Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 05-18-2005, 09:18 AM
  #6511
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
Originally posted by briangomez931
whoever created this account, if you think it's funny, then good for you. because it's starting to f***ing piss me off.
-- edit edit
pare... baka yan yung gumawa rin nung mga fake na wency accounts... or may stalker ka na bri?
Tommi Makkinen is offline
Old 05-18-2005, 11:01 AM
  #6512
lem2's Avatar
Originally posted by joelt
ROBO/HMAN/PITSHOP BOSS - Dala ako mga sirs ng blank setup sheets for the BD this Sat. . . . . Please fill in the blanks na lang.
BRIANG - You running this Sat? 19t?
Ako din pakopya ng set up!
HIGHWAYMAN: interesting stuff you did on your BD as posted on the BD thread, looking at the rear, parang mas maganda yun angle ng arms if I remove the rear spacers, that will improve mid corner stering? Will try it out!! Tumino lang yun CGM ko when I copied your set up, hopefully, I could do better with the BD!
Joelt: bakit 19T???? diba BD is for MOD!!!!
may go signal na ako sa saturday!!!!! kung saan ka dun ako!!!!
lem2 is offline
Old 05-18-2005, 06:49 PM
  #6513
ss
Originally posted by rough512
Sir JT: which is better, Horizontal or Vertical for 19T. Tama ba yung intindi ko sa vertical at horizontal. Please see attachment. Assume that it's a laydown brush...
Grabe.... seryos na ito..... akala ko ba walang dibdiban?
Chito - 27t or 19t? ... Thanks for the ride last sat!
ss is offline
Old 05-18-2005, 07:24 PM
  #6514
joelt's Avatar
LEM2 - 19t muna ako, kasi hindi ko pa nabubuo yung BD ko. In fact, I've only succeeded in putting CA on the carbon decks and shock towers. Pag nabuo yun, mod!!!!
Confirmed with PITSHOP BOSS that this weekend's race will be at Capitol. Anduon na ako, bago pa man dumating si Manong. Kitakits, you can take the seat my son will be emptying kung dadating ka after clinic hours.
ROUGH - Vertical sir. . . . Ito yung kinukuha ko from Pitshop boss eh. Ingat sa pag-dremel if this is what you plan to do kasi baka mabyak yung brush mo.
SS - Maniwala ka dyan kay ROUGH. . . . Alang ginawa yan buong araw kahapon kundi mag-surf para makakuha ng tuning tips para sa 19t!!!
FAKE NA BRIANG - You ha. Kilala na rin kita. . . . . ROUGH employed a technique na ginagamit nowadays para ma-trace ang mga nagkakalat ng virus, scams, at poison letters. May fatal flaw ka kasing nagawa eh.
joelt is offline
Old 05-18-2005, 07:51 PM
  #6515
rough512's Avatar
Sir JT: thanks sa response. hehehe... Mali pala yung cut ko sa brush hehehehe... may dalawang groove tuloy yung comm ko. BTW, nagnenok ako ng 2 instant soup sa paminggalan mo kagabi. The Knorr munchy mushroom is better than the Maggi burst of corn nagutom ako eh hehehehe...
nagpapaadvise na rin pala ko kay Evaa kung paanong gagawin sa HR nyo,
SS: Di ba sinabi ko sa iyo ang dahilan
rough512 is offline
Old 05-18-2005, 09:26 PM
  #6516
joelt's Avatar
ROUGH - Alang problema bast ikaw. Get as much as you like. Actually kasi, gusto ko na nga syang maubos kasi lumalaki ang ulo ko kapag kinakain ko sya. . . . . . dahil sa dami ng monosodium glutamate.
joelt is offline
Old 05-18-2005, 09:50 PM
  #6517
highwayman's Avatar
-- edit edit
... i didn't notice it at first !!! thought you'd gone off the deep end .. !!!
... anyway, relax, enjoy, lets play na lang on saturday !!!
highwayman is offline
Old 05-18-2005, 10:10 PM
  #6518
highwayman's Avatar
rough : do you have a brush factory?
joel : sure np.
LEM : sure np... which ones? arm spacing?
Old 05-18-2005, 10:17 PM
  #6519
highwayman's Avatar
LEM : sure no problem !
Things i changed from stock set-up
1. Fixed center pulley
2. 40wt all around
3. removed rear spacers underneath the hinge pin holders
4. rear arms forward
5. shock length 61.5mm
when its really hot, use center 1way and stock springs... for more steering change rear spring to white.
Old 05-18-2005, 10:30 PM
  #6520
rough512's Avatar
Sir Jason: wala eh. Ang alam ko lang na meron nun ay si Evaa. but that was 2 years ago pa. Baka nabenta na nya.
Dremel lang ang gamit ko, plus my kung-fu grip
rough512 is offline
Old 05-18-2005, 11:36 PM
  #6521
briang0mez931's Avatar
FAKE NA BRIANG - You ha. Kilala na rin kita. . . . . ROUGH employed a technique na ginagamit nowadays para ma-trace ang mga nagkakalat ng virus, scams, at poison letters. May fatal flaw ka kasing nagawa eh. [/B]
hehehe
briang0mez931 is offline
Old 05-19-2005, 02:54 AM
  #6522
highwayman's Avatar
sorry for the double post...
rough : paki bura na lang yung isa...
... medyo mahirap yung vertical slot, i haven't seen a brush with a vertical slot... horizontal and cavity lang...
Old 05-19-2005, 03:11 AM
  #6523
rough512's Avatar
Default Sir H'man
okay lang yung double post... hehehe...
sir, agree muna tayo sa vertical and horizontal. ang alam kong vertical and horizontal ay yung katulad sa attachment ko... yung vertical (based sa attachment ko, for laydown brush), meron na pala nito kay mang. and I think mas madaling gawin kasi mas malaki yung margin of error... di ko pa rin sure kung tama yung vertical at horizontal ko
I was able to make a horizontal slot (lengthwise cut. see attachment) using dremel and holding the brush with one hand. Hindi perfect but good enough. kakatakot!!! I had to wear safety goggles doing it kasi pag natabingi yung brush madaling mabasag yung cutoff wheel.
I'll be buying one of those plastic vices pag may nakita na ko... eto yung kulay red na plastic vise with metal strips para dun sa pressure edges, rubber suction cup at the base. panghawak ng brush para dalawang kamay ang hawak sa dremel
Attached Thumbnails Electric Touring / On-Road RC-brushcut.jpg
rough512 is offline
Old 05-19-2005, 03:16 AM
  #6524
who do you think i am?
things are not what they seem......
c-ya all this sat!!!
Old 05-19-2005, 03:19 AM
  #6525
highwayman's Avatar
ah ok... now i understand better... i haven't seen a "stand-up" with a cut in it... i don't know why, but in theory, all brushes, whether P-94, laydown or standup can be either full face, cavity, sloted, serrated or whatever cut you can do to it... trinity even suggests to "cut down the brushes" every time you cut the motor so that the brushes will fit perfectly with the comm every cut...
BTW... i have those red plastic vice... i'll lend them to you if you cut my brushes din... just kidding... i'll bring them on sat if i remember...
personally... too much work, but let me know if you do try it out.
