Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 02-14-2006, 05:53 PM
  #9886
curious mind's Avatar
Japys: pare Nice avatar!! yan ba yung reteat master nyo? wink:
curious mind is offline
Old 02-14-2006, 06:13 PM
  #9887
FBJ's RDX's Avatar
Originally Posted by ROBORAT
fbj: balak ko na nga rin mag ride accord (pero out of stock pa) or the 3.0AP for my ride. i need that little extra steering .... in the meantime, i'll try some set-up changes (droop, shocks, dampening, etc) this weekend and see if that helps.
I suggest try mo yung 3.0AP, Meron ako na 3.0 and Accord na u can try, butasan mo nalang. Jason and I kasi have the same experience with the Accord, tends to have too much forward traction most especially when your tires are new. Medyo you will need 1 major tuning change to make the accord really aggressive when your tires are new. Pero it is excellent when your tires are old and srubbed, perfect balance agad. That's why that's the body I use when I dont have new tires, ok parin lumiko, but when I have new tires, I use the Much More Stratus body.
FBJ's RDX is offline
Old 02-14-2006, 06:34 PM
  #9888
Fatboy Joe's Avatar
Anyone running EP tonight at JP's Track?
Fatboy Joe is offline
Old 02-14-2006, 06:54 PM
  #9889
LaMusica's Avatar
Hi i'm a noob to this with not much knowledge on how to run or customize an RC car. I dont have one yet but i'am getting a TA05 with a 10 turn motor and berrings any suggestions or help on where to get parts etc?
LaMusica is offline
Old 02-14-2006, 08:18 PM
  #9890
ROBORAT's Avatar
FBJ: is that the stealthy 3.0 that you used last satrday? ... stealthy kasi di ko alam ikaw yun! hahahaha if you dont mind, id like to try it out.
ROBORAT is offline
Old 02-14-2006, 09:20 PM
  #9891
FBJ's RDX's Avatar
You can buy parts from Lil's for your Tamiya. If you intend to be in the hobby for a long time and plan to be competitive, I suggest you consider getting a different brand which has more value for money in the long run. Just my .02
Yup, that was my 3.0 Stealth body, hehehehe. Sure, no problem, you can try it out
Old 02-14-2006, 09:30 PM
  #9892
joelt's Avatar
LA MUSICA - FBJ is right. The TA05 is an excellent entry-level kit, but it does have it's limitations for the long haul. Also, you might want to consider starting with a milder motor instead on 10 turns. This may be too fast for you to start with, and you might just end up having too many unnecessary breakages. My .02 - start with a stock 27 turn or 23 turn motor and go up from there as you get more used to driving.
joelt is offline
Old 02-14-2006, 11:15 PM
  #9893
joelt's Avatar
im not a hundred percent yet if i can run at JP's on thursday. i really want to though .... pero 100% for sunday! gusto ko na mag-modified! woooohoooo! hehehe
babytoy: punta ka ba JP sa thurs? kung sakaling maka-daan ako, iwan ko brood ko na 19T sayo .... alam mo na kung ano gagawin dun! ... it needs a buzz!
It's Sunday for me for sure. MODIFIED!!!!
. . . . Nakakatakot na rin kasing kasabay na ngayon sila FAFATY, RUFF, at ITALIANI sa stock eh, dahil panay homicide na ang pinag-uusapan duon pagdating sa motor at baterya
joelt is offline
Old 02-14-2006, 11:43 PM
  #9894
LaMusica's Avatar
Whats a .02? What key points should i customize in my TAO5?
LaMusica is offline
Old 02-14-2006, 11:47 PM
  #9895
joelt's Avatar
Whats a .02?
It's an expression for sharing unsolicited/unfounded/biased/purely opinionated advices i.e., "my 2 cents' worth".
joelt is offline
Old 02-14-2006, 11:49 PM
  #9896
babytoy101's Avatar
speaking of the italiani.... theres a rumor that he is a native of north part of luzon! hehehe!
and a decendant of a very famous tribe in tarlac! hulaan nyo! nag iisang species yan.....
babytoy101 is offline
Old 02-14-2006, 11:54 PM
  #9897
KillWency's Avatar
I highly suggest you get a 2nd hand HPI. It's unbreakable and very adjustable. I dont suggest any other brands like ae, yokomo in the same price range they are very easy to break even with "experienced" racers. But they are fast. It will cost an arm and a leg to replace parts for these brands.
And start with a silvercan. Dont rush into 27 turn roar stock or 23 turns. Just gear up your silvercan if you think you can handle the speed without hitting anything. In singapore most people run silvercans geared at 4.8 to keep cost down on club racing. Of course there's always 8 min 23 turns races for advance racers.
KillWency is offline
Old 02-14-2006, 11:55 PM
  #9898
LaMusica's Avatar
Oh ok cool.
LaMusica is offline
Old 02-14-2006, 11:57 PM
  #9899
joelt's Avatar
IMHO, get a stock motor, leave your TAO5 as it is for the time being and enjoy the hobby. Modify when you're ready and not while you're getting used to the needed driving skills.
When do you consider yourself ready? - When you can regularly drive your TAO5 around a race track with hardly any mistake (using a stock motor). Running up and down the street won't really count, as this essentially only teaches you how to accelerate and decelerate.
What order of modification do you follow, when you're ready? - Tires, body, suspension, drivetrain, batteries, motor.
joelt is offline
Old 02-15-2006, 12:06 AM
  #9900
ROBORAT's Avatar
jt: yea baby! MO-DI-FIED!!!! hehehe
ROBORAT is offline
