Electric Touring / On-Road RC
#8341
MR SHIMS, JAYPS, DR DETABALI, ROUGH - Oh ano, call? Magsarado na kayo para malaman ko kung maghahanda ako ng stock motors (at tamiya tb01) para masters o hindi!!!
#8342
di naman ako manginginom a. Napapainom lang ako pag nasa Pashig Tracksh ako. Once in a blue moon lang ako umiinom, nakakasira daw kasi ng brain cells yung alcohol.
Okay yung picture pero lasing yung camera... Di ko matrace kung kaninong hita yung nasa picture hehehee
#8343
Sir Joel RBBOY JAYPS ROUGH DR. Detaballi and all sa class. Game
,,, "SHOT" race lets say round two or three ? kumg kelan pwede lahat. Papapili pa natin yung beverage of choice sa mga Connoisseurs... we have Grand Matador 05, Emperador 05, SML 05, Tanduay 05, puro 05 lang para mura
RBBOY check out ko yung site, 90% sure as long as hindi prop yung eroplano...
#8344
Tekin's newest G11 series of speed controllers uses the most advanced technology available today to create a speed control that provides virtually limitless multiple setup tuning options (over 600,000) of every critical operating parameter. "Finally a speed controller that adjusts to your style of driving, not you adjusting to what the speed controller will allow you to do." (Kraig Kruger) New Features: New super FETs give you Ultra Low On-Resistance. All new software, You can hear the difference in your motor on the bench. Makes this speedo the fastest one yet. The newest components available for today's market. No caps are needed, you don't need to use a fan. Buy it, install it, race it and win. Pretty simple. Team Tekin only had one entry at the recently concluded International Indoor Championships that was held in Vegas, Team Tekin Driver Jeff Cuffs won the Stock Foam Sedan Class with the new G11 Pro.
SPECS:
Updated Software and Components
Adjustable Drive Frequency: 1 - 11 kHz
Adjustable Brake Frequency: .8-8.8 kHz
Current Limit: 10-90 Amps Bypass
Low On-Resistance: G11 0.0008 / G11 Pro 0.0003
BEC: 6.0V / 5.0A
Motor Limit: 4-8 cells None (8-12 cells,12 turns)
G11 part number TT1035
G11 Pro part number TT1040
"The Doctor is in. "
Tekin's all new Battery Doctor 8.0 is just another part of that winning combination from Tekin.
The Battery Doctor discharge tray increases performance in both new and older packs by safely discharging each cell down to 0.5 without the risk of accidental reversal.
The Battery Doctor features a Non-Polarization tray. Which means you don't have to worry if you put your batteries in the correct way.
The Battery Doctor discharges your battery at an even 2.0 amps. This allows the batteries to finish their discharge while keeping the heat down and extending the life of your batteries.
Each cell in your pack will be discharge down to a low 0.5 volts. Again protecting your cells from damage and extending the life of your pack.
You can discharge from 1 to 8 cells at a time. 4 cells racers you can now discharge two packs of batteries at a time.
With LED lights on each battery tab you can keep track of your discharge and know when it is safe to take your pack out.
The Battery Doctor is a must have if you are serious about your batteries.
Tekin BC112A
Modified Motor... TOSOLINI Edition 8x1 Ti platform (BLUEPRINTED)
19T Reedy Quad Magnet TAGGED/SPEC LEGAL (BLUEPRINTED)
27T STOCK: Epic & Monster based TAGGED/SPEC LEGAL (BLUEPRINTED)
GET 'em NOW!!! be ready for MASTERS
#8345
Anong ibig sabihin ng blueprinted? Naririnig ko yung bluprinting sa gearbox, di ko rin alam ibig sabihin. Ang alam ko lang na blueprinting yung sa design sheets ng engineers.
Sa mga nakakaalam, Pa-explain naman po
#8346
BLUEPRINTED - Term ito na ginagamit originally for american muscle engines that were torn down and rebuilt as specified in their respective 'blueprints'. Nuong kapanahunan kasi ni KURIPs, nde pa ganun kalapit ang mga tolerance ng mga motor na ina-assemble. As a result, one typically would not be able to draw the maximum horsepower from a stock motor that came straight from the factory.
#8347
Ah ganun pala yun. Thanks JT.
Yung motor ko bluepainted.
May alam ba kayo panggamot sa epekto ng pagkatalo natin nung sat? parang may burnout ako. Di ko masimulan maski mag-tape ng chassis or maglipat ng electronics for this Saturday's series.
#8348
rough: madali lang yan! gamitin mo na LCG mo .... nakakasama talaga sa pakiramdam yung pag gamit ng lumang kit kahit meron ka nang bago! hehehe
may diff covers na naman e so non-issue na yung ma-damage mga gears mo from track debris!
LCG! LCG! LCG!
honestly though, theres nothing like running a new kit. it helps keeps things fresh since its a new toy to tinker with. pansin nyo ba na ako i change kits like twice a year? i sell the old one then save up a bit to cover for the difference to get a new one. i only keep one kit at a time though. para hindi mahal mag maintain. you have a new kit just laying there waiting to be used -and its a better one than what you currently use so that alone should be somthing to look forward to.
kung baga it keeps things interesting kasi iba na sine-set up mo and then you learn to adapt to a new car. mawawala yang burn-out feeling mo pag ginamit mo na yung LCG! sigurado yan!
#8349
LCG! LCG! LCG!
#8350
Meron . . . . . Yung binabalak natin na 'SHOT' race.
Katumbas kasi ito ng happy hour pagdating sa trabaho. . . . A time to unwind, and let it all out.
Seriously, I don't think you're experiencing a burnout. Plain and simple case lang yan ng KATAM!!!
Kung hindi mo talaga maumpisahan magtape o maglipat ng electronics, ipagawa natin kay BABYTOY ito this coming Sat!!!
#8351
rough: ok lang yan pare. di masyado importante yung malampaso sa race. dami pang race djan to look forward to and do better! i know how it can get frustating to sturggle in races. i've been that way recently since im not as consistent as i used to be ... partly siguro that i dont have the track time id like to have but regardless of the reason, nakaka-frustrate din talaga minsan. kaso, makatakbo ka lang naman ng isang magandang run, bawi agad yun.
parang soccer/football lang yan - saksakan ng hirap maka-goal! pero minsan lang maka goal, parang bawing bawi mo na agad ang paghihirap mo! kulang nalang labasan ka sa tuwa! hehehe kung baga, sulit lahat ng pagod mo. and i honestly think using the LCG will also help. Its no doubt a better car and should help you perform better.... then again, regardless kung ano pa kotse mo, racing should always be fun! -- win or loose!
dapat basta makapag-race, enjoy! pag maganda takbo, mas enjoy lang lalo!
#8352
Hanep, nakaka-encourage naman ang post nyo. Pang-manager ang dating.
LCG it is then. Ngayon pa lang, parang ginaganahan na ulit ako.
Thanks.
Thanks.
#8353
rbb- hayup ka. pinost mo pa dito. sa ibang forum ko na nga linagay para atin atin nalang eh.
#8354
STRIKER - Eh kahit san ka man mag-post ay masusundan pa rin naman namin eh.
Looking forward to your return of the come back. Stock tayong lahat!!!
#8355
