Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 03-03-2006, 08:42 AM
  #10261
ROBORAT's Avatar
madda: game! i can lend you a motor. si mang may mga donuts pa!
ROBORAT is offline
Old 03-03-2006, 08:55 AM
  #10262
rc_kangkaroots's Avatar
ASSALAMUALAYKUM mang si abel ito malapit ko na makita dito sa saudi ang lampara ni 'ALLADIN' pag nakuha ko na unang wish ko bigyan nya ako ng pinakamagaling na ''RC' ung walang tatalo diba'''' anyway kamusta na sa mga tropa sa capitol see you in november karerang karera na ako tlaga lng
rc_kangkaroots is offline
Old 03-03-2006, 05:24 PM
  #10263
curious mind's Avatar
Abel!!! pare musta na? -bing
curious mind is offline
Old 03-03-2006, 08:29 PM
  #10264
XTREMERCHOBBIES's Avatar
Curious - we have 1/12 associated kits in the shop P7,000 lang
Robo - bubuo ako ng spx12 pag okay yung test run natin
Mada - spx12 is not yet available, we still have to see if the 1/12 will run smoothly in jp's track.
XTREMERCHOBBIES is offline
Old 03-03-2006, 08:34 PM
  #10265
pitshop's Avatar
Trader Rating: 56 (98%+)
abel --> Naalala mo ba yan si bing... siya yung kasama sa Kirei na
mahilig sa MALALAKI
pitshop is offline
Old 03-04-2006, 09:07 AM
  #10266
Abel si chito to kamusta ka na pare? panay pa rin ang karera namin dito ok ang JP indoor track siguradong magugustuhan mo sige pare post mo yung mga ginagawa mo jan
tochidet is offline
Old 03-04-2006, 07:26 PM
  #10267
|JayFlores|'s Avatar
Default March 4, 2006 race
mga Sir thanks..
boss pitshop, sa pakarera
lem2, for the traction compound!
rbboy, sa rear belt! laking tulong pare (pasensya sa hassle)
jayps, sa yosi hehe
mungoy, thanks for joining too next time pare
tantalus007, kaw ah kausapin mo naman hehehe "kapatid"!
and sa lahat narin!
-Jay
|JayFlores| is offline
Old 03-05-2006, 06:44 AM
  #10268
mitsubishi: Musta ka na pre? magkikita nanaman tayo sa stock touring pang ilang taon na ba to? See you pre
tochidet is offline
Old 03-05-2006, 08:47 AM
  #10269
carfreak33's Avatar
Default batts
tanong lang po... sorry to be way off topic pero nu po ba pwede charge rate at cut-off para sa sanyo 3300? gamit ko po CE pitbull(yung blue version di yung bago...)help lang po long-time newbie here thanks!
carfreak33 is offline
Old 03-05-2006, 08:55 AM
  #10270
Talking NEW ARRIVALS
DC Motorsports NEW ARRIVALS!!!
- Extreme Voltage Intellect Batteries 4200, 6-Cell Pack, 35 Amp 1.120v+ Matched & Zapped Cells
- Battery Bars
- New Z-Zone Evo-27 (New generation rebuildable Stock motor)
Features:
· 27 Turn 22 gauge wire
· 24 degree fixed timing
· Low Friction Bushings
· 3 surface mount capacitors built-in with blue LED indicator
· 6 large venturi cooling vents
· Extensive use of copper material on endbell to keep operating temperature low
· Extended armature shaft for easy tech inspection
· Low armature mass for quicker spool up
· Use normal laydown springs and standard laydown brushes
· Easy to tune
· Meets all ROAR & NORRCA mechanical specification.
The Evo-27 stock motors are hand tuned and tweaked for maximum performance. Here’s a list of what every spec motor receives…
-Magnets Zapped
-Armature Balanced
-Diamond trued commutator
-Armature shaft polished
-Bushings reamed and polished
-Armature centered in magnetic field
-Brush hoods aligned to provide proper brush/comm commutation
-Spring tension optimized for maximum performance.
-Commutator timing inspection; insure overall motor timing is not less than 24*
-Each motor is dyno tuned & tested using CE Turbo 45 dyno.
-Dyno sheet included
DC CHECKPOINT with UL ARMS WILL BE ARRIVING SOON TOO
VISIT THE SHOP TO SEE
Old 03-05-2006, 10:06 AM
  #10271
pitshop's Avatar
oops wrong post
sa for sale pala...
pitshop is offline
Old 03-05-2006, 03:13 PM
  #10272
paulc's Avatar
jason/maebelle : ygpm
paulc is offline
Old 03-05-2006, 05:42 PM
  #10273
puroy's Avatar
woohooo .. sarap pala mag drive sa isang track.... actually dalawa pang track ang nasubukan ko sa isang araw.. hehehe... first time ko talaga sa on road track... hehehe
sir tutoy! TSALAMAT ng marami sa tips at pagtabi sa pit table, pagpapagamit ng discharger mo... lalo na sa tires at pakikisabay papuntang JP...
FBJ,JoelT, Doc Lem, Highwayman, Jay, Weiner (tama ba spelling?) at sa iba pang na-meet ko nung sat... Nice meeting you all! Next time ulit...
Kailangang matutong magdrive! hehe
Sensya na rin sa mga naabala dahil sa 0% driving skills ko.
-alwyn
puroy is offline
Old 03-05-2006, 06:31 PM
  #10274
Maddafunker's Avatar
Robo: Ayuz! Hukayin ko yung kit ko. Kailangan pa i-rebuild yun. Pahiram na rin ng ESC, baterya, charger, radyo. Joke! Hehehe.
Xtremehobbies: Ok. When are you testing your 1/12?
Maddafunker is offline
Old 03-05-2006, 07:05 PM
  #10275
ROBORAT's Avatar
di naman off topic post mo. electric forum to so this is actually where you should post a question like that. you should be good with a charge rate of 5amps. di ko alam pano settings sa pit bull pero usually for old gp 3300s, set the volt threshhold as low as possible (ie. 0.2mv per cell).
ROBORAT is offline
