Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 02-24-2004, 03:11 AM
  #346
Blackwrench™'s Avatar
Default Sir Baguhan lng po
Nandun po ako sa Capitol last saturday, akin po ung Yellow Altezza na parati bumabaligtad. Ikaw po ung naka TC3 na shirt and a car na may average na 19.50sec sa capitol (I time cars in capitol to have data to compare with my car). ako po ung nasa dulo na mesa. crowded na kasi kayo dun sa table nyo kaya di na ako sumama sa inyo. next time that i saw you sir i'll approach you na. mukha sama ng tama ng car ng anak nyo, ako nanghihinayang every tie he hits the barrier. thanks po sa advice.
Blackwrench™ is offline
Old 02-24-2004, 03:58 AM
  #347
carbin's Avatar
Default where to run:)
Bro, try to run with us at park square early; 7-8am kami just come over.
carbin is offline
Old 02-24-2004, 04:11 AM
  #348
Default Thank you!
lem2 & carbin thank you!
burgermachine is offline
Old 02-24-2004, 05:41 AM
  #349
Hmmm...
Let me play contrarian...
If there are only a few threads (but many pages per thread), if I'm gone for a week, that's too many pages to have to go back to.
If there are many threads, and one doesn't want to read all of them, then of course you don't have to open that thread.
But really, I don't really mind either option (many threads or fewer threads).
My dos centimos.
--Alf
Alfalfameister is offline
Old 02-24-2004, 06:02 AM
  #350
Toolbox™'s Avatar
Thanks for the information. I will definitely check out all the sites and see what my best option is.
Are there any more sites? Does Action Hobbies have one of their own?
Toolbox™ is offline
Old 02-24-2004, 06:10 AM
  #351
Default tip po papuntang Park square 1
sir little help lng po.
Saan po ako pwedeng magleft sa ayala center? dun pa ba sa crossing? advice nalang po how can i get get there...
and if i'm commuting nu po sasakyan if galing akong cubao(baka kasi matuloy race sa march 3, that's wenesday, may van ends in 6, Coding ako). baka kasi mataga ako sa Taxi. thanks po uli.
Old 02-24-2004, 06:21 AM
  #352
Default Sir T-mak question po
I cut the bottom tail end of my altezza, un lng po kasi tamiya ko na body kasi expensive sya. ung detail ng exhaust pipe po un, para po madali damputin, legal parin ba un?
ung stock touring class po ba wala age limit as long as walang race experience?
ung old tires ko po ng TL-01 pudpud na sa capitolyo, what tires can i replace other than the orignal one's. that still falls to the stock touring class. also with the wheels.
Old 02-24-2004, 06:23 AM
  #353
lem2's Avatar
Default BLACKWRENCH
Holiday tomorrow, so cancelled ang color coding!
Easier to take the MRT, baba ka na ayala, then lakad ka na lang going to PSq1.
Lem
lem2 is offline
Old 02-24-2004, 06:41 AM
  #354
Default Help po sa charger ko
I'm planning to buy 6 cells of GP 3300mah at pitshop. kasi po i have a NIKKON manual quick Charger(sayang eh kaysa bumili pa ako), usually it charges my 1300mah battery for 25mins(don't know if it is overchage),
tingin nyo kaya po ng charger ko ung 3300mah?
how much time po kaya? tama ba ung charge ko sa 1300mah? output po ng charger ko is 13volts.
or should i invest na with a new charger (vintage na kasi charger ko eh). advice naman po kayo ng brand, ung 3k pababa lng un lng kasi kaya for now.
THanks again
Old 02-24-2004, 07:11 AM
  #355
lem2's Avatar
Default Get a new one
If your going to invest on batteries and chargingit with your nikko, ala pang one month patayna mga NiMh bats mo.
Get a new charger, if budget is not an issue, Protrak!!!! GFX!!!
then the Mil Pro, QUasars, Pulsars come next
kung ala pa din--buy 2nd hand!!!!!! But of course brand new is better.
kung ala pa din sa budget
Get the pocket chargers, yun kinakabit sa Power supply and automatic cut off, but it normally charges up to 4amps ranges between 1,500 to 2,500
either LRP micro charger or the eagle pocket charger, owned both and works great!
lem2 is offline
Old 02-24-2004, 07:59 AM
  #356
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
Default Re: Sir T-mak question po
well... if you didnt trim off too much, it would still be allowed. let me see the bodyshell sometime para i can judge if its clear to use.
wala age limit sa TL-01 spec or sa stock...
remember: TL-01 spec is for the rookies, Stock touring is for those with minor experience in racing...
you can only use tires listed under TL-01 spec class namely:
Tamiya Racing Slicks
Tamiya Radials
Tamiya Semi Slicks
Tommi Makkinen is offline
Old 02-24-2004, 08:00 AM
  #357
blackwrench,
i have an extra set (4pcs)of stock tamiya slicks. would you like to buy em?
Old 02-24-2004, 08:21 AM
  #358
Regional Moderator
Addict sa RC's Avatar
Guys, please visit Electric On-Road thread and put in your input. Thanks.
Addict sa RC is offline
Old 02-24-2004, 08:22 AM
  #359
Regional Moderator
Old 02-24-2004, 08:29 AM
  #360
Regional Moderator
Ok. So far walang hindi pumapayag sa ganitong scheme albeit may request to retain the Non-RC Stuff For Sale & Barter thread. And once ma-implement wala ng burahan ng thread so mawawala na yung mga Version numbers. I'll start implementing by Sunday so kung may violent objections kayo sabihin niyo na ngayon.
