Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 09-05-2006, 06:05 PM
  #12076
curious mind's Avatar
Originally Posted by ROBORAT
inigo: congrats pare! now you can experience the happiness that comes with having your own child! sarap nyan pare! nothing compares!
.... parang naging heli thread na 'to a! meron naman flyer's thread sa kabila.
curious: sige, kita nalang tayo sa pasko kung raffle nga habol mo... hehehe .... its about the fun and thrill of racing bro!
hehehe... curious lang sir.
on-road parin sir, and ofcourse its the pips i get along that makes racing fun. may kulitan, may konting banggaan and syempre yung mga Jokes nung mga jokers ang masaya. Not to mention pag si Boss pitshop ang kakulitan namin. basta cool ang grupo, join ako jan.
curious mind is offline
Old 09-05-2006, 10:17 PM
  #12077
Trader Rating: 16 (100%+)
Not for public viewing before 09-01-06
Team Losi JRXS “Type-R”
Team Losi is pleased to announce the much anticipated release of the JRXS “Type-R” racing sedan. As the name implies this is an evolution of the ultra successful JRXS that has won numerous National and International events the last few years. Team Losi bucked the trend of making another copycat version of the all-to-common sedan design with the narrow centrally weighted JRXS. The Type-R retains all the hi-tech features of the JRXS as well as the numerous small changes and design innovations that the team has developed over the last few racing seasons to further enhance the versatility, adjustability, efficiency and performance. In addition to the most noticeable revision of the motor moved toward the rear of the chassis, the Type-R also features:
•Newly designed narrow differentials
•Longer driveshafts for freer suspension movement when cornering
•EA3 composite molded suspension components
•Center mounted battery design can use Li-Po, stick, or racing packs
•Longer rear arms with revised suspension geometry
•New upper front arms for longer camber links
•New 3mm Carbon/Graphite front and rear shock towers
•Machined aluminum suspension mounts pinned to prevent movement
•New “RCD” rear driveshafts
•Lightened center shaft for less rotating weight
•Machined aluminum split design bulkheads for easy maintenance
•Machined aluminum motor mounts with built in fan mounts
•2.75mm Carbon/Graphite chassis with balancing marks
•2.75mm Carbon/Graphite top plate with transponder mount
•Bellcrank style adjustable servo saver with optional rigid link
•Machined aluminum shock mounts
•Fan coupler allowing for up to 3 cooling fans
•New “HD” hex-in-head ball studs
•Captured rod ends with one-piece steering link
Although the Type-R comes with a set-up for foam tire racing, it still retains the unique ability to be quickly and easily converted for asphalt/rubber tire racing. The unmatched combination of cutting edge design, hi-tech materials, and machined parts make the JRXS Type-R the most feature packed sedan chassis ever offered for pro-class competition. Look for the JRXS Type-R at hobby shops and racetracks worldwide this fall.
Fortress is offline
Old 09-06-2006, 05:10 AM
  #12078
ROBORAT's Avatar
as per mr. todd hodge of team losi himself .... looks like October for the JRXS-Type R release! woooohooooo!!!! Cant f'n wait!
ROBORAT is offline
Old 09-06-2006, 05:19 AM
  #12079
rough512's Avatar
Curious , sali ako jan sa mini-cheapie heli testing mo... hehehehe... ayos yan sa likod ng JP.. wag lang barilin ni JT ha? Meron sa landmark around 1.9k.
I'll be at JP this sat... plaktis and hanap pa ng setup ng onroad EP.
rough512 is offline
Old 09-06-2006, 05:53 AM
  #12080
buboy28's Avatar
Matt Francis used this kit at the ROAR Onroad Nationals He placed second at 19 turn TC and fourth at the Modified TC I'll also be keeping an eye with this kit
buboy28 is offline
Old 09-06-2006, 06:00 AM
  #12081
Ngeks... bakit now ka lang nag post.. Nag glorieta pa naman ako after office. Sayang!!! Tara mas marami mas makulit... hehehehe... Pero wag nyo iwan ang EP ha... Wawa naman si voodooh pag wala na sya kalaro.
Jay: wag mo na restore yang BD mo. Antayin mo nalang ang New Losi JRXS “Type-R” !!
Old 09-06-2006, 06:10 AM
  #12082
rough512's Avatar
teka lang dude.. nakabili na ako.. hintayin mo text ko sa iyo yung frequency ng nakuha ko... fixed frequency mga ito
heheheheh
Syempre di ko maiiwan EP onroad... sayang naman mga gamit, di mo naman mabenta ng matinong price. Tsaka okay yung nakakalikot lagi... habang nanood nga ako ng TV hawak ko yung 415 ko eh... di ako makapag-aral sa bahay dahil laging nakatutok ang mata sa kit.. kaya pagdating ng weekend, tamad nang pumunta ng track kasi nagsawa na ) kaya dapat agahan ang alis ng haus bago magset-in ang katamaran...
rough512 is offline
Old 09-06-2006, 06:30 AM
  #12083
tantalus007's Avatar
Trader Rating: 17 (100%+)
May point ka dian!!!
Tama si curious, baka omen yung nangyari sa BD mo last sat... hintayin mo na lang lumabas ung New LOSI JRXS "Type-R"...
as per mr. todd hodge of team losi himself .... looks like October for the JRXS-Type R release! woooohooooo!!!! Cant freakin wait!
Looks like your gonna be one of the first to get their hands on this kit when it arrives at our LHS... cant wait to see it on pit tables... hhhhmmmmmm...
tantalus007 is offline
Old 09-06-2006, 06:42 AM
  #12084
|JayFlores|'s Avatar
Default !
we'l see. pero mukhang malabo ako makapagpalit ng new kit sa mga panahon na ito.
well from the name itself palang mukhang type racing na.
parang gawain ko rin ito ah..
|JayFlores| is offline
Old 09-06-2006, 06:48 AM
  #12085
Hindi naman ngayon mo kukunin, sa October pa...
Para Sayo talaga ang LOSI JRXS TYPe-R !!! Magpa reserve ka na at baka maunahan ka ni minimi!!!
Old 09-06-2006, 06:59 AM
  #12086
heheheheh
ano freq ng nakuha mo?
Erwin: yung nakuha mo na esky, ano freq? para pwede tayo magsabay sabay sa ere...)
Old 09-06-2006, 08:15 AM
  #12087
rbboy's Avatar
curious: kaka-order ko lang ng blimp sa tower hobbies hehehe! ayus to sa JP Raceway... iikot-ikot ang advertisement habang may karera hahaha
Attached Thumbnails Electric Touring / On-Road RC-airship-1.jpg
rbboy is offline
Old 09-06-2006, 08:20 AM
  #12088
VooDooPH's Avatar
Trader Rating: 18 (100%+)
honga!!!
VooDooPH is offline
Old 09-06-2006, 08:22 AM
  #12089
Trader Rating: 82 (100%+)
Default indoor heli
mga EP boys, ito ba yung heli na pinaguusapan nyo? ... (see pic below )
if yes, patesting naman kung sino meron (yoohoo, sir rough512 & wind_split ) noon ko pa to binabalik balikan sa landmark, natest fly ko na rin, kaso di fully charged yung batt. dyahe naman ako na ipafully charge yung batt, lalo na kung di ko naman kukunin
nung na-test ko kasi doon, ikot lang ng ikot habang nagho-hover, konti lang yung control nya for forward/back/side to side flight. factory charge lang kasi nung nagamit ko, plus sandali lang na-charge kasi magsasara na noon sa landmark
OK ba siya lumipad kapag fully charged yung batt?
Attached Thumbnails Electric Touring / On-Road RC-maliit-na-helichopter.jpg
marvi is offline
Old 09-06-2006, 10:06 AM
  #12090
i know this is the wrong thread
but ... http://youtube.com/watch?v=DZSvnKJNIyQ
pero yung ending ...
marvi is offline
