Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 04-16-2004, 05:19 AM
  #1096
Dongskie's Avatar
Trader Rating: 44 (100%+)
Hello Mate!
Dongskie is offline
Old 04-16-2004, 05:29 AM
  #1097
oro27's Avatar
Trader Rating: 33 (100%+)
Dongskie,
Mukhang bored ka na diyan ha!?.... Uwi na. Miss ka na ni Kenneth.
oro27 is offline
Old 04-16-2004, 08:06 AM
  #1098
lem2's Avatar
Default QUADRA
Originally posted by KoK_KoK
nakalagay naman dun sa box nung quadra pwede daw nimh... pero im not so sure lang talaga...
Kok_Kok,
That charger is okay, it can charge both NiCd and NiMh. Up to 6 amperes. It also has a trickle charge. . . .
But. . . . .
Hindi pa ganun ka perfect yun system, still false peak and over charges your batteries...sometimes!!!
I got that charger because ala power supply!
I bought mine at Lil's and sold it less than 5 months used....
may balance pa nga yun kumuha ng PhP1,000---- kalimutan ko na pangalan, pero nitro boy siya from south metro, kakainis talaga....
kailangan mo lang bantayan ang batteries mo after mga 25 minutes of charging, honestly mas maganda pa yun LRP micro.
Yun kumuha nga LRP QUADRA ko, 2 years ago na yun!!!!
lem2 is offline
Old 04-16-2004, 08:09 AM
  #1099
lem2's Avatar
Originally posted by ROBORAT
lem: would you still happen to have you KO crystals na 40 or 41 mhz na frequency? would like to borrow sana kahit one pair as extra. will be in cebu next weekend i mite have time off on sunday so that would mean i mite be able to join the race there. mite need lang to have an extra crystal just in case may ka parehas or kalapit akong frequency. thanks.
Sorry sir, naisama ko na when I sold my Tx and Rx's.
lem2 is offline
Old 04-16-2004, 08:51 AM
  #1100
Baluga's Avatar
Default Re: 414
Originally posted by evaa
basically, yang 414 tank yan e, cguro if your going to keep spare parts, try mo ung arms, kingpin, hinge pin, lagi kasi nabebengkong yun, one way outdrives, belts. Try cleaning the bearings din, thats one thing i failed to do nung may 414 ako e.
ung nasa steering linkage di naman nasisira ung bearing dun.
good luck on the car, also, may tip ako sa u, ung camber link sa rear, make sure na meron ka at least 2 spacers to adjust the roll center. i found out the hard way kasi na the 414 reacts to changes in roll center in the rear. pag less than 2 ung spacers very twitchy yan.
hope this helps.
Bossing paki check yung attachment ko for confirmation kung yun naka circle ang tinutokoy mong adding additional spacer. Tnx ulit... Regarding naman sa spare parts, bibili na lang pala muna ako ng delrin outdrives and lightweight drive shaft.
Attached Thumbnails Electric Touring / On-Road RC-getuserimage44.jpg
Baluga is offline
Old 04-16-2004, 08:56 AM
  #1101
Baluga's Avatar
Originally posted by rough512
Balugs,
Tama si Lem, walang masyadong masisira sa 414 na parts na specific 414 lang...
Siguro stock ka na lang ng Kingpins, steering blocks at c-hub carrier, spur and pinion gears at palit ka ng ball cups, kunin mo yung RPM.
Yun lang!!!
Yung flange bearing ng steering plate, hindi mo naman siguro masisira yun, bukod sa minimum load e ni hindi nga nakakaisang revolution yun kahit na anong steering pa gawin mo heheheh...
Hindi pwede RPM ball cups sa tamiya ball connector. Malaki sobra yung "BALLS" ng tamiya. Bili na lang muna ako delrin outdrives, tsaka na spare parts tutal may kasama naman basic parts.
Baluga is offline
Old 04-16-2004, 05:12 PM
  #1102
rough512's Avatar
rough512 is offline
Old 04-16-2004, 10:24 PM
  #1103
buboy28's Avatar
Post
Originally posted by Dongskie
Hello Mate!
Dongskie bat naiba ata address mo, mukhang australian citizen na dating mo dyan ka na ba for good o long vacation lang
buboy28 is offline
Old 04-17-2004, 03:08 AM
  #1104
racenut's Avatar
Trader Rating: 15 (100%+)
kennet, marvi
nice race guys, kahit kinawawa nyo ko!!!
racenut is offline
Old 04-17-2004, 09:55 AM
  #1105
KoK_KoK's Avatar
Default Re: QUADRA
Originally posted by lem2
Kok_Kok,
But. . . . .
sir thanks for the clarifications.
question lang po, i have a micro charger ng LRP and it says dun sa sticker nya "nicd batteries only" pero i read sa box na pwede daw nimh dun sa micro, which one is correct?
anyway, might get a millenium pro nalng din talaga... baka kapos ang isang charger samin ng bro ko.
KoK_KoK is offline
Old 04-17-2004, 10:01 AM
  #1106
lem2's Avatar
Default Re: Re: QUADRA
Yes it can charge NiMh already. If you compare the charge of the Quadra and the Micro--- you will see namay punch yun Micro. hehehehehehe Weird but True!!
See you soon!
lem2 is offline
Old 04-17-2004, 10:08 AM
  #1107
KoK_KoK's Avatar
lem2: thanks po ulit. i'll try that nga, nakakaintrigue un ah.
that is pagnakabili nako mga batts... dami pa kulang...
anyway, thanks po ulit sir.
KoK_KoK is offline
Old 04-17-2004, 10:09 AM
  #1108
lem2's Avatar
Default Geetoo
Hi, on your thursday night races what brand of 23T motors are used? Only/Stirctly Tamiya? Or pwede din yun ibang brand by other Jap Manufacturers na fixed endbell pero may bearing?
Thanks Lem
lem2 is offline
Old 04-18-2004, 07:19 AM
  #1109
ROBORAT's Avatar
Arrow 1st CGM Test Run
finally ran the cgm today at park square. the car is smoooooth! thing is i was only able to run two packs with it up until i hit a barrier and snapped a steering knuckle. generally the car is really easy to drive but i will try to dial in some more steering into it to make it turn in harder. pero pag ginawa ko yun malamang medjo bibitaw na yung pwet kasi it did not feel that planted .... so malamang pati rear end kelangan ko rin i-fine tune. of cors note that this is at the ps1 track which has a very simple layout so its hard to say how it will behave in a track with tighter lines. but, im very hapy considering it ran very well without playing around with the set-up.
so, since sira na yung knuckle, labas na ulit si tc3. i have to say, despite tis age, tindi talaga nung auto na 'to. aggressive pero planted - parang naka riles. so i ran three more packs with the tc3 and had a blast. i think i'll be keeping this ride so i can join dual classes at races.
ROBORAT is offline
Old 04-18-2004, 07:28 AM
  #1110
ROBORAT's Avatar
Thumbs up PS1 Track
Tommi/Rnold: you guys have a great track. i had a blast running there this afternoon. superb traction and generally smooth as i was able to run my tc3 at 5mm without any trouble. a few small bumps but really nothing major.
it would be nice if you could refine the layout a bit to maximize the track size. people told me the track was small but honestly i think with the right layout, it's the size is sufficient. there's really enuff length in the back stretch to satisfy any speed freak's urge. i think its just a matter of making the most of the space especially at the end of the straight coming into the sweeper, and the in-filed infront of the driver's stand. the switchbacks can be refined quite easily by moving the boards just a bit - and i mean nothing major really. you wont even need additonal boads, the one's there will suffice. very minor stuff but they should make a big difference and add more passing sections, nake it more challenging, of course more fun, and make for really great racing. hope you guys dont take this the wrong way, like i said i had a blast and would surely go back. now i have a place to go when i have nothing to do one sunday's.
marvi: sa uulitin pare. sarap tumakbo. its been a loooong while for me. 2months na ako di naglalaro. buti nalman at nabuhay ko na ata mga cells ko. next time laro tayo ulit. bring your 12th scale, i can lend you 4-cell packs. keep in touch pare!
BDC: next time unahin mo an rc sa pamilya ha! di maganda mga asal mo. priorities naman pare! hehehe loko lang bro. laro tayo minsan. alokin natin si doc para mabugbog natin yung ova nya! hahahaha
ROBORAT is offline
