Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 08-30-2006, 06:35 PM
  #12016
joelt's Avatar
Originally Posted by grandmasteralok
hi guys, ano po b mas maganda... bili ako ng grip kit then setup ko for drift if necessary or bili ako ng drift kit then setup ko for grip??? preferred ko tamiya... d ako makapmili e... hehehe... salamat...
IMHO, and if you have the budget, go for a 'grip kit' and then set it up later on for drift. Easier to do it this way kasi most drift kits are actually entry level racers (plastic shocks, plastic arms, bushings, etc) with drift tires included. So, you'll end up having to invest a lot, should you plan to run grip competitively. If it will be the other way around naman, all you'll have to do is buy a set of drift tires.
joelt is offline
Old 08-30-2006, 08:10 PM
  #12017
VooDooPH's Avatar
Trader Rating: 18 (100%+)
may maglalaro pa ba ng stock?
VooDooPH is offline
Old 08-31-2006, 02:15 AM
  #12018
|JayFlores|'s Avatar
meron parin sympre. nagkataon lang na kulang naglalaro nung saturday kaya nag 19t class. hehe
kamusta pare? tagal mo nawala ah?
|JayFlores| is offline
Old 08-31-2006, 04:14 AM
  #12019
VooDooPH's Avatar
ok lang. dami kasing sagabal sa paglalaro ng r/c eh... hehehehehe!
sana this sat makalaro na ako. kahit makapagpraktis man lang
VooDooPH is offline
Old 08-31-2006, 05:33 AM
  #12020
Trader Rating: 82 (100%+)
CAD dwgs of the new JRXS type R
Attached Thumbnails Electric Touring / On-Road RC-losi-jrxs-type-r.jpg   Electric Touring / On-Road RC-jrxsr1.jpg   Electric Touring / On-Road RC-jrxsr2.jpg   Electric Touring / On-Road RC-jrxsr3.jpg   Electric Touring / On-Road RC-jrxsr4.jpg
marvi is offline
Old 08-31-2006, 07:23 AM
  #12021
5 more ...
Attached Thumbnails Electric Touring / On-Road RC-jrxsr5.jpg   Electric Touring / On-Road RC-jrxsr6.jpg   Electric Touring / On-Road RC-jrxsr7.jpg   Electric Touring / On-Road RC-jrxsr8.jpg   Electric Touring / On-Road RC-jrxsr9.jpg
marvi is offline
Old 08-31-2006, 07:24 AM
  #12022
last 2 ...
Attached Thumbnails Electric Touring / On-Road RC-jrxsrx10.jpg   Electric Touring / On-Road RC-jrxsrx11.jpg
marvi is offline
Old 08-31-2006, 10:02 AM
  #12023
curious mind's Avatar
ofcourse may stock class parin. Meet half way ang nangyari nung last sat. there were no enough racers for stock and modified kaya we decided to join forces and run 19T. it was fun, so much fun!!! next time sali ka lang.
curious mind is offline
Old 08-31-2006, 10:13 AM
  #12024
|JayFlores|'s Avatar
yupyup. pare laro ka sa sabado?
uyyy, congrats kanina sa nitro race. heheheh
Old 08-31-2006, 11:24 AM
  #12025
rbboy's Avatar
lupets ng takbo ng curious TQ and WIN sa first Nitro Race eh! 19T ba on saturday? di ko na pwede buy back yung DC kay tantalus... pero may banzai pa naman ako so game pa din ata wag lang malasing bukas ng gabi haha
rbboy is offline
Old 08-31-2006, 06:44 PM
  #12026
ROBORAT's Avatar
jrxs-r .... the future is here!
pisthop/fortress: sign me up for one sir! im definitely getting that for my next ride! hope it comes out soon! btw, may karrera ba bukas? friday na sir, no announcement yet. or are we going to be implementing the "race only every 2-weeks" thing?
more details:
Here is the info listed on the Horizon site:
Main Page
EA3 suspension components provide strength and durability
Revised suspension geometry for improved handling
Revised drivetrain layout with centrally located, rear-mounted motor
New belt materials and drive pulley geometry
New "narrow diff" setup
Machined aluminum bulkheads and chassis braces
Balanced weight layout for improved handling and response
Ultra-narrow chassis and top deck
New ball bearing steering system
New front upper arm design for strength and stability
F/R diff setup ideal for carpet racing
Race proven adjustable bladder shocks with single or double O-ring configuration
Bottom-load battery configuration accepts NiMH or Li-Po packs
Picture/CAD captions:
The new front upper arm design improves strength and increases stability during hard cornering.
The Type-R design centers weight and mass for razor-sharp response and handling.
Battery packs load from the bottom, lowering CG and making quick battery changes possible
LiPo battery packs can be utilized in the Type-R bu using the included LiPo battery tray/mount set.
The "long arm" suspension configuration allows racers to choose a "short" or "long" suspension arm setting based on track conditions.
The Type-R's super low profile keeps weight low and centered for precise handling
Unique "reverse" CVD's (RCD's) are used on the rear of the Type-R to reduce wear and deliver a silky-smooth drivetrain.
The Type-R features innovative front and rear ball diffs. This setup is the "ticket" for foam-tire carpet racing.
The modular design makes maintenance of the Type-R easier than typical touring designs.
Machined aluminum bulkeads and chassis braces provide an ultra-rigid platform that resists tweaking and provides easy access for maintenance.
The centered and rear mounted motor configuration improve traction and handling while increasing cornering speeds, making the Type-R easier to drive "on the edge".
The new ball bearing-equipped steering sytem utilizes smaller bearings for reduced weight, and delivers adjustable Ackerman with quick-response geometry for improved steering reaction and feel.
ROBORAT is offline
Old 09-01-2006, 02:41 AM
  #12027
ROBORAT's Avatar
as advised by mr.pitshop (aka fortress) himself, EP CLUB RACE IS ON for tomorrow at JP Raceway! woooohooooo! hapi hapi nanaman mga ep boys!
race starts 2pm! stock/spec and mod classes will be run. But is suppose that will adjust depending on the number of people who show up for each class. Suggest we all be prepared with our 19T motors so we in case we collapse the classes to just one ....
actually mas feel ko nga mag 19T bukas to further test the Komodo dragon ... pero bahala na bukas! see you all at the track!
ROBORAT is offline
Old 09-02-2006, 09:15 AM
  #12028
Sir sorry d ako nakalaro. Need to do some erands. anyway, musta ang race? Sana next week pwede nako mag laro ulit.
Jay: nag RC kaba sat?
Old 09-02-2006, 10:46 AM
  #12029
VooDooPH's Avatar
sayang di natuloy yung race.
pero masaya na rin.. at least nakapagpatakbo na rin ako. hehehehehe!
VooDooPH is offline
Old 09-02-2006, 08:30 PM
  #12030
|JayFlores|'s Avatar
yep, too bad nabiyak topdeck with my last pack with checkpoint. kaya i cant join you guys for the upcoming races pahinga muna ako.
