Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 04-09-2006, 10:33 PM
  #10726
joelt's Avatar
Originally Posted by tochidet
Robo: Sori ha wag mo na intindihin yung listahan na yun kay joel lang yun enjoy naman ndi ba? pakwela lang yun hayaan mo sagot ko na ang C2 mo sa next race natin
Dapat pala pati ako mag galit-galitan para ma-libre ng C2!!!!!
Sapat na ba 'to?
joelt is offline
Old 04-09-2006, 10:54 PM
  #10727
ROBORAT's Avatar
tochi: oo masaya naman .... pero c2??? PIZZAAAA!!!! pare, 19T turn next week! call ka? tara na para masaya!
jt: im game for 19T! lets do it! .... teka, payag ka na sa C2?! wag!!! HAHAHA
ROBORAT is offline
Old 04-09-2006, 11:03 PM
  #10728
joelt's Avatar
Oo nga naman, bakit C2 lang???
PIZZA!!!
joelt is offline
Old 04-09-2006, 11:36 PM
  #10729
rough512's Avatar
Originally Posted by ROBORAT
rough:
if i may suggest, at most just do the following:
1. mill out the stand-off mounts on the upper deck..
- tanggalin ko na lang muna yung posts
2. run 30wt oil all around.
- Okay, gagawin ko ito
3. silver springs all around.
- wala pa ako nito . I'll try using yokomo silvers, xray orange, and tamiya reds (soft) muna
4. use a black sway bar in front and none at the back.
- done (tamad lang ako magtangga
5. no kick-up, anti-squat, etc ... run the car flat.
- may nakalagay nang spacers under the suspension blocks.. flat pa din naman pero naka-angat. try ko muna daanin sa rollcenter, pangcompesate sa softer springs
6. run a one way. if its too twitchy/responsive, try a diff. avoid spools for stock/spec racing. too much drag slows you down in the corners.
- dito ako umaasa. Kakabili ko lang ng 1way gear kay mang nung saturday
rough512 is offline
Old 04-09-2006, 11:54 PM
  #10730
joelt's Avatar
Oist galingan mo dyan sa pag-aayos mo. Humusay na ang Weiner. Pretty soon, sya naman ang magkakaroon ng Hit List tulad ni TOCHI. . . . And guess who he will be starting with in his list???
joelt is offline
Old 04-10-2006, 12:06 AM
  #10731
ROBORAT's Avatar
rough: you mean hanggnang ngayon gamit mo pa rin ang stand-offs?? i remember suggesting that to you before already. anyway, try it ... it will give much better overall traction and the car will run better over the bumps making the car more consistent. tnaggalin mo rin yung center spine. blue spriings all around should be ok as well especially if you are running 40 wt oil.
keep the spacers on the arm mounts. just be sure the suspension arms run flat even with the spacers on. wag ka na muna mag experiment sa roll centers (via camber links & arm mount hieght). pag laruan mo muna shock position. mine are leaned in all the way in front and for the rear its in the 2nd to the inner most hole.
if i may ask, ano ba ang kulang sa handling ng auto mo? the one way will give more steering in general but i dont know if that is what you want/need.
ROBORAT is offline
Old 04-10-2006, 12:31 AM
  #10732
rough512's Avatar
JT: balita ko nga ambilis na daw ni weinner e.
Robo : once ko pa lang napatakbo yung tc4 na may oneway and nagkataon na ginawang 19t yung race so hindi ko naramdaman masyado yung advantage. Pero tingin ko yung 1way talaga ang kulang... with dual ball diff kasi nasisingitan ako lagi dun sa chicane. e yun pa naman ang isa sa pinakamagandang spot for overtaking.
rough512 is offline
Old 04-10-2006, 01:36 AM
  #10733
ROBORAT's Avatar
rough: makaka tulong nga yung one way dun sa chicane. pati sa double apex. anyway, try mo muna. the sway bar up front will keep the car flat as it transitions through that section and taking out the one in the rear will keep the rear end planted naman. ... 19T tayo sa "hello" race ni lem ha! para sama sama tayo.
ROBORAT is offline
Old 04-10-2006, 01:48 AM
  #10734
Maddafunker's Avatar
Robo: When are you running this week? Wanna try the new baby sana.
Maddafunker is offline
Old 04-10-2006, 02:28 AM
  #10735
joelt's Avatar
Default LEM2's HELLO RACE
LEM2 - Your call sir, since ikaw naman ang GUEST OF HORROR sa event na ito. Pdeng 19t ang mga OLDIES and NEWBIE PRETENDERS (like ITIM, ROUGH, BBTOY, etc) tapos, 27t naman ang traditionally nating tinatawag na WACKIES.
Watutink???
joelt is offline
Old 04-10-2006, 02:37 AM
  #10736
ROBORAT's Avatar
... whatever happened to the wacky class nga ba? that was such a good way to get noobs to get into racing. but maybe we should just call novice class rather than wacky class ....
lem: 19T ka na rin!
ROBORAT is offline
Old 04-10-2006, 02:39 AM
  #10737
ROBORAT's Avatar
madda: sori, no racing for me this week/weekend..... next week na ako for the race for doc lem.
ROBORAT is offline
Old 04-10-2006, 02:41 AM
  #10738
rough512's Avatar
oo nga... hehehe... di naman wacky magdrive mga bago ngayon... heheheh...
rough512 is offline
Old 04-10-2006, 04:21 AM
  #10739
barug's Avatar
rough: gaya ng sabi ni robo, wag mo intindihin ung sa international thread. masyado lang nga maangal ung mga tao don. i'm very happy with my tc4. the set up that i have now works very well for me, with a one way of cors. i'm planning to run on wed sana pero pag di natuloy baka sa sat na din. see u!
barug is offline
Old 04-10-2006, 04:31 AM
  #10740
Joelt/Robo: Ok 19t naman tayo pwede kaya tayo sa JP? Yun ay kung ok sainyo para macheck ko expiry ng agimat ko dun
tochidet is offline
