View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
REPRICED!!!
For Sale: Slightly Used Proline Rims for Axial AX10 Crawler P2,000.00
-With weights already (2 loops for front/1 loop for rear)
For Sale: Hobao Hyper ST Pro Truggy! (whole lot only) P26,000.00
"COMPLETE WITH BOX & MANUAL"
- Hyper ST Pro Rolling Chassis (good condition. Just add Electronics/electronics and AMB-PT in picture not included) Only comes out to P6,000 if you put value on all the other parts included below.
- Just broken-in NOVA Plus 28-7T (7port Turbo) Practically Bnew (worth P10,000)
- Q-world twin Motor Starter Box (Like new/worth P3,500++)
- Newly painted Pro Body (worth P1,500++)
- Bnew Hobao Pro Mounted tires (4pcs/worth P3,000++) + Free used set
- Bnew Proline Crime Fighter tires (4pcs/worth P3,500++) + Free used set
- Box of bnew spare parts (wings, arms, wing stay, shocks, universal shafts, air filters, Clutch shoe's, Clutch Bell, Fuel Tank and lots more...worth more than 8k).
RFS: Race track closed in Cebu. Now into Mountain Biking & Crawling.
PM or Txt 09228502020
http://i112.photobucket.com/albums/n...j/IMG_1915.jpg
http://i112.photobucket.com/albums/n...j/IMG_1911.jpg
http://i112.photobucket.com/albums/n...j/IMG_1917.jpg
http://i112.photobucket.com/albums/n...j/IMG_1914.jpg
LAST POSTED ON PAGE 755
last posted on page 755
FOR SALE! BRAND NEW!
NOW AVAILABLE!!!
Brandnew! 214Racing 7.4V 5000mah true 40C Lipo in Hard case! 200 Amps continuous discharge! 4.5K only!
Dimensions:
Length: 139mm
Width: 47mm
Height: 23mm
CR01- B/new 3Racing Alum. Knuckle Arm 1.2K set (2sets available)
TURNIGY BRUSHLESS MOTOR 2435 4,400KV - Bnew 1,500 only
Motor Size: 2435 (370S), Speed: 4400kv, ESC Required: 18A, Voltage Range: 6~12v, No Load Curr: 1.2A, Max Load: 26A, Diameter: 24.2mm, Length: 37mm, Front Mounting Hole Distance: 16mm, Front Mount Thread Size: M3, Shaft Diameter:2mm, Shaft Length: 12mm, Weight: 72grams
AXIAL AX10- B/new 3Racing Alum. Y-Shape linkage connector 680 pesos
Mtroniks Viper ECO20- 2,000 each, (7 Pcs. Available)
B/New, 20Turn motor limit, built in failsafe to protect against complete loss of signal or when out of range (compatible with all manufacturers receivers), Dual core microprocessor, 4-8 cells input voltage , 4 Layer super power circuit board, Thermal integrated protection system , Digital one touch setup, Legendary 100% waterproof design, Dimensions : L39.0mm x W34.0mm x H13.0mm, Weight : 55g
IP6 Competition ESC- 7,300 (last piece)
B/N, Waterproof, NO MOTOR LIMIT, Rated Current Fwd. 660A- brake. 240A, peak Current Fwd. 2,640A- Brake 960A,Fully programmable punch, drive freq. 4-7 cells NiMh, BEC 5.6V/8.0Amps. Perfect for speed & power junkies!
Mtroniks Micro Failsafe- 1,400 each(OUT OF STOCK)
B/N, this new micro sized WATERPROOF failsafe is small enough to fit easily into those tight radio boxes or even just hang outside the box! It's waterproof after all!!
Mtroniks ZGM (Zero Glitch Module)- 1,400 each
B/N, 100% waterproof, dimensions: L28mm x W14mm x D7mm
Mtroniks Signal Booster-1,400 each
B/N, the signal booster has been designed to improve the signal received from the channel it is connected in series with. The signal booster conditions the signal, filtering out any nonsense noise and amplifies the remaining data leaving a strong clean signal, giving crystal clear operation! This unit is also 100% waterproof!
TOWER-PRO 9g Micro Servo – 350 pesos each (5 pieces available)
Dimensions : 22.6 x 21.8 x 11.4mm, Weight : 9g, Operating Speed (4.8V no load) : 0.12sec / 60 degrees, Stall Torque (4.8V) : 17.5oz/in (1.2 kg/cm), Temperature Range : -30deg to +60deg, Operating Voltage :3.0 - 5.0 Volts, Coreless Motor, All Nylon Gear, Connector Wire Length 150MM, Complete w/ 3 Horns.
TOWER-PRO MG996R SERVO- OUT OF STOCK
Upgraded version of the famous MG995. The MG996R has smoother operation due to a whole new PCB circuit, IC control so it CENTERS perfectly! Metal gears are further improved so it's more quiet. Perfect for 1/8 & 1/10 scale Cars,Buggy,Truggy, MT's. Safe for large scale plane application!
BRUSHLESS MOTOR 540 SIZE - 3.5K only Bnew KEDA B36-50-6T 5900kv, 5mm shaft. 25v max input. ( PENDING TRANSACTION!)
HOBBY WING PROGRAM CARD - 850 pesos each
Pocket Size! Set-up your BL ESC anytime, anywhere! No need to bring your laptops!
DEANS ( T- Connectors)- 200 Pesos/Pack (Now Available)
(3 males, 3 females, with Shrink tubes/ pack)
BULLET Connectors3.5mm- 200 Pesos/Pack
(3 males, 3 females, 6 Shrink tubes)
U-BEC by rctimer- 850 Pesos
INPUT: Up to 30v max, OUTPUT: 6V @ 5Amps.
EC3 Connectors- 100 Pesos/Pair
Pack contains 2 female & 2 male 3.5mm bullet connectors, 1 male & 1 female plastic casings (blue)
Click here for product pictures:
http://s304.photobucket.com/albums/nn199/Tagasagwan/
I accept payments via Bank Transfers ( BPI & Chinabank) or Credit cards via
Text or Call Stephen 0919-8888865 Pls. include your real name and RCTech username. Sorry No Trade unless specified! Meet up during Saturdays 7am-12noon at Kidney Center along East Ave. or Q.C. Track . Sundays 10am-12noon SM Megamall. Thanks to RCTech.net and Moderators!
NOW AVAILABLE!!!
Dimensions:
Length: 139mm
Width: 47mm
Height: 23mm
happy bertday! rnold and oldskul hehe
WOW PAULIT ULIT KAYO! HINDI NA TALAGA KAYO NAHIHIYA SA KAPWA NIYO. MAKIKITA NAMAN YAN SA MGA RECENT PAGES. SAME OLD POST
Looking for:
Any brand FM Radio TX and RX (preferably Futaba) that operates in the 27mHz range.
sana at a reasonable price...
also, if you have this radio that came with some Associated RTR kits pwede na rin.
Associated XP3D FM radio
pls PM me for offers
thanks in advance
thanks in advance
Location: 205 2/F Place One Bldg. Katipunan Ave., Q.C. Tel: 949-2129
Trader Rating: 4 (83%+)
NEW ARRIVALS!!
RJ AIR REMOVER
for Buggy
for Touring
MICRO TEMP DIGITAL INFRARED THERMOMETER
SPEEDWAY PAL
YUKES AE86 DRIFT BODY
APEX FD35 D-1 DRIFT SPEC BODY
DUMMY EXHAUST PIPES (5 DIFFERENT VARIETIES)
SIDE MIRRORS
BLADE DRIFT TIRES HARD
ABC HOBBY 210X300mm CARBON STICKER SHEETS
KAWADA SUPER DURALUMINUM 48P PINIONS
18T - 24T
31T - 40T
JET CYCLONE TC ALUMINUM PARTS
JET CUP RACER ALUMINUM PARTS
2.4GHZ CONTROLLERS
CORNER DOTS FOR DRIFT / TOURING
......AND LOTS MORE! COME VISIT US!
RJ AIR REMOVER
for Buggy
for Touring
SPEEDWAY PAL
SIDE MIRRORS
18T - 24T
31T - 40T
2.4GHZ CONTROLLERS
Kyosho RRR evo WC 1/10 nitro onroad
SOLD Thanks RCTECH
2 complete rolling chassis one K-Factory fully hopped up and one stock
PLUS Spare parts to build one more complete car and much more. So basically
3 whole cars plus spares
no electronics
Novarossi Plus-3t only 1 gal used, new conrod (changed after break in)
with 2 novarossi 2601 tuned pipe and manifold one brand new and one used
SELLING as a package only 15K
IF you get the package I can include a hudy setup station complete w/ case for 5k
Pls include your rctech name when texting
09172043938
no electronics
09172043938
SIR TOMMI YOU GOT PM!!1
pro D spec r (opem for trade)
(3 months old hindi na ginagamit) now accepting trade any items psp+cash or xbox360 or ps3 or pc+cash or ofer lower kit+csah or str8 swap pm or txt lang
o and i do accept iphone+cash or ako mag add if mataas na klaseng iphone ty
cash 17k
swap 19k
walang gas gas
Chassis Protector since day one
hop ups palang 5k na
- FOW
- titanium Screws and some bolts
- Stabilizers "soft"
- servo saver
- body post intentions
- orange spacers
- protective film
- box manual
PICS
http://img.photobuck.../Photo-0064.jpg
http://img.photobuck.../Photo-0065.jpg
http://img.photobuck.../Photo-0066.jpg
http://img.photobuck.../Photo-0067.jpg
http://img.photobuck.../Photo-0063.jpg
shells
impala RARE-1.5k http://img.photobuck.../Photo-0058.jpg
warning device -200
am crystal 27.195 bnew 350 sa lils - 250 nalng bnew
futaba am receiver -400nakita ko na
RIMS
old school 800 - http://img.photobuck...es/IMG0035A.jpg
shiny 600- http://img.photobuck...es/IMG0036A.jpg
may crack to so 200 petot nalng - http://img.photobuck...es/IMG0037A.jpg
yung 2 painted red 2 painted yellow - 300 -http://img.photobucket.com/albums/v464/shabadoodles/IMG0038A.jpg
painted gold 300- http://img.photobuck...es/IMG0039A.jpg
2 set for 400 petot - http://img.photobuck...es/IMG0041A.jpg
all rims for 1.7k all out ksama gulong
eto iba pics -http://img.photobucket.com/albums/v464/shabadoodles/IMG0040A.jpg
http://img.photobuck...45308148m93.jpg
Teu +23t rz motor + sportuned motor - 1k
meeting place makati or meet half way if pro d buy
txt for faster transaction 09173790202 (no chikka) piso lang ang text hahaha
ty
buy and sell peeps are open for negotiote for all items
cash 17k
swap 19k
walang gas gas
- FOW
- servo saver
- orange spacers
- protective film
- box manual
PICS
shells
warning device -200
RIMS
ty
bilhin nyo na po.
Kyosho Giga-Crusher Nitro Remote Control Monster Truck. With two x 26cc engines,Three speed transmission and reverse gear
sell @ 20k
item is in cebu, free shipping po
you can pm me or email @ [email protected]
or txt @ 0917480066 or 09239713080 Francis "nuki" Del Rosario
OS .91 sx ring heli engine brand new
OS Crankcase 91SX H with crankshaft and cover plate brand new
OS crankcase 91SX H only brand new
all @ 12k item is in cebu free shipping
you can pm me or email me @
[email protected]
or sms me @
09174180066
09239713080
sell @ 20k
[email protected]
or sms me @
09174180066
09239713080
Ang kulit talaga ng ibang nagpopost dito ano? Rule: wag naman post ng post pag natatabunan ung for sale, pag post ka ng post at walang bumibili, siguro naman you should be mature enough to realize na BAKA AYAW NG MGA TUMITINGIN ANG BINEBENTA MO.....
