Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 04-18-2004, 09:25 AM
  #1111
Big Daddy Cool's Avatar
Trader Rating: 15 (100%+)
Robo: Hope to be able to run with you guys next time. I was there last Saturday afternoon running my TC3 and TA04. The TC3's epoxied rear shock tower did not last more than six minutes. Bumigay din ulit. I really have to get replacement parts soon. BTW, have you tried out Pitshop's rebuildable 23turn stock motors? OK ba yun? Yun kasi 23Turn Atlas ko ok pa rin kaya lang di rebuildable.
marvi: Kelan ulit kayo lalaro sa PS1?
Maddafunker: I missed out on the Speedzone night race last week. I found out too late kasi. Sayang.
Big Daddy Cool is offline
Old 04-18-2004, 09:52 AM
  #1112
KoK_KoK's Avatar
Arrow ta04-trf owners
mga sir tanong lang...
wana ask sana kung anong sukat ng preload (front and rear) sa dampers niyo according to the manual? short springs ang gamit ng ta04-trf diba?
and kung ano din ung sukat nung downstop screws (front and rear) according sa manual din?
reason: i wana try lang sana ung "box-stock" setup when using ung ssg shock towers and chassis.
also, how do i know what springs to use? i mean kung saan ung softer, sa harap o likod?
thanks.
KoK_KoK is offline
Old 04-18-2004, 10:57 AM
  #1113
babytoy101's Avatar
buti sila nka pag laro na huhuhu!
sana ako rin huhuhu!
robo : good luck sa pkikipag laban mo sa cebu, sponsored ka ba ni manong mang? hehehe! galingan mo bro and take care! picture ha!
babytoy101 is offline
Old 04-18-2004, 11:54 AM
  #1114
lem2's Avatar
Default Buti pa sila!
yun mga batterya ko tulog na---matagal na sila tulog!!
ROBORAT: so did you like the CGM? Read your post on the other thread and seems like you find the TC3, more planted? Have you decided yet what you will use in CEBU? If TC3-- yahoooo!!!!!
If you need anything for your kits as back up, text me B4 Tuesday. Will be in Boracay from wed to sun! ala nanaman RC!!!!!!
MANG: meron ka bang walkie talkie yunmaliit na pwede mahiram for the weekend? txt me!
Or is anyone selling? budget ko 2k hehehehehe
lem2 is offline
Old 04-18-2004, 06:31 PM
  #1115
evaa's Avatar
Default Re: Re: 414
Originally posted by Baluga
Bossing paki check yung attachment ko for confirmation kung yun naka circle ang tinutokoy mong adding additional spacer. Tnx ulit... Regarding naman sa spare parts, bibili na lang pala muna ako ng delrin outdrives and lightweight drive shaft.
Baluga: yep, thats the one.
suggestion lang, regarding the parts u want to purchase, yung delrin outdrives, napakatibay nyan. i hid the pipe dati sa kapitol and nachip ung delrin outdrive, pero hindi kinailangang palitan, very tough ung material nyan e. so i suggest you hold back on that, sayang lang, naka stock lang sa pitbox mo.
ung lightweight drive shaft, hindi ba kit standard yan? i think kasama na sa 414 yan.
yung rpm ballcups "i think" are too small for the tamiya ballcups, pero ok sana yan.
Kok_Kok: yup i agree with lem, grabe yang lrp micro charger na yan. ok sya for both nimh and nicd packs. the only draw back is may trickle charge sya, so you have to watch your nimh packs, baka maovercharge kasi.
also, dont cut the wires ha, may purpose yan kung bakit super haba ng wires, i almost cut those wires dati, buti na lang di ko naituloy.
evaa is offline
Old 04-18-2004, 06:49 PM
  #1116
ROBORAT's Avatar
lem: yup, the tc3 was more planted. but note that ive set up that car quite a bit and it is really quite balanced. the cgm as montioned is very smooth and is so easy to drive. too easy in fact that i'd like to dial in more agrressiveness into it. back end does not seem as planted as my tc3 but i think i can fix that. in fact baka nga nasa body lang. i used the mazda 6 on the cgm and a losi alpha in the tc3. i would have wanted to try the alfa on the cgm pero as mentioned, my run was cut short with a busted steering knuckle. cant wait to run this cgm in capitol and really work on its set-up. the car is defenitely very promising. i'll be bringing both cars to cebu.
babytoy: ang sponsor ko lang wallet ko. di ako umaasa na maganda takbo ko dun. di ako makakapag practis sa track kasi. so deretso karrera lang ako. bago pa auto ko sa baka tagilid tayo dun! hahahaha ok lang, lechon lang habol ko.
ROBORAT is offline
Old 04-18-2004, 06:53 PM
  #1117
joelt's Avatar
LEM2 and ROBO - Don't know if this will help but, I've set up my CGM as close as possible to what I used for the TC3 before. . . blue and silver springs, roughly the same turnbuckle locations, etc at happy naman ako. Maybe you guys can also try out setting up your CGMs this way and do fine tuning from there na.
CAPITOL SPEEDWAY V2.0
Hanep you CAPITOL tracks sa kines. It even looked like it didn't have any bumps at all . . . . to the point na pdeng pde ang 1/12!
My son really had a grand time running his TB01, specially with sand scattered in some of the sections. Drifting ala N4S Underground daw all the way to the open sewer on the side.
Eto pa ang maganda sa tracks. Expect spectacular air time when you hit the barriers and islands. Hindi pa kasi tapos eh. So sisiw ang reverse summersault with clockwise twist landing on all four wheels, as shown to us by PITSHOP BOSS using my CGM. . . . . . nothing broken after that!!!
Sana matapos na talaga within the week at matanggal na yung sand. In the areas kasi na alang sand, the traction was even better than that of Montalban!!!
BLP
joelt is offline
Old 04-18-2004, 07:40 PM
  #1118
ROBORAT's Avatar
BLP: i already know what i want to do with the CGM. one is to lower the ride height to 5mm para mas responsive steering and to make the car run flatter....nasa 6mm kasi kahapon since that was the suggested ride height for the cebu track. the other is to simply use a thinner sway bar in front and move the front ams back a notch. if that puts in too much steering, i'll just go down on spring tenssion in the rear to gain back some rear bite. so nothing major but should do a lot to get what i want out of the car. the car does turn in well but just not as good as my tc3 yet! i really made the tc3 a "steering monster" . im sure i wont have trouble doing the same with the cgm. all i need is a track to test on.
ROBORAT is offline
Old 04-18-2004, 08:27 PM
  #1119
Trader Rating: 82 (100%+)
racenut: ikaw ba yung naka-mini cooper na yellow (or orange ba yun?)
robo: pare, di ko talaga kaya yung nagawa mo, more than 1 month na sa yo yung car pero di pa nagagamit alam ko na kung bakit mo na-tap yung barrier - panay kasi ang lingon mo dun sa naka-pink btw, text me if youre gonna sell the F103 and at what price, nasabi ko na dun sa friend ko and he's interested.
BDC: nasa PS1 kami every sat morning, fun run lang using 23T motors. this saturday, meet kami dun around 9am then punta sa megamall para manood ng motorshow (para manood ng mga promo girls sa motorshow ) baka pwede ka, nood tayo (ng motorshow ) may lemans ka ba? dalhin mo rin kasi magpapatakbo din kami, naka sport tuned motor. as of now, mga 6 or more na yata kami dun. nabuo mo na yung F201 mo? sadly, i had to let go of my F201 (again), ibebenta ko na lang kay Tmak kasi natatakot ako gamitin sa PS1, konting tapik lang durog agad yung arms, even when using a mabuchi. e si Tmak, maraming pambili yan ng arms
madda: OK na yung fan? baka na overdischarge lang yung batt. dibale, pag ayaw pa rin umandar, soli mo na lang on sat. balik ko sa yo yung P 100.00 hehe. sama ka rin sa motorshow, nood tayo
marvi is offline
Old 04-18-2004, 08:52 PM
  #1120
babytoy101's Avatar
BLP
mukhang na binyagan na track ni mangski ah! hmmmmm!
mang matatapos na po ba! magkano na practice fee natin!
robo: kahit na walang practice, iba ka pa rin! wag mo sana sila ubusan ng lechon....... si lem ata pupunta ba?? si manong mang kaya?
Old 04-18-2004, 10:27 PM
  #1121
Default From USA
Hi Guys!
Just wanted to know where's the best track I can race at while I'm in Manila.
Thanks guys!
gido is offline
Old 04-18-2004, 11:46 PM
  #1122
rough512's Avatar
Default Re: From USA
Originally posted by gido
Hi Guys!
Thanks guys!
No comment on the "best" bit,
Try capitol speedway at the Pasig Capitol... It's presently being re-surfaced.
You can also try the track at The Fort in Fort Bonifacio and if you want a large track, there is one in Montalban.
The PS1 track is also open
rough512 is offline
Old 04-19-2004, 01:35 AM
  #1123
ROBORAT's Avatar
babytoy1: hehehe salamat sa kompyansa mo sakin pero magagaling din mga kapatid natin na cebuano mag rc. so kelangan ko talaga mag practice para magkaroon ng pag asa. hehehe ... di bale, pag dating sa lechon, di ako papatalo. di ko alam kung pupunta si doc lem, mukahng may ibang lakad eh. si pitshop di rin ata sure. mukhang ako lang if ever. ok lang, masaya naman kasama mga cebu boys.
ROBORAT is offline
Old 04-19-2004, 04:07 AM
  #1124
buboy28's Avatar
Hi Guys!
Thanks guys!
if you are racing off road there's the qc circle off road track and the covered JP RACEWAY off road track at ortigas ave and if you are racing on road there is also one in pinagbuhatan, pasig plus the tracks that has been mentioned by Rough512
buboy28 is offline
Old 04-19-2004, 05:24 AM
  #1125
chambalero's Avatar
Default Re: 1st CGM Test Run
Originally posted by ROBORAT
finally ran the cgm today at park square. the car is smoooooth! thing is i was only able to run two packs with it up until i hit a barrier and snapped a steering knuckle. generally the car is really easy to drive but i will try to dial in some more steering into it to make it turn in harder. pero pag ginawa ko yun malamang medjo bibitaw na yung pwet kasi it did not feel that planted .... so malamang pati rear end kelangan ko rin i-fine tune. of cors note that this is at the ps1 track which has a very simple layout so its hard to say how it will behave in a track with tighter lines. but, im very hapy considering it ran very well without playing around with the set-up.
so, since sira na yung knuckle, labas na ulit si tc3. i have to say, despite tis age, tindi talaga nung auto na 'to. aggressive pero planted - parang naka riles. so i ran three more packs with the tc3 and had a blast. i think i'll be keeping this ride so i can join dual classes at races.
hmmm... parang gusto ko ilabas from retirement tuloy yung tc3 ko i have a cgm that i'm gonna start building pa lang and i thought it is a suitable car to replace the tc3. i agree with you that the tc3 is definitely planted. do you think it can be set up to behave like the tc3?
chambalero is offline
