Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 01-18-2014, 08:41 AM
  #31501
Leo V.'s Avatar
Default ..
Leo V. is offline
Old 01-26-2014, 06:33 PM
  #31502
hello guys...... question... when is the next practice?.....
can I invite anyone to join us?.. Me, my cousin Phil and my son is already three heads......
So I guess we just need three more companions?.....
Could we set it for this Saturday, Feb 1, 2014..... after lunch?.......
thanks..........
jun.venturanza is offline
Old 01-26-2014, 07:15 PM
  #31503
VooDooPH's Avatar
Trader Rating: 18 (100%+)
VooDooPH is offline
Old 01-27-2014, 05:22 PM
  #31504
VooDooPH's Avatar
Saturday Practice Session
February 1, 2014
1. Jason dela Cruz
2.
3.
4.
5.
6.
VooDooPH is offline
Old 01-27-2014, 07:31 PM
  #31505
Trader Rating: 14 (100%+)
want to play but have to be somewhere else on Saturday :-(...
mikeygar is offline
Old 01-27-2014, 08:15 PM
  #31506
VooDooPH's Avatar
February 1, 2014
1. Jason dela Cruz
2. Noel
3. Ralph
4.
5.
6.
VooDooPH is offline
Old 01-28-2014, 04:41 PM
  #31507
February 1, 2014
1. Jason dela Cruz
2. Noel
3. Ralph
4. jun
5. vurge
6.
On-Road GT Spec Class
Like Us on Facebook: https://www.facebook.com/RcGtSpec
[TRF418][TRF417][TB-04Pro][FF-03Pro][M-05 S Spec][F-104W][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12]
Old 01-29-2014, 12:06 AM
  #31508
Default Mighty gripper club race Feb.1
Hi Dears,
We have M.G.R. on feb.1. I already spoke to Jason about this and he is fine with it. we sorry for late schedule announcement. and thank you Jason!
Also, We(Ralph, Mikey, Taka) have M.G.R. on Feb. 15 and this will be manila F1 club race(Mr. Cocojam organizing) together.
The MGR on Feb.15, MGR F1 class will be as part of manila F1 race.
F1 class Rules might be follow the manila F1 rules. I may let you know more in days guys!
About The M.G.R. Feb. 1
Starting time: 1PM up to 3PM. Race finish target time 7PM.
Entree fee: 400PHP.
Each class top 1st winner will have MGR medal after race.
Minimum entry for each class will be 3~5 players.(organizers call)
Qualifying: A fastest lap record style. 2 times of 15 minutes open track a day.
Attention please!! All categories car will run together in this 2 times of 15 minutes qualifying.
We can save a lot of time by this method. Please you may get used to this.
A slower car will have priority to keep a racing line during qualifying. But A blocking car is not allowed for every one during Qualifying.
Other things are here below,
13.5T boosted kings class
3 times of 5 minutes races.
chassis: open for 1/10 size(190mm) 4 independent suspension touring car. FF car can join.
tires: open for rubber tires.
body: open for 190mm touring car body.
motor: open for 13.5T motors.
battery: open for (2s) 7.4V lipo, sub-C 7.2V, Life 6.6V.
weight limit: minimum 1400g (when ready to run)
ESC: open
About a special rules for this 13.5T boosted kings.
Each heat top runner will have 30g weight handy cap base on car minimum car weight.
This handicap is going maximum 2 times (total 60g) for heat winner.
You may please prepare weight balancer for your car by your-self.
About when Heat winner can remove the handicap weight?
If the person had lower then 4th(including 4th) on his final result in the race day,
This person can take off one time of handicap weight(30g) for the next race event.
※ during race day, the person has no chance to remove it anymore.
※ weight handicap is going to put for only top finisher of each heat.
※ If the person finished race over all result by 1 or 2 or 3 with the weight handicap,
He(she) must carry this handicap for the next race event again.
※ It can be remove If handicap holder person absent more then 3 month.
17.5T non boosted Meisters class
3 times of 8 minutes races.
chassis: open for 1/10 size (190mm) 4 independent suspension touring car. FF car can join.
motor: open for 17.5T motors. motor timing need to set on "zero" position.
If the motor has fix advance timing, FDR will be different.
FDR: Minimum FDR. is 3.80 (If motor has any fix advance timing 4.00)
ESC: open with no boosted and turbo timing.
About a special rules for this 17.5T non booted Meisters.
Each heat top finisher must change pinion gear 2 step smaller. If used tamiya 0.6 gears 1 step smaller.
This handicap is going maximum 2 times ( 4 step smaller) for the heat winner.
If used tamiya 0.6 gears maximum 3 times.
Please prepare your smaller pinion gears by your-self.
About when Heat winner can remove the handicap FDR?
This person can take off one time of handicap FDR for the next race event.
※ FDR handicap is going to put for only top finisher of each heat.
※ If the person finished race over all result by 1 or 2 or 3 with the FDR handicap,
He(she) must carry this handicap for the next race event again as his starting FDR.
Open wheel formula car challenge class
chassis: open for 1/10 size F1 and Indy. open wheel car only.
body: open for 1/10 open wheel bodies.
motor: 540-J, 21.5T blush-less motors can be use. trinity 21.5T can't use. blush-less motor must be set "zero" timing.
ESC: any blush ESC and any blush-less ESC without boosted and turbo timing.
weight limit: minimum 1050g
FDR: open
About a special rules for this Open wheel formula car challenge class
1, Each heat winner must change pinion gear 2 step smaller from his(her) last running of FDR.
If tamiya used 0.6 gears, 1 step each handicap and maximum 3 times.
2, "Passed winners" must use narrow (Max 190mm).
About the "passed winners".
Manila F1 club racer open class winner of 2012 and 2013, and, The mighty gripper cup F1 class winner of 2012 and 2013,
Also tamiya asia cup A main racers of 2012 and 2013.
(Or can play without getting winner medal)
Tub-chassis 540 masters class
chassis: any 1/10 size of tub-shassis touring car. 4WD, FWD, RWD.
body: only tamiya, HPI, and kyosho bodies can be use. proto etc racing bodies cant be use.
motor: 540-J ※ Max RPM 18500(7.2V), Max consumed electric 2.5A(7.2V). both will be check by motor master.
ESC: open
weight limit: minimum 1550g
FDR: Minimum FDR is 6.0
about special rules for this tub-chassis masters class.
Each heat winner must put 40g additional weight base on the minimum weight limit.
This handicap is going maximum 2 times (80g) for heat winner.
This person can take off one time of handicap weight(40g) for the next race event.
New?! Unrestricted car challenge class!!
2 or 3 times of lap-count qualifying. and 3 times of races.
We donít have M-chassis class this year independently. M-chassis please join in this Unrestricted class2.
Unrestricted class 1:
3times of 5 minutes race
faster more then brush-less 17.5T up to 2.5T, brushed 23T up to 6T, and nitro cars.
Unrestricted class 2:
3times of 8 minutes race
slower than bush-less non turbo 17.5T to any, brushed 25T up to any, silver cans, speed tune. torque tune, formula tune, lightly tune.
chassis: unrestricted
tires: unrestricted
body: unrestricted
motor: unrestricted
ESC: unrestricted
Battery: unrestricted
weight: unrestricted
FDR: unrestricted
Special rules for this unrestricted car challenge class.
2nd heat and 3rd heat will be reverse grid from result of previous heat.
About this class
whatever your RC car can run this class!
These Rules will have improved during in this season yet.
If you have any question, Please feel free to ask me, Ralph, and Mikey.
See you then Lets enjoy RC in manila!
taka
Mighty nokkey is offline
Old 01-30-2014, 04:28 AM
  #31509
ao97b's Avatar
Count me in for feb 1
ao97b is offline
Old 01-30-2014, 08:18 PM
  #31510
danjoy25's Avatar
Trader Rating: 38 (100%+)
Meron bang big electric on road events happening as April. Bakasyon ako sa Manila for 3 weeks and keen on having a run. We run 13.5t blinky here.
danjoy25 is offline
Old 01-30-2014, 10:25 PM
  #31511
cocojam's Avatar
Trader Rating: 47 (100%+)
Im not sure about the schedule of the annual summer shootout but there is the regular TAC qualifying series every other week plus the NASA Mighty Gripper races. What we normally have for 13.5 is the boosted class while blinky is limited to 17.5. If you have an F1, the F1 RC club will most likely have a race too in April. See in 2 months
cocojam is offline
Old 02-02-2014, 10:20 PM
  #31512
Default Race results of MGR Round 1 (Feb.1.2014)
1st round of MGR report and results is here.
We enjoyed to play 13.5T, 17.5T, open wheels class on last saturday.
Open wheels class had 5 players, it was not so much. But we had a new "TQ winner" in the open wheels(F1) class. Its was Mr.Coco jam. He also was held "a fastest lap of the day" on that full day. It was a really great job, he've made it with his 180mm narrow F1 chassis against 200mm F1 chassis.
Manila F1 club race founder Allan came back to MGR open wheels class. And we knew that he was still good old driver in this class. He've had 2nd in there.
●Open wheel class Qualifying results●
1st. Jun Manego SJF01:time (20.019s)
2nd. Allan corico F103: time (20.144s)
3rd. Ramund F104Pro: time (21.005s)
Rey F104V2:didn't run Qualifying
Jomile SJF01:didn't run Qualifying
●Race results● ( 3times of 8 minutes races)
H1, H2, H3, Race best time, ave time, best vs ave
1st. Jun manego (3 / 2 / 1) 18.625s 19.554s (-0.929s)
2nd. Allan (2 / 1 / 2) 18.763s 19.622s (-0.859s)
3rd. Rey (4 / 4 / DR) 21.736s 24.075s (-2.339s)
4th. Raymund (5 / 3 / 3) 20.565s 21.416s (-0.851s)
5th. Jomile (1 / DR / DR) 18.691s 19.938s (-1.247s)
!7.5T non boosted class became so tight time battle, its because of control FDR. But, no one couldn't stop him.
Its him, one of most experience manila racer Noel aldaba won!
Even He didn't run qualifying then he had back grid started.
The handicap rules actually worked on his car.., but He was so faster than others at his cornering speed. Now he is going to carry 4 pinion gear handicap for next MGR and JPR race.
Look at Rains,Denis, and Jason's best lap! We've never see like this so close yet right?
●17.5T non boosted Qualifying results●
1st. rains viela 417V5: time 17.900s
2nd. Jason dela cruz 417smokem: time 17.900s
3rd. Denis Lusindo TCXX: time 17.960s
4th. yuichiro takaya TB04Pro: time 18.900s
5th. manito manego BD5: time 18.351s
Noel aldaba 416, didn't run
Reymund no data, didn't run
1st. Noel aldaba (DR / 1 / 1) 17.044s 17.458s (-0.414)
2nd.Yuichiro Takaya (1 / 3 / DR) 18.009s 18.483s (-0.474)
3rd. Jason dela crus (2 / 6 / 3) 17.219s 18.032s (-0.813)
4th. Denis Lusindo (4 / 4 / 2) 16.942s 17.716s (-0.774)
5th. Rains viela (5 / 2 / 4) 17.664s 18.006s (-0.342)
6th. Manito Manego (3 / 5 / 5) 17.990s 18.274s (-0.284)
7th. Ramund (6 / 7 / 6) 18.320s 18.844s (-0.524)
Sad to say the 13.5T class was just 4 players. JP,Ralph,Mikey,Jerome L, Joseph etc, Common 13.5T class winners were not there. Thats why It became just taka's show time..
New player Denis was showing us very nice driving in 13.5T class too. But this class car need too much set-up and also need a experiments to have enough competitive car.. this is the problem for all new players in the 13.5T. All new player must have a buddy who had good experience, we think.
For all new players, Please don't hesitant to have a assist for your car and ESC set-up from me, Ralph, and Mikey at the race track.
●13.5T boosted class Qualifying●
1st. Yuichiro Takaya 417 V5 time: 15.620s
2nd. Jason dela cruz 418 time: 17.190s
3rd. Jerome span spec-R time: 18.329s
Denis Lusindo 418 didn't run
●Race results● ( 3times of 5 minutes races)
H1, H2, H3, Race best, ave time, best vs ave
1st. Yuichiro Takaya (1 / 1 / 1) 14.923s 15.190s (-0.267s)
2nd. Jason dela cruz (2 / 2 / DR) 16.023s 16.778s (-0.755s)
3rd. Jerome span (3 / 3 / 2) 16.807s 17.483s (-0.676s)
4th. Denis Lusindo (4 / 4 / 3) 16.636s 18.596s (-1.960s)
I'd like to introduce some important thing to be faster for you. That is "best vs ave" you can see on my this race report.
This must be below 0.5s if your want to be winner in any class I guess.
So, Manito(-0.248s), Rains(-0.342s), were very good driver that I can see it, This time.
If Manila and Rains has more good set-up car, sure they will have more good results. As you know, You can make "best vs ave" better by "consistent driving". Manito's -0.248s was really impressive!!
We are looking for more player come! see you next guys!
(Next MGR is feb. 15 together MF1club race)
Special thanks for JP raceway!
taka
Old 02-02-2014, 10:59 PM
  #31513
VooDooPH's Avatar
Nice race Taka san!
VooDooPH is offline
Old 02-03-2014, 04:30 AM
  #31514
Originally Posted by VooDooPH
Nice race Taka san!
Thank you Jason! Lets have more fun on next MGR.
Old 02-03-2014, 05:52 PM
  #31515
cocojam's Avatar
Thank you Taka for the nice race last saturday. Your commentary on Manito's consistent driving is surprising considering that it was his first race after being sidelined for several months. I will let him know this to motivate him to race more often. Thanks and see you on Feb 15.
cocojam is offline
