Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 11-07-2006, 04:54 AM
  #13396
Mini Toink's Avatar
Trader Rating: 30 (97%+)
Originally Posted by Minimi
ang cute ko talaga!!
ah okay...
Toink
Mini Toink is offline
Old 11-07-2006, 05:05 AM
  #13397
buboy28's Avatar
Xanavi_R34]Mga guys, can I ask a favor(s) from you? Can you please help me which brand to buy in the f.f. items that I'm going to put and how much they cost.?
-Battery - Intellect matched packs(3K to 4K) Loose Cells ( 200/cell to 300/cell)
-E.S.C - 3K to 12K ( if your running stock or 19T pwede na yung 12T limit na ESC para mas mura f u r planning for modified better get no motor limit ESC)
-Discharging Tray - 3K to 6K
-P.S.U.(Regulated)- 4K to 6K
-Transmitter - M-11, 3PK and Helios from 14K to 15K
-Servo(digital na mabilis ang response)- 4K to 6K
-Plugs(deans, bullet, etc...)- 200 to 300 pesos per set
-Charger(digital)- 4K to 8K
Pls specify na lang ung mga di ko nalagay na gamit na kelangan sa pangangarera sa itaas..
ty po in advance..[/QUOTE]
HOPE THIS HELPS
buboy28 is offline
Old 11-07-2006, 06:33 AM
  #13398
|JayFlores|'s Avatar
tahimik ah....busy ata lahat sa pag setup for saturday
busy nga. hehehe tagal eh. wednesday palang bukas.
cute ka tlga minimi. kaya nga meron ka mau diba?
|JayFlores| is offline
Old 11-07-2006, 11:01 AM
  #13399
tantalus007's Avatar
Trader Rating: 17 (100%+)
Originally Posted by babytoy101
tantalus: hehehe! teka? nabilhan naman kita ng motor cooler at yung mtx-4 battry brace eh wala tlga stock... di ka isa sa mga sinawing palad... isa ka sa magbabayad sa akin... hehehehe!
ayus!!! pakidala na lang nung item on saturday!!! thanks!!!
bakit, kanino bang kotse ang inaayusan mo ng setup ngayon... kay mau???
tantalus007 is offline
Old 11-07-2006, 05:01 PM
  #13400
curious mind's Avatar
yepz, tahimik nga ang its wednesday. tagal nga ng sat. can't wait to race.
minimi: wala sa timing ang log-in mo sa rctech. busy sila sa work yung iba nagpunta sa LHS to get stuff. Yung iba nag overtime para sa sat wala sila conflict sa work. ikaw ano ba ginagawa bukod sa pag tulog sa hapon?
toink: wagna natin contrahin, cute nga sya... yun din sabi sakin ni misis nya and ni day.
tantaclaus: may bago nnman? mau?? matulis talaga!!
curious mind is offline
Old 11-07-2006, 05:49 PM
  #13401
ROBORAT's Avatar
Xanavi_R34: some added inputs to buboy's suggestions:
Battery - Intellect Loose Cells Approx P1850 for 6-cells. Add about P200 for battery bars to assemble your packs so thats about P2000+ per pack. I think at this you wont need the expensive matched packs. I still use loose cells to this day and although matched packs still pack more power, loose cells will still do the job at less cost.
E.S.C - i suggest you go with a 2nd hand high end esc with no motor limit from the start. getting a brand new mid range one will turn out more expensive in the long run since when you want to run a faster motor you'll have to invest again. And even if you are running stock or other spec classes, a 2nd had, top end esc will give you better power, performance and flexibility than a brand new mid range one. Lower resitance, adjustable drive frequencies, etc. is what you will need to go faster. Try looking for a 2nd hand LRP Quantum 2 or Novak GTX/GT7 or even a 1st gen KO VFS at the for sale thread. You should find one at around 4k-6k depending on which model.
Discharging Tray: The much more ctx-d is the one that seems to be the most complete - equalizing, linear and pulse discharging, etc (about P8-9K). But if youre only after equalizing, the rayspeed or the novak smart tray should do the trick.
P.S.U.(Regulated): Much More
Transmitter: what buboy mentioned are the best one's to have. but if too pricey, try looking for a 2nd hand Sanwa M8 or KO Mars-R. If you're lucky, you might get one for around P8K or so.
Servo(digital na mabilis ang response): Futaba 9550 (smaller/lighter with enough speed for TC), Sanwa WRX line. P4K-P6K
Plugs(deans, bullet, etc...): go with bullet connectors - i believe they have less resistance compared to deans since there are less connections/solder joints given you install directly to the batteries with no added lead wires required. approx P300 a set.
Hope this helps.
TATLONG TULOG NALANG!!! ROUND 3 NA!!!! WOOOOHOOOO!!!!!!!
ROBORAT is offline
Old 11-07-2006, 06:35 PM
  #13402
Trader Rating: 82 (100%+)
woohoo!!!!!!!!!!!!!
Originally Posted by oldskul
ok guys, we have approval!
The Futaba Cup will now be held at JP Raceway on December 3.
marvi is offline
Old 11-07-2006, 06:39 PM
  #13403
|JayFlores|'s Avatar
wow goodnews yan fred! rain or shine tuloy ang futaba cup!
Old 11-07-2006, 07:39 PM
  #13404
ROBORAT's Avatar
yup! rain or shine, tuloy futaba cup! yahooo!!! now to help with the layout....
ROBORAT is offline
Old 11-07-2006, 09:37 PM
  #13405
|JayFlores|'s Avatar
tantaclaus007 , whats up pre? maganda ba ung 540 motor cooler mo?
curious , exciting ah? after ng ride series balik JP ulit for another fun filled racing scene.. hehehe
robo , goodluck with the layout sana pag nag bago kayo ng layout makasama kami para test run narin.
Old 11-07-2006, 09:55 PM
  #13406
correct ka dun dude. hindi pa nga natatapos ang ride series excited nako sa futaba cup. Dec 9 and 16 nalang ang bakante sa racing calendar natin. hmmmm... sino kaya ang magpapakarera ng 9 and 16??
Old 11-07-2006, 09:59 PM
  #13407
Xanavi_R34's Avatar
Thank you po sir buboy and robo for the reply..
now, all I have to do is make ipon pera..
Thanks again!!!
Xanavi_R34 is offline
Old 11-07-2006, 10:06 PM
  #13408
|JayFlores|'s Avatar
hintay lang tayo ng mga post baka meron pakarera si mang sa dec. 9 and 16.
hahaha tagal mag sabado. woohoo!!
Old 11-07-2006, 10:19 PM
  #13409
ROBORAT's Avatar
jay: actually, im suggesting that we just use the layout we will be using for the first time this weekend. i think thats as techincal as it will get at JP. at most we can cut the straight a bit shorter if they want since puro 23t lang gagamitin natin. hirap din kasi gumawa ng super techincal layout sa JP kasi malalaki talaga turn dun at malapad ang lanes kaya very flowing. anyway, tignan nalang natin. ... pero first things first - ride round 3 muna tayo! tagal nga ng sat! makikita ko namaman mga malilibog sa rc! hahaha
xanavi: np!
curious: ikaw nalang magpa-karrera! gawa ka ng "curious cup" race! ... pwede rin tanta-claus race para paskong pasko ang dating! hehehe seriously, mukhang for the first time in years we wont have a masters race. this time last year nagumpisa na mga qualifiers para dun. hopefuly may christmas race pa rin.
ROBORAT is offline
Old 11-07-2006, 10:31 PM
  #13410
Originally Posted by ROBORAT
curious: ikaw nalang magpa-karrera! gawa ka ng "curious cup" race! hehehe seriously, mukhang for the first time in years we wont have a masters race. last year nagumpisa na mga qualifiers para dun. hopefuly may christmas race pa rin.
baka walang pumunta sir...
oo nga sir sayang walang masters this year. ganda pa naman ng dicing ng mga pro racers that time. haaay... nakaka miss ang masters...
talked to mang last monday, magpa xmas race daw sya. ( dont worry hindi naman lashing si mang nung nagkausapa kami) so lets wait and see.
