Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 01-20-2013, 10:56 PM
  #30766
reichsmarshal24's Avatar
Thanks guys I'll look into AH. If wala, I'll check the shops in Singapore.
reichsmarshal24 is offline
Old 01-22-2013, 04:09 AM
  #30767
VooDooPH's Avatar
Trader Rating: 18 (100%+)
http://www.quantumracing-rc.com/inde...productId=3324
VooDooPH is offline
Old 01-22-2013, 04:21 AM
  #30768
Thanks Jason. Just ordered mine yesterday. Hehehehe
Old 01-22-2013, 10:21 PM
  #30769
ROBORAT's Avatar
@reichsmarshal: cool! let us know how quick it is to order from quantumracing ang enjoy the upgrade! It should help get you car dialed in!
ROBORAT is offline
Old 01-22-2013, 10:38 PM
  #30770
Thanks Gerry. Will let you guys know how fast they deliver. But I'll work on the Spec R muna for blinky. If kaya ko i-drive 13.5, dun ko na lalaspagin yung bargain TRF416.
Old 01-23-2013, 04:29 AM
  #30771
i emailed Smokem last week coz Gerome and I are also looking to get another 417FX chassis, sabi nila $6 lang shipping to PH. Yun nga lang wala naman stock nung 417FX..
Minami is offline
Old 01-23-2013, 10:42 PM
  #30772
alecladanga's Avatar
Originally Posted by VooDooPH
i think they order from smokem not exotek...
Correct correct men, smokem nga! thanks dude
Mga peeps,
Saw this link in one of the threads in the EP onroad, something to think about
http://www.rctech.net/forum/11071986-post29.html
alecladanga is offline
Old 01-24-2013, 04:31 AM
  #30773
geromeling's Avatar
astig! i'll give that a try this weekend!
geromeling is offline
Old 01-24-2013, 04:41 AM
  #30774
VooDooPH's Avatar
saw that too... hehehehe
VooDooPH is offline
Old 01-24-2013, 05:05 AM
  #30775
cocojam's Avatar
Trader Rating: 47 (100%+)
Mga peeps,
Bagay pala pang TC6 eto. Will try it in ours.
cocojam is offline
Old 01-24-2013, 07:54 PM
  #30776
ROBORAT's Avatar
Mga peeps,
yep! that's the trick. i've been using small strips of tub tape under my batts to achieve just that in order to make the packs "float" and give the chassis some room to flex more. admittedly though, i can't really feel much of a difference hehehe maybe im just not good enough to notice or because but i've been doing this ever since my BD5 so dont know how it feels without. .... try ko minsan na walang tape risers just to see.
ROBORAT is offline
Old 01-24-2013, 08:13 PM
  #30777
tmomedrano's Avatar
i was thinking about the tape thing sa batts but i feel like magtataas ka ng CG which has more effect on handling than the flex imporvement itself. the trf417v5 has 0.5mm raised bulkheads = higher CG to make the car roll more = more side grip = more chances of traction rolling (in our case). it was was the tuning for the worlds kasi since bawal yung compound.
baka maliit lang naman talaga difference nun tape thing. the tape itslef has flex in effect the baterry still moves around anyway. its not screwed in naman. just my 2 cents.
baka sila hara, rheinard and groskamp nalang nakakaramdam nun and shave off time with those mods hehe
parang power caps hehe I did have the power cap craze when I was doing silvercan. in the end it only gave me some placebo effect = more confidence hehe
tmomedrano is offline
Old 01-24-2013, 11:20 PM
  #30778
ROBORAT's Avatar
@tmomedrano: yup, agree it will definitely raise the CG. but it shouldn't be anything major as you're just looking at strips of tape which should be quite thin ... especially if using electrical tape. I guess the intent of the entire exercise is to make the car feel consistent rather than make it handle drastically different. It's more so flex on each side feels similar since on the other side of the chassis there isnt anything strapped or bolted down to hinder the flex... moreso now with the intro of floating servo mounts. In any case, the added roll higher CG (albeit marginal at best) this will provide can be easily offset by chassis set up by playing around with roll centers to lessen roll/camber gain, etc. Think of of it like you added a shim under your batts so offset this by taking a shim our of your camber links (if needed) to compensate ... but this time with an added consistency the tape tip is supposed to provide. But yeah, like we've mentioned, we probably cant feel it anyway but it shouldn't hurt to try out if you haven't done it yet. Personally don't think the slightly elevated CG will be enough to make traction rolling a problem. Thing of it as a tuning option nalang i guess. Ako personally I leave the tape in and just work my set up with it there.
ROBORAT is offline
Old 01-25-2013, 12:38 AM
  #30779
race na lang yan hahaha
EDIT: nvm, i just saw the race time table for tomorrow..
Minami is offline
Old 01-26-2013, 08:06 PM
  #30780
ROBORAT's Avatar
@minami: korek! kaya tara na!
ROBORAT is offline
