Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 08-02-2005, 09:44 PM
  #7261
XTREMERCHOBBIES's Avatar
Robo: yup! pero matagal pa yun. Stinger muna it looks good and balanced - they made the chassis stiff perfect for shaft.
XTREMERCHOBBIES is offline
Old 08-02-2005, 10:54 PM
  #7262
rough512's Avatar
Survey Quistion lang po kung may interested:
I have a friend who has a friend who has access to a machine shop (CNC equipped daw pero I have to verify pa).
Anyway, tanong ko lang kung merong intersado magpagawa ng spool for their cars. The spool would be similar to a one way diff minus the oneway bearing. A normal oneway cup would be inserted into the spool and locked by means of a pin. Advantage is, when the cup wears down, you only have to replace the cup, not the whole spool . You will also get to choose which one way cup you would like to use. Tamiya, Yokomo and Xray use the same oneway bearing size, right? Pwede kaya yun?
Anyway kung may willing magpahiram ng oneway assembly for their cars, baka pwede tayo magpagawa ng sample. Let me know na rin kung magkano yung ideal na price para sa inyo.
Thanks.
PS. The same friend of my friend is also making an aluminum disc wheel patterned after the yokomo units. Hinihintay pa namin yung sample. Para sa mga mahilig sa Bling although pang display nga lang sya. NOn-anodized daw sa ngayon.
rough512 is offline
Old 08-03-2005, 01:39 AM
  #7263
joelt's Avatar
ROUGH - DONUT! GONUT! DONUT! GONUT! DONUT! GONUT!
joelt is offline
Old 08-03-2005, 01:43 AM
  #7264
rough512's Avatar
Bayad muna! hehehehe
LCG conversion anyone? yuhooo... mura lang po...
rough512 is offline
Old 08-03-2005, 01:45 AM
  #7265
joelt's Avatar
ROUGH - Kung wala pang pumansin dyan by December, ako na lang ang kukuha. 12 gives, starting January 06.
joelt is offline
Old 08-03-2005, 01:52 AM
  #7266
rough512's Avatar
Sows, e bagsak na piso sa december eh heheheh.. kunin m na ngayon di ko sasabihin kay Mang na ikaw ang kukuha
Sana wag umulan sa Saturday. Gusto ko na ulit maglaro, and mang-uusyoso ako ng setup nyo nina Jason
rough512 is offline
Old 08-03-2005, 01:58 AM
  #7267
joelt's Avatar
ROUGH - Yung sa akin, ayaw mo usyosohin???? . . . . On second thought, wag na lang. Baka mag-dalawang isip ka kasing ibenta yang LCG mo kapag nasubukan mo yung sa akin eh.
joelt is offline
Old 08-03-2005, 02:19 AM
  #7268
rough512's Avatar
Sige na nga, malakas ka sa kin eh. May kasamang test drive pa kung gusto mo.
rough512 is offline
Old 08-03-2005, 09:00 AM
  #7269
judoka03g's Avatar
Default AM crystals
hello, baka naman meron kayong extra AM crystals? pamana nyo nalang sa akin!hahahaha.... or i can buy them did po. pero sana bigay nyo nalang! para masaya! thank u. pm me plz. happy raceing.
judoka03g is offline
Old 08-03-2005, 06:50 PM
  #7270
ROBORAT's Avatar
rough: since you will be using the drive cups of the one way unit and securing this with a pin, does that mean you will have to drill a hole through the drive cup inputs? lemme know, baka pwde ko bigay yung isang one way unit to use as a pattern.
.... shet, inggit ako sa inyo. no racing for me again this weekend. have a weekend long family thing to attend. anyway, have fun mga r/c bros! next week nalang ulit!
ROBORAT is offline
Old 08-03-2005, 08:12 PM
  #7271
rough512's Avatar
Yes sir, ganun na nga. Kasi pag grub screw gamitin, pwede mag-loose thread yun in the long run, and kailangan pa din magdrill sa cup to give the grub screw something to hold on to. With a pin, you can put a drop of glue to hold it in place. It's easy to tap the pin out when cup needs to be replaced.
Idea pa lang naman. If anybody has a better idea on how to secure the cup, please post them here.
I have oneway units for the Yok SD, X-ray T1 and TA04
rough512 is offline
Old 08-03-2005, 08:47 PM
  #7272
Ano masasabi niyo sa Tamiya TT01 chassis? Ok na ba ito pang laro-laro lang at occassional track use? parang trip ko kasi magbuo... please give me pros and cons if you arew familiar. thanks!
malibu is offline
Old 08-03-2005, 09:14 PM
  #7273
highwayman's Avatar
i'm in... but i dont have an extra 1 way unit now, but the idea of replacing just the drive cups instead of the whole unit is great.
highwayman is offline
Old 08-03-2005, 09:57 PM
  #7274
rough512's Avatar
Sir Jason : Okay lang po maski extra ball diff. Kung may existing kayo na lumang spool okay na din. Pag-usapan na lang natin sa Sat kung anong magandang design.
ANNOUNCEMENT:
I got an SMS from Mang:
Club Race daw sa Saturday, Aug6,2005 at Capitol Speedway. 27T and Modified. If the weather cooperates daw, snack will be on the house.
Race starts after lunch.
rough512 is offline
Old 08-03-2005, 10:03 PM
  #7275
highwayman's Avatar
LEM : on my LCG biggest is 100T 64 pitch spur. for capitol this is good for 27 turn and modified, not sure about 19T yet, as i havent tried it yet. BD biggest is 112, i use 104 now... this is good for any motor, any track. ROBO is right 22 to 40 T pinion shld cover you.
on set-up's... i want to try an LCG setting on my BD, ill let you know on saturday how it works out.
JOEL T : what's you ride height? if its not equal, make the front and rear the same ride height. i'll try those in-line's next time.
