Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 03-30-2004, 10:33 PM
  #841
rough512's Avatar
Ganun pa din...
Txt ng txt... set ng meeting daw.... uusyosohin ang kit... babaratin... babalikan daw.... tapos maglalaho na na parang utot...
hehehehe...
Buti pa mga taga-ibang lugar, mas sigurado pa pagdating sa deal... dapat yata singilin na din pati yung mga txt na nagamit hehehehe
rough512 is offline
Old 03-30-2004, 10:34 PM
  #842
babytoy101's Avatar
Default Trinity T-SPEC
another shaft driven baby! dami shaft ah! eto pics!
Attached Thumbnails Electric Touring / On-Road RC-tspec.jpg
babytoy101 is offline
Old 03-30-2004, 10:36 PM
  #843
rough512's Avatar
anong kit yan?
rough512 is offline
Old 03-30-2004, 10:39 PM
  #844
babytoy101's Avatar
Originally posted by rough512
anong kit yan?
trinity T specs!
Features include: Spec Motor, Spec battery pack, T-Spec body, Shaft Drive, Aluminum Drive Shaft, Aluminum Drive Couplers, Ball Differentials, Pillow Ball Suspension, Adjustable Caster, Adjustable Camber, Adjustable Toe In/Out, Front & Rear Droop Screws, Ball Bearings, Threaded Body Oil Filled Shocks, Heat Sink Motor Clamp, Stick or Saddle Pack, Rear Sway Bar and Motor Heat Sink.
  #845
babytoy101's Avatar
anong kit yan?
trinity T specs!
what do you think?? should we change to shaft drive?
Old 03-30-2004, 10:45 PM
  #846
rough512's Avatar
stock touring ... siguro dapat mag-shaft na rin tayo....
Mod... belt pa din siguro...
rough512 is offline
Old 03-30-2004, 10:51 PM
  #847
babytoy101's Avatar
napapa-isip 2loy ako sa sd ni kenneth! sa bagay magaan na rin tong losi susubukan ko muna!
Old 03-31-2004, 01:00 AM
  #848
racenut's Avatar
Trader Rating: 15 (100%+)
dong,
may Tekkin na uli???
racenut is offline
Old 03-31-2004, 04:09 AM
  #849
paulc's Avatar
say hi for me when you see him again. or does he log on? Siya ata yung nag iisang pinoy na na feature sa isang RC mag before, the topic was about R/C drag racing.
Kilala din ni mang yan, kasabay nya sa nitro sa boyel before. lol... GP10 pa gamit nila noon, with the wide "euro" style bodies...eheheh, electric din naman noon, wide. sigh....
Originally posted by Tommi Makkinen
yup. the same mike... he told me na he raced before in boyel many times... including the out of town races...
paulc is offline
Old 03-31-2004, 05:35 AM
  #850
judd's Avatar
mga sir pag pinalitan ko ba ung front suspension tower ng tc3 ng pang back para makabitan ko ng tamiya body mag iiba ba handling ng car?? salamat po!
judd is offline
Old 03-31-2004, 05:52 AM
  #851
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
Originally posted by Wency_TA03R-PRO
Bosing tommi kung dead set n ung ESC.. may possibilities p b n marepair yon??..
depends... dependot ,este, depends sa esc. some esc's pwedeng i-repair pag na-dead set as you put it... but some like the newer ones na naka maliit na fet like yung quantum medyo hopeless case na yun...
Tommi Makkinen is offline
Old 03-31-2004, 05:57 AM
  #852
he doesnt go online unfortunately. but i got his cel number. im getting in touch with him kasi marami sa Nueva Ecija naghahanap ng mga RC stuff... sayang nga e, if i had brought my RC's for sale, garantisado sana sold dun. daming nagtatanong sa mga gear namin, loaded pa mga pitaka nila...
kinuwento nga ni mike yung feature nya sa RC Model Cars... kaso his only copy of that mag nasa states with his parents... he still has his Drag RC ride. it was a Bolink Pro Stock Car...
Old 03-31-2004, 09:50 AM
  #853
...of course.
TambokGT is offline
Old 03-31-2004, 09:52 AM
  #854
lem2's Avatar
Yes it will! But for the better!
lem2 is offline
Old 03-31-2004, 06:14 PM
  #855
joelt's Avatar
JUDD - To add to what LEM2 has said, switching shock towers is actually one of the more common mods done to both TC3s and SDs (Black Special and SSG). Being so, what Rayspeed and Yokomo (for their SD CGM) eventually did was to make their front shock towers look pretty the rears straight from the box.
Am a bit concerned though with what you plan to do, unless you're really after looks only. Using a Tamiya body (with the original mounts) may not be the way to go if you plan to compete. Protoform bodies (Stratus v1/v2, Alfa v2, Mazda 6) may be the better choice, although they aren't as scale looking as Tamiyas.
Also, I've heard that the price of a Tamiya body has increased, so medyo sayang if you intend to use these for racing. You won't be able to compete in TAC races din naman since your chassis is a TC3.
. . . . Opinion lang nga ito sir.
BLP
joelt is offline
