Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 01-14-2014, 05:10 PM
  #31486
RRRoy23's Avatar
Originally Posted by ao97b
Nice race update taka! Rains here. Hope to join the next race
Mr. Rains..... kamusta ka na po?
RRRoy23 is offline
Old 01-14-2014, 05:33 PM
  #31487
agent23's Avatar
Are newbies welcome to join your practice session on Saturday, Jan. 18?
agent23 is offline
Old 01-14-2014, 05:46 PM
  #31488
VooDooPH's Avatar
Trader Rating: 18 (100%+)
newbies are always welcome sir
VooDooPH is offline
Old 01-14-2014, 05:55 PM
  #31489
VooDooPH's Avatar
Saturday, Jan 18
PRACTICE SESSION
(please sign up)
1. Jason
2. Vin
3. Jun
4. Alec
5. Ralph
6. Rains
7. Cocojam
VooDooPH is offline
Old 01-14-2014, 06:54 PM
  #31490
agent23's Avatar
What time will practice session start?
agent23 is offline
Old 01-14-2014, 09:27 PM
  #31491
ao97b's Avatar
M here in lax. How far is revelation raceway fr here?
ao97b is offline
Old 01-14-2014, 11:34 PM
  #31492
VooDooPH's Avatar
58 mins away (82.1kms away)
https://maps.google.com.ph/maps?ie=U...ed=0CC8Q-A8wAA
VooDooPH is offline
Old 01-15-2014, 05:59 AM
  #31493
westsideafrica's Avatar
Mga Paps makapagtanong na newbie here. I have Tamiya TBO3 na naka CS. Madali ko bang e convert ito para maging touring? Nag palit na ako ng on-road tires, kung sakali how much pa kaya magastos ko sa convertion?
TIA
westsideafrica is offline
Old 01-15-2014, 06:52 AM
  #31494
VooDooPH's Avatar
Youd neet to change to the bevel gears onn your front and rear diffs back to stock (should run the same size front and rear, sa CS kasi magkaiba ata).
Probably your front upright needs to be replaced too, back to stock.
Then remove all the one way bearings (kung meron) in your drivetrain. For on road, we usually run spool or locked diff in front and either a ball diff or a gear diff at the back. Thts
VooDooPH is offline
Old 01-15-2014, 07:56 AM
  #31495
ao97b's Avatar
Originally Posted by VooDooPH
Hope to visit next tym... Jp muna tayo sat
ao97b is offline
Old 01-15-2014, 08:49 AM
  #31496
Trader Rating: 14 (100%+)
True 90C is coming...
mikeygar is offline
Old 01-15-2014, 05:43 PM
  #31497
Default Saturday practice
Im In po.
1. Jason
2. Vin
3. Jun
4. Alec
5. Ralph
6. Rains
7. Cocojam
8. Taka
Mighty nokkey is offline
Old 01-16-2014, 04:58 PM
  #31498
agent23's Avatar
1. Jason
2. Vin
3. Jun
4. Alec
5. Ralph
6. Rains
7. Cocojam
8. Taka
9. Lord
Count me in. Bdw, what time does the track open? What time does practice start?
agent23 is offline
Old 01-16-2014, 05:59 PM
  #31499
Hello Dear Rc player in manila!
Here are the Mighty gripper club race (MGR) and JPR basic rules for season 2014.
Please check and get ready to have Fun together.
(Race day calendar will be follow posting by Mikey and Ralph soon.)
Starting time: 1PM up to 3PM. finish race target 7PM.
Entree fee: 400PHP.
Each class top 1st winner will have MGR or JPR medal after race.
Minimum entry for each class will be 3~5 players.(organizers call)
Qualifying: A fastest lap record style. 2 times of 15 minutes open track a day.
Attention!! All categories car will run together in this 2 times of 15 minutes qualifying.
We can save a lot of time by this method. Please you may get used to this.
A slower car will have priority to keep a racing line during qualifying. But A blocking car is not allowed for every one.
Other things are here below,
13.5T boosted kings class
3 times of 5 minutes races.
chassis: open for 1/10 size(190mm) 4 independent suspension touring car. FF car can join.
tires: open for rubber tires.
body: open for 190mm touring car body.
motor: open for 13.5T motors.
battery: open for (2s) 7.4V lipo, sub-C 7.2V, Life 6.6V.
weight limit: minimum 1400g (when ready to run)
ESC: open
About a special rules for this 13.5T boosted kings.
Each heat top runner will have 30g weight handy cap base on car minimum car weight.
This handicap is going maximum 2 times (total 60g) for heat winner.
You may please prepare weight balancer for your car by your-self.
About when Heat winner can remove the handicap weight?
If the person had lower then 4th(including 4th) on his final result in the race day,
This person can take off one time of handicap weight(30g) for the next race event.
※ during race day, the person has no chance to remove it anymore.
※ weight handicap is going to put for only top finisher of each heat.
※ If the person finished race over all result by 1 or 2 or 3 with the weight handicap,
He(she) must carry this handicap for the next race event again.
※ It can be remove If handicap holder person absent more then 3 month.
17.5T non boosted Meisters class
3 times of 8 minutes races.
chassis: open for 1/10 size (190mm) 4 independent suspension touring car. FF car can join.
motor: open for 17.5T motors. motor timing need to set on "zero" position.
If the motor has fix advance timing, FDR will be different.
FDR: Minimum FDR. is 3.80 (If motor has fix advance timing 4.00)
ESC: open with no boosted and turbo timing.
About a special rules for this 17.5T non booted Meisters.
Each heat top finisher must change pinion gear 2 step smaller. If used tamiya 0.6 gears 1 step smaller.
This handicap is going maximum 2 times ( 4 step smaller) for the heat winner.
If used tamiya 0.6 gears maximum 3 times.
Please prepare your smaller pinion gears by your-self.
About when Heat winner can remove the handicap FDR?
This person can take off one time of handicap FDR for the next race event.
※ FDR handicap is going to put for only top finisher of each heat.
※ If the person finished race over all result by 1 or 2 or 3 with the FDR handicap,
He(she) must carry this handicap for the next race event again as his starting FDR.
Open wheel formula car challenge class
chassis: open for 1/10 size F1 and Indy. open wheel car only.
body: open for 1/10 open wheel bodies.
motor: 540-J, 21.5T blush-less motors can be use. trinity 21.5T can't use. blush-less motor must be set "zero" timing.
ESC: any blush ESC and any blush-less ESC without boosted and turbo timing.
weight limit: minimum 1050g
FDR: open
About a special rules for this Open wheel formula car challenge class
1, Each heat winner must change pinion gear 2 step smaller from his(her) last running of FDR.
If tamiya used 0.6 gears, 1 step each handicap and maximum 3 times.
2, "Passed winners" must use narrow (Max 190mm).
About the "passed winners".
Manila F1 club racer open class winner of 2012 and 2013, and, The mighty gripper cup F1 class winner of 2012 and 2013,
Also tamiya asia cup A main racers of 2012 and 2013.
(Or can play without getting winner medal)
Tub-chassis 540 masters class
chassis: any 1/10 size of tub-shassis touring car. 4WD, FWD, RWD.
body: only tamiya, HPI, and kyosho bodies can be use. proto etc racing bodies cant be use.
motor: 540-J ※ Max RPM 18500(7.2V), Max consumed electric 2.5A(7.2V). both will be check by motor master.
ESC: open
weight limit: minimum 1550g
FDR: Minimum FDR is 6.0
about special rules for this tub-chassis masters class.
Each heat winner must put 40g additional weight base on the minimum weight limit.
This handicap is going maximum 2 times (80g) for heat winner.
This person can take off one time of handicap weight(40g) for the next race event.
New?! Unrestricted car challenge class!!
2 or 3 times of lap-count qualifying. and 3 times of 8 minutes races.
We donít have M-chassis class this year independently. M-chassis please join in this class.
Unrestricted class 1:
faster more then brush-less 17.5T up to 2.5T, brushed 23T up to 6T, and nitro cars.
Unrestricted class 2:
slower than bush-less non turbo 17.5T to any, brushed 25T up to any, silver cans, speed tune. torque tune, formula tune, lightly tune.
chassis: unrestricted
tires: unrestricted
body: unrestricted
motor: unrestricted
ESC: unrestricted
Battery: unrestricted
weight: unrestricted
FDR: unrestricted
Special rules for this unrestricted car challenge class.
2nd heat and 3rd heat will be reverse grid from result of previous heat.
About this class
whatever your RC car can run this class!
These Rules will have improved during in this season yet.
If you have any question, Please feel free to ask me, Ralph, and Mikey.
See you then Lets enjoy RC in manila!
taka
Old 01-16-2014, 07:30 PM
  #31500
hey guys, new rules are designed to make the races more competitive and make it more difficult for race winners to hold their positions in the next races. This makes for tighter and closer racing for everybody!
mikeygar is offline
