Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 11-07-2006, 10:33 PM
  #13411
ROBORAT's Avatar
curious: yahoo!!! chirstmas race should be one to look forward to! sa capitol kaya gagawin? sige, abangan nalang natin.
pitshop: we eagerly await your announcement.
ROBORAT is offline
Old 11-07-2006, 11:21 PM
  #13412
tantalus007's Avatar
Trader Rating: 17 (100%+)
Originally Posted by |JayFlores|
tantaclaus007 , whats up pre? maganda ba ung 540 motor cooler mo?
honestly...hindi ko pa na-try... makikita natin on saturday...gusto mo???
Originally Posted by ROBORAT
pero first things first - ride round 3 muna tayo! tagal nga ng sat! makikita ko namaman mga malilibog sa rc! hahaha
wag mawawala si minimi...
Originally Posted by curious mind
talked to mang last monday, magpa xmas race daw sya. ( dont worry hindi naman lashing si mang nung nagkausapa kami) so lets wait and see.
ok yan ah!!! christmas race... baka naman ikaw ang lashing nun curious...
tantalus007 is offline
Old 11-08-2006, 12:28 AM
  #13413
|JayFlores|'s Avatar
jay: actually, im suggesting that we just use the layout we will be using for the first time this weekend. i think thats as techincal as it will get at JP. at most we can cut the straight a bit shorter if they want since puro 23t lang gagamitin natin. hirap din kasi gumawa ng super techincal layout sa JP kasi malalaki talaga turn dun at malapad ang lanes kaya very flowing. anyway, tignan nalang natin. ... pero first things first - ride round 3 muna tayo! tagal nga ng sat! makikita ko namaman mga malilibog sa rc! hahaha
xanavi: np!
curious: ikaw nalang magpa-karrera! gawa ka ng "curious cup" race! ... pwede rin tanta-claus race para paskong pasko ang dating! hehehe seriously, mukhang for the first time in years we wont have a masters race. this time last year nagumpisa na mga qualifiers para dun. hopefuly may christmas race pa rin.
sir, ibig sabihin makikita mo si minimi? hahaha tama! enjoy muna tayo sa current ride series at sa newlayout.
curious cup? tantaclaus cup? how bout woot woot cup? kahit sino sakanilang dalawa babaha ng mga alkansya.
tantalus, akin nalang motor cooler mo? hmmmmm pag lashing si curious pag nasa pitshop ibang klase nangyayari eh.
|JayFlores| is offline
Old 11-08-2006, 02:06 AM
  #13414
alecladanga's Avatar
wowow marami palang races din sa december (hopefully) kay saya naman talaga
question lang po sa lahat - actually, i just wish to confirm if tama nga yung hula ko sa problema ko...
I was at JP today and it seems that my cheap avacus power supply isn't working (12V & 6A).
I hooked up my TLP charger and tried to charge my intellect batteries (side-by-side config - deans connectors - thanks sir bing).
when charging, it'll peak but the batteries are not even hot enough, then my run time will only be 6 - 8 minutes.
I don't think it's my charger since during the 2nd leg, I hooked it up with the power supply of minimi and it was chraging okay, the batteries will get hot (my intellect batteries were still in stick pack form). I charge at 5.5A.
I doubt it as well if it's my batteries since it's just around 2 months old and I only use it for once a week (averaging of 6 - 7 runs per day, each run would be around 8 - 10 minutes long).
So, do you think that my power supply is too low? 6A lang kasi eh?
Sorry for the long post, hope you understood what I have written down and thanks in advance guys
alecladanga is offline
Old 11-08-2006, 03:50 AM
  #13415
|JayFlores|'s Avatar
fred! hindi pa ako nakakadaan kay pitshop. busy kasi eh. onga pala red powered ang avatar mo ah? kaka-gigil
Old 11-08-2006, 04:54 AM
  #13416
curious mind's Avatar
lets hope for the best.
the power supply may be a factor in false peaking, but where not yet sure kung false peak nga cause the charger u have right now dont have digital reading to check on mah uploaded to your packs. Basically if you normally charge your packs 5.5amp its a requirement for the supply to be at list 8-10amp capable. Your Power supply rating should have atlist 25% buffer vs usage. The packs may not be that warm cause its not fully charged.
yup i think so too.
after using your packs, make sure to discharge them to 0.9v if possible and let them cool down for atlist 2hrs before charging again. 6-7 runs/day over work ang batts mo. could be a reason that your batts no longer charge that good.(speculation lang yun)
i think so. bump up to 8-10amp PSu.
curious mind is offline
Old 11-08-2006, 05:35 AM
  #13417
Thanks as always sir curious for the information i'm saving up na for a good charger and equalizer and sana power supply too
kita-kits po sa sabado
Old 11-08-2006, 06:02 AM
  #13418
Trader Rating: 82 (100%+)
no problem, baka pumunta na rin ako this friday, may lakad kasi ako banda dun. text mo ko kung may papasabay ka, text din kita friday kung matutuloy ako. at least, sa JP ang futaba cup kaya konti parts lang kailangan ko bilhin
marvi is offline
Old 11-08-2006, 07:03 AM
  #13419
XTREMERCHOBBIES's Avatar
YAHOO 3 tulog nalang karera na ulit dont forget be early on saturday lalo na dun sa mga di pa nasubukan yung lay-out
ROBO: tapos ka na mag SPINTEC? ano nangyari umangat ba capacity? borrow spare charger on saturday ha thanks! Futaba cup will be held at JP Raceway am i correct? Modified naman tayo but that might mean we will have to change the lay-out
MARVI: ayus yang avatar mo ah dalhin mo nga yan sa sabado hehehe! kung pwede naka pink bathing suit
F.A.S.T: huy post ka na dito!!! EP player ka na din hehehe!! there's a new Corally driver... watch out Stockers
XTREMERCHOBBIES is offline
Old 11-08-2006, 07:38 AM
  #13420
is it true-is it true??? si FAST EP racer na rin? Corally Team pa!!! bwahahahahahahaha!!! fresh meat!!!
oist john... tara laro na tayo sat... 19t dapat kasi FAST kana sa GP...
Old 11-08-2006, 07:48 AM
  #13421
alec, try mo na rin kumuha ng regulated na power supply, para no problem for the new charger your saving up for the future...
sir, hiramin mo na lang cellphone ni marc... im sure andun yun kasi completo yun... as per prince jay...buhay na buhay ang mga laman ng cellphone ni miniminyakol... no match ang 200gig na ipod video...
ayos yan... the F A S T and the curious sa ep scene...
Seriously, welcome to the ep scene Mr. F A S T...
Old 11-08-2006, 08:17 AM
  #13422
rbboy's Avatar
FAST & the Curious hahaha! watta nice tandem yan ah! maganda ang laban nyan yep John is finally trying EP... plaktis sya tomorrow sa JP sana makasali sya sa Saturday
rbboy is offline
Old 11-08-2006, 03:02 PM
  #13423
|JayFlores|'s Avatar
okidoks! salamat pare. teka nga, kilala mo ba si angelica panganiban? if ever isama mo sa sabado pero tama si xtreme pink powered dapat.
hindi lang yun.. starring marc solids pa. hmmmm.. *wootwoot* hehehehe nakaka-gigil tlga
yahooo!!! THURSDAY NA!!! at wala pa ako practice
Old 11-08-2006, 06:11 PM
  #13424
jay: di yan si angelica, taga engkantadia yan
btw, sino sa mga bd boys ang may extra c-hubs, kahit plastic? wala na daw sa pitshop sabi ni tantalus yun pa naman kailangan kong spare
marvi is offline
Old 11-08-2006, 06:48 PM
  #13425
yep yep tantalaus, i'll get a regulated power supply, hopefully bytbhe end of the month and a new charger as well tumitingin na ako sa sale thread for second hand equalisers and dischargers
kita-kits sabado
