)
-front & rear stabs
-2 speed transmission
-ATS rims with sponge tires (made in italy)
-medium os glow plug
-spares
-using tornado after run oil during my runs
(race worthy kit)
http://s438.photobucket.com/albums/q...t=SSC_0455.jpg
Hobao GPX4 PRO Rolling kit -1.5k
-rolling kit only
-with touring dish rims
-slick tires
-2 servos
-dodge stratus shell
http://s438.photobucket.com/albums/q...t=SSC_0464.jpg
http://s438.photobucket.com/albums/q...t=SSC_0465.jpg
Neo racing (classic brand) -6kfix
-mother brand of nitro's
-fully hopped
-fluorine coated dampers
-medium yellow and medium hard blue springs
-with bio hazard dish rims
-digital temp gauge
-.12 pullstart engine (very good compresion, easy to start)
-tuned resonator pipe (silent @ idle, very load when reving)
-2 servos
-red alfa romeo shell
http://s438.photobucket.com/albums/q...t=SSC_0466.jpg
http://s438.photobucket.com/albums/q...t=SSC_0467.jpg
HPI R40 hara ed. - 6k neg.
-many aluminum parts
-o.s tz .12 engine (very good comp)(finely tuned)
-hec power tuned turbo pipe
-oversize headers
-2speed transmission
-s3003 & Fp-s148 servos
-adjustable shocks
-front one way
-1 TT-01 box full of spares
-HB dish rims
-Black BMW m3 shell
(race ready)
http://s438.photobucket.com/albums/q...t=SSC_0468.jpg
http://s438.photobucket.com/albums/q...t=SSC_0469.jpg
Txt me @ 0927448015 for sure buyers,. pm me for inquiries
gab3r7 is offline
Old 09-02-2009, 10:27 PM
  #48935
diorsky's Avatar
Default Rushness Sale
Futaba 3pk - Synthesized module and receiver (FSS) with box, manual and bag (not speedmind) plus 8pcs Nimh batts - 8.5K
LRP Sphere Competition TC Spec ESC and Orion Vortex 4.0 motor - 6.5K
- No reverse
- Sensored
TA03R - 4K
RFS: Mayhinahabol na piyesa ng auto
Dior - 09158501319
Meet Ups: Ayala Triangle (12:00 to 8pm)
Monumento Caloocan (10pm onwards weekdays)
Thanks.
diorsky is offline
Old 09-02-2009, 10:49 PM
  #48936
Default For Trade
Almost new 1/18 surface 5800kv Brushless Inrunner motor with 25a Tekmodel ezrun ESC
Trade with 40mhz surface RX.
you can reach me at 09063178044 Tnx
tigs85 is offline
Old 09-03-2009, 12:28 AM
  #48937
tagasagwan's Avatar
Trader Rating: 58 (100%+)
Default LAST POSTED ON PAGE 773
last posted on page 776(skipped 3 PAGES!!!)
Brandnew! 214Racing 7.4V 5000mah true 40C Lipo in Hard case! 200 Amps continuous discharge! 4.5K only!
Dimensions:
Length: 139mm
Width: 47mm
Height: 23mm
CR01- B/new 3Racing Alum. Knuckle Arm 1.2K set (2sets available)
TURNIGY BRUSHLESS MOTOR 2435 4,400KV - Bnew 1,500 only
Motor Size: 2435 (370S), Speed: 4400kv, ESC Required: 18A, Voltage Range: 6~12v, No Load Curr: 1.2A, Max Load: 26A, Diameter: 24.2mm, Length: 37mm, Front Mounting Hole Distance: 16mm, Front Mount Thread Size: M3, Shaft Diameter:2mm, Shaft Length: 12mm, Weight: 72grams
Mtroniks Viper ECO20- 2,000 each, (6 Pcs. Available)
B/New, 20Turn motor limit, built in failsafe to protect against complete loss of signal or when out of range (compatible with all manufacturers receivers), Dual core microprocessor, 4-8 cells input voltage , 4 Layer super power circuit board, Thermal integrated protection system , Digital one touch setup, Legendary 100% waterproof design, Dimensions : L39.0mm x W34.0mm x H13.0mm, Weight : 55g
IP6 Competition ESC- 7,300 (last piece)
B/N, Waterproof, NO MOTOR LIMIT, Rated Current Fwd. 660A- brake. 240A, peak Current Fwd. 2,640A- Brake 960A,Fully programmable punch, drive freq. 4-7 cells NiMh, BEC 5.6V/8.0Amps. Perfect for speed & power junkies!
Mtroniks ZGM (Zero Glitch Module)- 1,400 each
B/N, 100% waterproof, dimensions: L28mm x W14mm x D7mm
Mtroniks Signal Booster-1,400 each
B/N, the signal booster has been designed to improve the signal received from the channel it is connected in series with. The signal booster conditions the signal, filtering out any nonsense noise and amplifies the remaining data leaving a strong clean signal, giving crystal clear operation! This unit is also 100% waterproof!
TOWER-PRO 9g Micro Servo 350 pesos each (5 pieces available)
Dimensions : 22.6 x 21.8 x 11.4mm, Weight : 9g, Operating Speed (4.8V no load) : 0.12sec / 60 degrees, Stall Torque (4.8V) : 17.5oz/in (1.2 kg/cm), Temperature Range : -30deg to +60deg, Operating Voltage :3.0 - 5.0 Volts, Coreless Motor, All Nylon Gear, Connector Wire Length 150MM, Complete w/ 3 Horns.
HOBBY WING PROGRAM CARD- 850 pesos each
Pocket Size! Set-up your BL ESC anytime, anywhere! No need to bring your laptops!
DEANS ( T- Connectors)- 200 Pesos/Pack (Now Available)
(3 males, 3 females, with Shrink tubes/ pack)
BULLET Connectors3.5mm- 200 Pesos/Pack
(3 males, 3 females, 6 Shrink tubes)
U-BEC by rctimer- 850 Pesos
INPUT: Up to 30v max, OUTPUT: 6V @ 5Amps.
EC3 Connectors- 100 Pesos/Pair
Pack contains 2 female & 2 male 3.5mm bullet connectors, 1 male & 1 female plastic casings (blue)
Click here for complete product details:
http://www.rctech.net/forum/australia-sale-trade/228919-fs-b-n-kyosho-v1rr-used-v1r.html#post4577395
I accept payments via Bank Transfers ( BPI & Chinabank) or Credit cards via
Text or Call Stephen 0919-8888865 Pls. include your real name and RCTech username. Sorry No Trade unless specified! Meet up during Saturdays 7am-12noon at Kidney Center along East Ave. or Q.C. Track . Sundays 10am-12noon SM Megamall. Thanks to RCTech.net and Moderators!
tagasagwan is offline
Old 09-03-2009, 12:37 AM
  #48938
liquidmix's Avatar
Smile for sale
slightly used 1:10 scale RC car
TLO1 ( full ball bearing) RTR
included on the package
> PENNZOIL lexan Body ( bashed )
> Futaba S3003 servo.
> TEU 101 Speed control
> adjustable tie rod
> foam bumper
> includes Lynx AM radio and receiver
selling the whole package for P4,500 only
here's my mobile number 0929.955. 9259
0922. 274. 9955
meet up point: North Triangle Trinoma Mall QC
liquidmix is offline
Old 09-03-2009, 12:55 AM
  #48939
tagasagwan's Avatar
Default Posting for a friend.
POSTING FOR A FRIEND
For sale! SV27 brushless boat RTR White hull 11K only! Neg pa daw konti!
Comes with Graupner CF45 Prop.
(pics for reference only)
For details please Call or Text Mr. Bambi Garcia +639185577250 or +639228430120
Old 09-03-2009, 01:49 AM
  #48940
babytoy101's Avatar
Default For Sale Copter X V2 RTF
Specs:
1. Copter X V2 Heli, Silver CF Frame
2. Hitec HS-65 MG X3 pcs for cyclic
3. Hobbywing 40Amp ESC and 3800KV outrunner brushless motor
4. Hitec HS-56HB Tail Servo
5. Futaba 6EXHP Tx and Rx 40.81Mhz. with 8pcs CDR King Ni-Mh
6. Futaba GY401 Gyro
7. EX 11.1 2200mAh 25C Battery
8. Copter X Heli Case
9. Bnew Main Blade
Spares:
1. Used HS-56HB Servo X3 pcs.
2. Used Hobbywing 30Amp Esc and 3200KV outrunner brushless motor
3. Bnew Hitec HS-56HB (PN55007) Gearset X3 pcs.
4. Bnew Hitec HS-65MG (PN55315) Gearset X2pcs.
5. Bnew Align oneway gearcase X2pcs.
6. Bnew CPX Belt X1pc.
7. Bnew CPX V2 Feathering Shaft X1pc.
8. Bnew CPX Main Shaft X2pcs.
9. Bnew CPX Tail Blade Plastic X1pc.
10. Bnew Carbon Hobby CF Tail Blade X1pc.
11. Bnew CPX Tail Blade Holder set X2pcs.
12. Bnew CPX CF Flybar Paddle X2sets
13. Bnew CPX Tail Rotor Control Set X1pc.
14. Assorted Used CPX and Align parts in the case.
Price is 18K and Negotiable.
for inquiry kindly contact me at 09175824123
babytoy101 is offline
Old 09-03-2009, 01:51 AM
  #48941
erinkirk's Avatar
Originally Posted by erinkirk
for sale!!
1.castle,mamba sidewinder 5700, esc and motor,almost new with box and manual-SOLD!!
2.spektrum dx3.0,tx/rx, almost new with manual - 6.5k
3.yokomo bd,full hopped,makinis,touring car setup,mazda and dodge body,fow,cow, rolling kit-8k
all items negotiable..
09157975459
4700276
renie
mamba sidewinder-SOLD/TRADED!!!
erinkirk is offline
Old 09-03-2009, 02:08 AM
  #48942
mE_bytes's Avatar
Esky Lama V3 RTF (Xtreme Upgrade)
-Xtreme Sports Conversion Body
-Xtreme Aluminum Swashplate
-Xtreme Aluminum Extended Shaft
-Xtreme Aluminum Heastsinks
-Xtreme Harden Blades
-Esky 7.4v 800mah Lipoly
-Esky 4 in 1 Controller
-Esky 4ch 72MHz Transmitter
Asking Price: 3,488.00
Futaba GY401 Heading Hold Gyro
Futaba S9253 Digital Tail Servo
Asking Price: PHP 5,888.00
Item in Cebu City
FREE Shipping
09052893824
mE_bytes is offline
Old 09-03-2009, 03:27 AM
  #48943
Geetoo's Avatar
Originally Posted by Dongskie
Ayus! no bearing din!
ganda avatar mo ah. I know that one
krir: Pag meron ka da move sa pro mo na gamitin yan. Yun oh!
Bigz: Ikaw din!
Geetoo is offline
Old 09-03-2009, 03:34 AM
  #48944
Geetoo's Avatar
UPDATE
HPI Japan Mr. Tatsuro Watanabe announced that there will be a venue change for the HPI All Asia Finals this November. From Shanghai, it will be moved to Hong Kong. Schedule TBA.
For our race series on Cup Racer. Tires to be used will be hand out Solaris tire set. There is a supply problem on hpi mini tires.
ty
Geetoo is offline
Old 09-03-2009, 03:39 AM
  #48945
kirizutochan's Avatar
Geetoo: Di nga? HK na??? Wow! That's great news!!! dahil dun... sige na nga sa pro na ko...
kirizutochan is offline
